#43 | |
Drives: 13 CSB BRZ Ltd
DIY - Gauge Cluster LED swap
I would be very careful using the cheap irons. There's no way for you to know how hot the tip temperature is unless you directly measure it, and temperature is what kills components during removal and installation.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread |
| The Following User Says Thank You to Acree For This Useful Post: | sshole (04-03-2014) |
#44 | |
Yup. It's making too much heat for the tip to handle. |
#45 | |
I've had my tips burn up on my analog Weller station even, and fairly regularly. That's why I recommend a temperature controller station.
#46 |
#47 | |
| The Following 5 Users Say Thank You to Acree For This Useful Post: | Eski (02-25-2015), mixtape (05-28-2016), Pwolf (04-03-2014), sirisvirus (04-05-2014), texasbound972 (12-12-2015) |
#48 |
Drives: 2013 GBS BRZ Limited
I just did my HVAC last weekend and am planning on doing something similar to what you have with gauge cluster (white numbers, blue bars, red rev limit, etc). If you don't mind, I may end up shooting you a PM with some questions.
| The Following User Says Thank You to Pwolf For This Useful Post: | Acree (04-03-2014) |
#49 |
all this talk about ebay quality caused my fuel gauge LED to die on the way back home.
#50 |
That sux. But you do know how to fix it, sooooo. There is that.
2013 FRS-Asphalt-M6-Invidia N1, K&N drop in, plasti dipped emblems, debadged FRS, Spyder II tails, 5000K Bi-xenon HID's, red demon eyes, Quad halo's, switchbacks w/Tapturn mod,Grimmspeed hood struts, led everything exterior, H&R 25mmF/15mmR spacers, Sportlines, SPC LCA's..(FUN car)
#51 |
Yup, fixed it in 10 minutes (got distracted by wife being sick).
#52 |
Just finished my conversion this morning
![]() Thanks guys.
| The Following 2 Users Say Thank You to Pwolf For This Useful Post: | Acree (08-12-2014), Mooseknuckle44 (07-27-2014) |
#53 |
I've found blue in the daytime on the clock is nearly impossible to see. Looks awesome at night, but l rarely drive in the dark.
#54 |
Drives:
@Pwolf I'm looking to do this was it a hard mod to do? What LEDs did you use?
Sent from my BRZ limited using plastic cup 2.0
Sent from my Subaru BRZ Limited using plastic cup 2.0
#55 |
Drives: FRS monogram
#56 | |
Cool White for the gauges from: http://www.oznium.com/plcc-2 and then Blue for the LCD displays from: http://lighthouseleds.com/plcc-2-121...-1000-mcd.html (Probably doesn't matter but the blue ones from Oznium didn't seem bright enough earlier in my LED conversion process so I bought a bunch from Lighthouse LEDs to do finish the interior.) For the gauges I bought some transparent blue vinyl from Ebay: http://www.ebay.com/itm/Transparent-...-/370298539724 Had to cut out and stick it to the backside of the insert. That was the hardest part and took the most time. @Mooseknuckle44, probably depends on what LEDS you're using. I have no problem seeing the clock or the LCDs on my gauge cluster during the day or night. Definitely looks better in the dark though :P
| The Following 3 Users Say Thank You to Pwolf For This Useful Post: |
| Gauge Cluster on FRS | tonytduc | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 07-24-2017 09:56 PM |
| BRZ cluster gauge swap? | InYOHface | Cosmetic Modification (Interior/Exterior/Lighting) | 31 | 03-25-2017 06:31 PM |
| WTB gauge cluster | Basti | Want-To-Buy Requests | 3 | 04-09-2014 02:54 PM |
| Gauge cluster mod? | kALMIGHTY | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-27-2013 10:59 PM |
| Want to try a gauge cluster experiment with me? | stockysnail | Northwest | 2 | 04-12-2013 10:57 AM |
