Old 04-03-2014, 02:26 PM   #43
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
DIY - Gauge Cluster LED swap
Originally Posted by sshole View Post
I've been getting by with crappy throw-away $10 RadioShack soldering irons for the past 10+ years. I've seen no need to upgrade to the $50+ units from the "Snap-On" brands.
I would be very careful using the cheap irons. There's no way for you to know how hot the tip temperature is unless you directly measure it, and temperature is what kills components during removal and installation.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
The Following User Says Thank You to Acree For This Useful Post:
sshole (04-03-2014)
Old 04-03-2014, 02:29 PM   #44
sshole
Originally Posted by Acree View Post
I would be very careful using the super irons. There's no way for you to know how hot the tip temperature is unless you directly measure it, and temperature is what kills components during removal and installation.
I've noticed on the current soldering iron I've got from RadioShack that the tip is melting.
Yup. It's making too much heat for the tip to handle.
sshole is offline   Reply With Quote
Old 04-03-2014, 02:32 PM   #45
Acree
Acree's Avatar
I've had my tips burn up on my analog Weller station even, and fairly regularly. That's why I recommend a temperature controller station.
Old 04-03-2014, 02:35 PM   #46
Mooseknuckle44
Mooseknuckle44's Avatar
I just noticed the pic in your sig of the gauge cluster.
Is that yours, and your handiwork? Cause that's dead sexy.
Mooseknuckle44 is offline   Reply With Quote
Old 04-03-2014, 03:45 PM   #47
Acree
Acree's Avatar
Thank you! There's a link to my build thread in my signature.
The Following 5 Users Say Thank You to Acree For This Useful Post:
Eski (02-25-2015), mixtape (05-28-2016), Pwolf (04-03-2014), sirisvirus (04-05-2014), texasbound972 (12-12-2015)
Old 04-03-2014, 04:43 PM   #48
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
I just did my HVAC last weekend and am planning on doing something similar to what you have with gauge cluster (white numbers, blue bars, red rev limit, etc). If you don't mind, I may end up shooting you a PM with some questions.
Pwolf is offline   Reply With Quote
The Following User Says Thank You to Pwolf For This Useful Post:
Acree (04-03-2014)
Old 04-04-2014, 06:12 PM   #49
sshole
all this talk about ebay quality caused my fuel gauge LED to die on the way back home.
Old 04-04-2014, 06:18 PM   #50
Mooseknuckle44
That sux. But you do know how to fix it, sooooo. There is that.
2013 FRS-Asphalt-M6-Invidia N1, K&N drop in, plasti dipped emblems, debadged FRS, Spyder II tails, 5000K Bi-xenon HID's, red demon eyes, Quad halo's, switchbacks w/Tapturn mod,Grimmspeed hood struts, led everything exterior, H&R 25mmF/15mmR spacers, Sportlines, SPC LCA's..(FUN car)
Old 04-04-2014, 07:36 PM   #51
sshole
Yup, fixed it in 10 minutes (got distracted by wife being sick).
Old 07-27-2014, 12:50 AM   #52
Pwolf
Pwolf's Avatar
Just finished my conversion this morning
Thanks guys.
The Following 2 Users Say Thank You to Pwolf For This Useful Post:
Acree (08-12-2014), Mooseknuckle44 (07-27-2014)
Old 07-27-2014, 11:45 PM   #53
Mooseknuckle44
I've found blue in the daytime on the clock is nearly impossible to see. Looks awesome at night, but l rarely drive in the dark.
Old 07-30-2014, 04:48 PM   #54
sirisvirus
Drives:
@Pwolf I'm looking to do this was it a hard mod to do? What LEDs did you use?
Sent from my BRZ limited using plastic cup 2.0
Sent from my Subaru BRZ Limited using plastic cup 2.0
sirisvirus is offline   Reply With Quote
Old 08-10-2014, 02:12 AM   #55
Top-Secret
Drives: FRS monogram
Thanks guys.
i need this, what LEDs did you use??
thats my delema right now
Top-Secret is offline   Reply With Quote
Old 08-10-2014, 02:21 AM   #56
Pwolf
Pwolf's Avatar
@sirisvirus as well (sorry for the late response)
Cool White for the gauges from:
http://www.oznium.com/plcc-2
and then Blue for the LCD displays from:
http://lighthouseleds.com/plcc-2-121...-1000-mcd.html
(Probably doesn't matter but the blue ones from Oznium didn't seem bright enough earlier in my LED conversion process so I bought a bunch from Lighthouse LEDs to do finish the interior.)
For the gauges I bought some transparent blue vinyl from Ebay:
http://www.ebay.com/itm/Transparent-...-/370298539724
Had to cut out and stick it to the backside of the insert. That was the hardest part and took the most time.
@Mooseknuckle44, probably depends on what LEDS you're using. I have no problem seeing the clock or the LCDs on my gauge cluster during the day or night. Definitely looks better in the dark though :P
The Following 3 Users Say Thank You to Pwolf For This Useful Post:
Acree (08-12-2014), Mooseknuckle44 (08-10-2014), Top-Secret (08-10-2014)
Gauge Cluster on FRS tonytduc Scion FR-S / Toyota 86 GT86 General Forum 16 07-24-2017 09:56 PM
BRZ cluster gauge swap? InYOHface Cosmetic Modification (Interior/Exterior/Lighting) 31 03-25-2017 06:31 PM
WTB gauge cluster Basti Want-To-Buy Requests 3 04-09-2014 02:54 PM
Gauge cluster mod? kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 8 11-27-2013 10:59 PM
Want to try a gauge cluster experiment with me? stockysnail Northwest 2 04-12-2013 10:57 AM
