Old 04-02-2014, 05:44 PM   #1247
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by FullBlown View Post
Loook... TQ reading
I know, dat 272 ft-lbs is what reminded me of my car:
Old 04-02-2014, 06:05 PM   #1248
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Reaper View Post
I'm sold on the gtx28 with stock compression. I specifically chose it over the 30 and made some serious tq as well. Much more than a gtx30 tuned by the same tuner.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Get a new tuner
Old 04-02-2014, 06:15 PM   #1249
sw20kosh
Drives: 2013 Black FR-S
Get a new tuner
this
Old 04-02-2014, 06:17 PM   #1250
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Yeah that wasnt a truely fair statement on my part. There where many more variables than just the turbo.
Old 04-02-2014, 06:41 PM   #1251
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
This may be off topic, but I have a custom turbo kit, very similar to the FB piping (front top mount turbo, IC piping, hot pipe very close to fans etc.). I read some posts about fans melting, and that the slim fan/rad upgrade is almost a must with this sort of piping.
I wrapped my hot pipes with some titanium wrap, and after about 10 dyno pulls during the tuning, it was cool enough to the touch that I can grab the pipe no problem. I'm assuming many of you have your pipes wrapped for heat issues, but if I can touch the pipe after 10 back to back dyno pulls, how is it that the FB kit pipes are so much hotter? Ofcourse the hot side turbo housing is super hot, but that is a little farther away from the plastic housing of the fan.
I'm still planning on upgrading the fans/shroud/radiator but was curious how many of you are having issues with over heating, other than track abuse.
Thank you, and I would of chosen the FB kit if my local company didn't give me such a good deal!
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 04-02-2014, 06:50 PM   #1252
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Not everyone has had fan melting issues. I had my downpipe coated by LJ and wrapped it with the black header wrap LJ included with my kit, and after 15,000 miles of boost my fans never melted or failed.
Old 04-02-2014, 06:51 PM   #1253
Dipstik-sportech
Dipstik-sportech's Avatar
Was your hood open or closed during the pulls? How hot was it at the time?
The Frozen North
Old 04-02-2014, 06:52 PM   #1254
Reaper
Reaper's Avatar
Drives: violent
I had the similar results coated and wrapped with dei titanium.
Old 04-02-2014, 06:58 PM   #1255
BRZPDX
Boosted Member
BRZPDX's Avatar
Hood was open and it was cool during the winter, but we had guys checking the heat right after pull after pull to see what kind of heat was generated and where. We can touch the pipe right after the pull, unless heat dissipates that fast.
i live in the PNW so it never gets scorching hot/humid like other states, which might help with this issue as well.. There are people not even running a oil cooler with FI, and seems to be ok, and others are having major heat issues. It can be quite confusing when I read through different problems with similar set-ups.
Old 04-03-2014, 06:48 PM   #1256
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Originally Posted by OjiGeorge View Post
Have been driving the new Full Blown SD base map for a few days now and the car drives smooth as butter. I'm amazed as I haven't been in any NA to Turbo cars that drive so well! Question I had for you guys, When I'm full throttle 4K+ what would you consider a good window for AFR? What would be considered too lean and what too rich?
No one dialed in knows their AFR's?
I'm just installing ECUtek on my new laptop so I can send LJ a log of the base SD tune. As I menioned before the tune runs very smooth, however when doing a pull the AFR is so rich that it's way way off the scales of what the factory baby wideband can read. I knows it's running this rich based on the info from my AEM A/F wideband gauge.
I'd log from the AEM failafe, but still need to find that pesky RPM wire. For some reason my Canadian FR-S doesnt seem to have the RPM signal wire that is shown in the thread about tapping into the RPM wire :/ Maybe it's an American 86 or a BRZ thing?
OjiGeorge is offline   Reply With Quote
Old 04-03-2014, 06:54 PM   #1257
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
How rich is your aem reading?
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 04-03-2014, 07:00 PM   #1258
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
U sure u have the aem failsafe set up to read AFR?
I love boost!!!!!!
Old 04-03-2014, 07:08 PM   #1259
OjiGeorge
OjiGeorge's Avatar
Had a shop install it, so I'm pretty sure, yes. The gauge is also reading like any other wideband I've seen, and the readings change as I'd expect them to via throttle load.
It idles around 14.5, cruises at 12-13 and when really on the gas it's rock solid at 9.5
Old 04-03-2014, 07:09 PM   #1260
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Full Blown Turbo Kit Owners Topic
Had a shop install it, so I'm pretty sure, yes. Is reading like any other wideband I've seen, and the readings change as I'd expect them to via throttle load.
It Idles around 14.5 cruise 12-13 and when really on the gas it's rock solid at 9.5
Wtf 9.5 ?
Sent from my IBrick
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
