Old 03-28-2014, 06:41 PM   #239
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Originally Posted by RacerX View Post
Just out of curiosity how tall are you guys and how far back do you have your driving position?
I'm 5'10 and I have my seat as far back as it will go. When I was first learning to drive stick I'd have the seat about half way back. As soon as I tried a laid-back driving position I instantly improved in smoothness. It will require ALOT more ankle movement to floor the clutch, but I find that anchoring my heel on the floor gave me so much more control and precision. I can still do all the tricks like heel toe just fine.
I think having the seat this far back is not the norm for someone of my height. The few times I've taking it in for service the seat was adjusted so far forward I could bearly get in it. Now when I move my seat forward I can't stand it.
So if you're struggling with clutch control give this a try. It took a day or three to get used to but it helped me out alot.
I'm also 5'10 with size 12 feet (but I have fairly short legs 28" inseam) and when I first got this car, I have to sit a lot closer than I did driving automatic to get good clutch control. As I got better I started to move the seat back a bit so that my right knee wouldn't get tired from all the bending while driving long distances. I find it harder to modulate the clutch if I sit too far back. Also sitting more straight helps with heel and toe too I find.
krayzie is offline   Reply With Quote
Old 03-28-2014, 09:00 PM   #240
ronboogieon
BReeZy Hunter
ronboogieon's Avatar
Drives: 13 DGM BRZ Limited 6MT
It took me a while adjusting seating position to find the perfect distance. At my current seating position, if I push the clutch in all the way my leg is almost stretch out but not quite. I find this position perfect for modulating the clutch. Any other position I feel like I'm too far or too close. I also find that shoes that help you feel the pedals are also good for clutch modulation.
ronboogieon is offline   Reply With Quote
Old 03-29-2014, 12:59 AM   #241
RacerX
Drives: Subaru BRZ
I have a 32" inseem as well. With my seat all the way back, flooring the clutch is about 50% ankle and 50% knee/leg. I don't feel like I'm slouching to reach the pedals and I still have a decent about of bend in my legs. It still requires me to physically lift my ankle off the floor as I move my leg over to the footrest. So it's not a lazy "all ankle" motion where my foot never leaves the ground and I drag it across the floor to the footrest. I commute 80 miles a day to go to school, sometimes in stop and go traffic, so I naturally discovered the easiest and most comfortable way to clutch and shift. Finding the most efficient way of doing something isn't lazy. When you have to do a motion over and over you'll naturally do what takes the least amount of effort. I remember when I first started driving stick my buddy said "I can tell you're new to driving manual because of how your grabbing the shifter". He was right. At first I would grab the shifter like a baseball, now I just kinda nudge it from 3-4 or 5-6 on the side with my finger tips while my arm is resting on the E-break (usually only when I'm tired). Is that lazy? Meh, I don't care. It works for me.
Of course when I am feeling a little more spirited with my driving, I'll adopt the proper way of doing things.
RacerX is offline   Reply With Quote
Old 03-29-2014, 07:39 AM   #242
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
ZZZZZZZZZZZ when is this thread going to end???
BRZfan is offline   Reply With Quote
Old 04-03-2014, 01:34 AM   #243
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Lol damn I'm relearning how to drive a stick pretty much because I'm struggling on first gear. I let off the clutch until i feel it "catching" and then i give it some gas and it goes sometimes its jumpy and all but basically I'm trying to learn how to do first gear a lot faster and quicker, because on a hill start I don't wanna roll back into someone I notice I tend to panic when the car starts to roll back and i kinda give it a little too much gas and i end up launching the car lol I know i'll probably get it down in a couple more days but damn lol its nerve racking on a hill and in stop and go traffic sometimes
Alltezza is offline   Reply With Quote
Old 04-03-2014, 04:00 AM   #244
Ec1990
Drives: '14 BRZ
Give it a little gas, enough to hold 1000 RPM's or so while releasing the clutch.
For hill starts pull up the parking brake a couple notches until you do what's above then release the parking brake as you take off.
Ec1990 is offline   Reply With Quote
Old 04-03-2014, 11:40 AM   #245
Alltezza
Alltezza's Avatar
Alright thanks lol I'll be practicing. I hope nobody sees me stall or fail in this sexy car it would be really embarrassing
Sent from my HTCONE using Tapatalk
Old 04-03-2014, 01:15 PM   #246
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Don't feel bad. I've stalled on a hill in traffic and caused the Tundra behind me to miss the light. He deserved it for consistently riding up on me despite me giving the little "roll back warning"
Also, the handbrake method works for me on bigger inclines. Just remember to release the handbrake as your clutch engages otherwise you're gonna do a mad tyte launch!
Jyn is offline   Reply With Quote
The Following User Says Thank You to Jyn For This Useful Post:
SirBrass (04-03-2014)
Old 04-03-2014, 01:31 PM   #247
newports
Drives: 2013 Scion FRS
5 star thread. This is awesome since I'm new to stick.
newports is offline   Reply With Quote
Old 04-03-2014, 01:58 PM   #248
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
Originally Posted by extrashaky View Post
As I was driving home today, it occurred to me that the clutch pedal is actually designed for using your entire leg. Think about the gas pedal. It's set so that it's easy to rest your heel on the floor and flex your ankle. The brake pedal is designed for intermittent use, so it's higher up and levered in such a way that you get the best use of it by lifting your leg off the floor.
If the clutch were intended to be used like a gas pedal, why is it designed just like the brake pedal? This topic got started when someone mentioned not being able to leave his heel on the floor when using the clutch. Maybe that should tell us something.
In normal driving, I keep my right heel on the floor to use the gas and brake pedal. In fact, my heel doesn't move at all. It just pivots to use the gas and then pivots over to use the brake. When I need more force, that is when the heel lifts off and my large leg muscles push through. But in terms of speed of getting to the brake pedal, nothing is faster than the pivot.
Panic braking/heel toe is another matter entirely though. I lift my heel and use my leg to push through.
So you can see the way I use the gas/brake carries over to how I use the clutch.
subiestyle is offline   Reply With Quote
Old 04-03-2014, 02:39 PM   #249
chas3wba0
chas3wba0's Avatar
Drives: Yes
Best advice I ever got and will pass along to you is this: stop looking at the tach for a while and just go by FEEL and SOUND. You should be able to gauge how much clutch/throttle to give as well when to shift and what gear to shift to solely based on those 2 senses
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 04-03-2014, 02:41 PM   #250
Alltezza
Alltezza's Avatar
Thanks lol yeah I noticed I'm always looking at the tach lol and by the way I have stalled a couple times and there are some times where I revved pretty high at like 4k or 5k and she's still in the process of being broken in. Is she going to be okay or did I mess up the car and my clutch?
Old 04-03-2014, 02:58 PM   #251
chas3wba0
chas3wba0's Avatar
Drives: Yes
How many miles are you at? And don't worry about revving to 5k, it's not gonna mess anything up. Especially if everything was warmed up already
And the clutch is made to handle that to an extent... you may have just shortened its lifespan by a few miles, no big deal
Old 04-03-2014, 03:00 PM   #252
Alltezza
Alltezza's Avatar
Oh okay a buddy of mine with a sti was telling me I need to be careful and not burn the clutch and shit but yeah appreciate the feedback
And I'm at like 100 miles
Best place to learn how to drive my car Pneub Southern California 1 06-07-2013 03:54 PM
what did you learn to drive on? 7thgear Off-Topic Lounge [WARNING: NO POLITICS] 31 08-10-2012 10:39 PM
Where to learn how to drive manual.... Saibot CANADA 12 03-13-2012 06:28 PM
Who needs to learn how to drive... RRnold Other Vehicles & General Automotive Discussions 14 08-27-2011 12:15 AM
Learn to Drive MtnDrvr86 Other Vehicles & General Automotive Discussions 102 03-14-2010 08:46 AM
