Old 04-02-2014, 03:05 PM   #15
celica73
Non-US 86's have smaller non-vented rotors as the standard part, it looks like those come in about 1.5 lbs lighter per rotor.
Old 04-02-2014, 03:15 PM   #16
CSG David
CSG David's Avatar
WRX rear.
Old 04-03-2014, 12:35 AM   #17
Poodles
Drives: 2015 Series.Blue
Aluminum hat with a working e-brake does exist for other applications (bolt in and replaceable steel liner).
I could bug him and see if he's interested in this platform...
Old 04-03-2014, 02:20 AM   #18
DAEMANO
Time Traveller
Racing Brake might just have it
Paging @RB Performance Brakes
These guys might sell you just the rear rotors. They do offer a full kit here:
https://www.racingbrake.com/ProductD...ductCode=2315K
Rotor Design:
These two-piece REAR rotors are made with the latest technology that is exclusive to RB. The rotor hats are constructed of aluminum with an iron sleeve insert. This allows significant weight savings, while still preserving the use of the stock emergency brake. This design is only available through RB!
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
himbo (04-04-2014), RB Performance Brakes (04-10-2014)
Old 04-04-2014, 07:11 AM   #19
himbo
Drives: Lightening Red BRZ Ltd.
Rotor Design:
This looks great! I'm gonna reach out to them and see if there's anyway they could do a stock sized rotor. Maybe err can do a group buy if we get enough people.
himbo is offline   Reply With Quote
Old 04-07-2014, 12:54 AM   #20
Poodles
Not exclusive at all
Hell, those other ones I posted where developed years ago... Might have to inform him.
Old 04-07-2014, 01:22 AM   #21
diss7
Drives: AE86, 2x GT86, TE27
If taking that serious, then why need e-brake?
I was going to run custom rear brakes and dual caliper with hydro handbrake, but the drum hand brake is so good, do not need to change
diss7 is offline   Reply With Quote
Old 04-07-2014, 03:04 AM   #22
Poodles
E-brake is required to pass inspection. Dual calipers likely adds more unsprung weight. Hydro handbrake is only used for drifting, it's NEVER a replacement for parking brake as locking the system like that for extended periods will damage components and isn't reliable enough.
The Following User Says Thank You to Poodles For This Useful Post:
Tristor (10-15-2018)
Old 04-07-2014, 03:41 AM   #23
diss7
Leave car in gear. Same effect as handbrake
Old 04-08-2014, 01:40 AM   #24
Poodles
No, as even a gentle slope is enough to rotate the engine. You can rotate the engine by hand, what makes you think the entire weight of the car can't do it?
Old 04-08-2014, 01:49 AM   #25
diss7
Lol.
Old 04-08-2014, 07:14 PM   #26
mike156
Drives: EVO
The transmission, rear diff and something called torque multiplication?
If the engine has about 50 ft-lbs of compression/friction at the crank, that's over 700ft-lbs at the wheels. That's a 15* slope, or roughly a 30% grade...
That said, there are lots of times you'll want the engine running but the car to not go any where. Sitting in Grid, warming up the engine in the morning, in a drive through, etc.
It's a PITA to not have an ebrake but an aluminum hat could easily handle these needs.
mike156 is offline   Reply With Quote
Old 04-09-2014, 02:50 PM   #27
Poodles
Takes far less than that to rotate the engine, and the resistance isn't constant. If someone bumps the car and gets it over the hump of compression, the car will easily keep moving. Unlike using the parking brake which unless the cable breaks (unlikely) won't have this issue.
It's also illegal damn near everywhere to park in this manner as well.
Old 04-09-2014, 06:59 PM   #28
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
You could always chock a wheel. I had to do that every time I got of my truck in the Air Force. I think there could be a decent market for the rb rotor setup in the rear. I wonder how much weight it would save though?
industrial is offline   Reply With Quote
P&L STI Lightweight rear brake kit diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 57 05-31-2017 08:26 PM
Was tapped on rear bumper, options? drewbot CANADA 9 10-25-2013 12:13 PM
Aftermarket options for fixing up rear fender body edocura Cosmetic Modification (Interior/Exterior/Lighting) 1 08-13-2013 06:20 PM
Got rear ended on Saturday night. What are my options? Demotic Scion FR-S / Toyota 86 GT86 General Forum 25 07-16-2013 05:36 PM
Rear camber adjustment options? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 09-12-2012 10:46 AM
