#239 |
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
could the difference come from the header, since nelsmar did the tune + BPB and shiv did Header + tune + BPB ?
#240 | |
Drives: 2013 FRS
But to re-state, additional tuning was able to negate most of the top end caused by the BPB on the OTS map. So then you are left with the really nice +10whp gains in the 5500-6500rpm range. And I should also point out that one thing that makes an OTS map so successful in a wide range of cars is that it isn't aggressive where it doesn't need to be. But it's clear that needs can change when changing things like runner lengths. A drop off in top end VE would, by definition, necessitate more ignition timing advance up top. And that is exactly what we gave it (among other things) to get back the power back. Last edited by Shiv@Openflash; 04-04-2014 at 11:57 AM. |
| The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post: |
#241 | |
Drives: 2008 STI
MotoIS's tests were performed on a totally stock car which tells us what the minimum overall gains will be. When you add your components and tune with our Power Blocks, the overall results will be much better as you are seeing! Good work. |
#242 | |
The pressure that weather stations report is the "altimeter setting" based upon present atmospheric conditions. This "setting" is used to calibrate an altimeter to correctly show your actual altitude relative to sea level. To get your actual barometric pressure you need to use this setting in conjunction with your actual altitude. To make it easy, this site http://wahiduddin.net/calc/calc_hp_dp.htm has a handy calculator that lets you see the relative pressure (as compared to sea level). I don't believe the speed of sound changes a whole lot at the low altitudes you are testing at so there likely aren't any significant resonant changes. I could be wrong though. |
| The Following 2 Users Say Thank You to R2 For This Useful Post: | nelsmar (04-04-2014), Shiv@Openflash (04-04-2014) |
#243 |
Drives: Pavement MT GR86
I would guess it has more to do with full exhaust setup vs a stock car....
Essentially hitting a ceiling on power without FI or changing parts internal to the engine.
GR86 MT premium
#244 |
I may be able to arrange testing of that as well... Depends on the owners decision though. I was tuning a local with a header and header back exhaust who was thinking of ordering these as well.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#245 |
Drives: 2008 STI
#246 |
I don't have a car right now otherwise I could leave in the morning.
#247 |
Drives: 2008 STI
#248 | |
Drives: small
I also can't see if they didn't add more than just the TB like a full system and/or a tune. Btw, there are some tricks you can do to make a dyno improve or lie within that margin of error. Look what I found: ![]()
| The Following User Says Thank You to Boxer486 For This Useful Post: | cslntuee (04-05-2014) |
#249 |
#250 | |
Drives: Subaru BRZ Limited
I do not have too much background knowledge in this topic. (The torque unit which that Japanese website using looks different. I am not sure that is big improvement in low RPM or not) I personal believe that Big TB is the similar case as intake pipe. It will slow the air flow when the diameter is increase. It should cause losing the torque in the low RPM. It is what I learn in physics. However, here is some intack pipe result. We can see the torque result in the low rpm. Actually, it shows slightly increase. Perrin http://perrinperformance.com/i-13324...-fr-s-brz.html Zetaperformance http://www.zetaperformanceltd.com/ca...201/image/661/ I do not know how to explain this. It is not match what I learn. Here is the same case for BPB. It should strongly benefit for the low RPM from the physics or I should say that we should see the different from the dyno at least. However, it looks almost same result as stock in low RPM.(It helps a lot in middle range) I am not trying to say big TB will help. However, it might something useful there, because there are a lot of aftermarket big TB for BRZ now. I will be a little bit surprising me that they all try to bullshit. I also not very trust the BPB at beginning as the same logic, because I did not see any other aftermarket BPB. However, I saw so many dyno evidence from Crawford BPB. It convinced me. I also hope that I can see some big TB dyno result for BRZ, before I try to challenge those aftermarket TB company are bullshit or hope those company can show more dyno result. Thanks. Last edited by cslntuee; 04-05-2014 at 01:42 PM. |
#251 | |
Drives: '14 FRS White
That appears to be for the inlet hose, not TB. I think it would contribute gains simple due to the fact it's not convoluted and has a much smoother airflow path. Correct me if i'm wrong, (road trip and i'm tired, lol)
| The Following User Says Thank You to DriftHappens For This Useful Post: | Boxer486 (04-05-2014) |
#252 | |
I wrote on my original post "I personal believe that Big TB is the similar case as "intake pipe". I think that will slow the air flow when the diameter is increase.( I mean the intake pipe) It should cause losing the torque in the low RPM. (It will help for high RPM that I understand as you mentioned) Thanks. Last edited by cslntuee; 04-05-2014 at 01:04 PM. |
| Crawford Billet Power Blocks | smbstyle | Engine, Exhaust, Transmission | 799 | 01-18-2016 05:01 PM |
| Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 | ZetaVI | BRZ Photos, Videos, Wallpapers, Gallery Forum | 22 | 04-01-2014 05:19 PM |
| Squidbelly wants to know the best way to gut a manifold cat | regal | Engine, Exhaust, Transmission | 14 | 03-07-2014 10:31 AM |
| short blocks? | 350matt | Engine, Exhaust, Transmission | 4 | 11-04-2013 08:37 PM |
| Billet Oil Catch Can #BC-175 by Billet Custom | Tim_Asphalt_FRS | Engine, Exhaust, Transmission | 48 | 10-27-2013 02:29 PM |
