Old 04-01-2014, 10:30 PM   #1
frslee
Just drive it
Drives: 13' FR-S
Borla UEL Header noise?
Hi Guys,
Today I installed the Borla UEL headers. Install was straight forward without any major issues. After installing, I am hearing this noise in the passenger cabin when I press the gas pedal at low rpm. Is this an exhaust leak where the header meets overpipe? It's the faint thin noise that's behind the rumble noise.
Any advice would be welcome, Thank you.
[ame="https://www.youtube.com/watch?v=BzweGYpU3Eo"]https://www.youtube.com/watch?v=BzweGYpU3Eo[/ame]
frslee is offline   Reply With Quote
Old 04-01-2014, 11:30 PM   #2
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
I would say that's rasp from the front pipe. Mine was terrible after the Borla install until I wrapped the front pipe.
Car is gone - parts for sale
6speed_Sam is offline   Reply With Quote
Old 04-01-2014, 11:33 PM   #3
frslee
Just drive it
Drives: 13' FR-S
What did you use to wrap the front pipe? Just exhaust wrap?
Old 04-02-2014, 12:32 AM   #4
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
Wrap then thin sheets of aluminum wrapped around from Lowes held on with hose clamps. It's the only way to get the rasp down
Old 04-02-2014, 12:49 AM   #5
Squido3J
Squido3J's Avatar
Drives: Scion FRS
This is the exact same problem i am having!!!
Where you able to fix it??
Squido3J is offline   Reply With Quote
Old 04-02-2014, 01:03 AM   #6
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
I got my rasp to completely go away
Old 04-02-2014, 01:05 AM   #7
Squido3J
Squido3J's Avatar
Drives: Scion FRS
Please share your almighty secret!! it's usually over 3k 4k rpm and it sounds like crickets are having sex inside my headers. kinda obnoxious
Old 04-02-2014, 01:25 AM   #8
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
My rasp came from my front pipe...though it is also catless, which can add to the noise. I wrapped my front pipe with header wrap, then cut and used thin sheets of aluminum from lowes and wrapped the header wrap. I basically made a double layer of insulation.
Please excuse the simple drawing..hope it gets the point across. I wrapped everything I could.
Old 04-02-2014, 01:39 AM   #9
Squido3J
Squido3J's Avatar
Drives: Scion FRS
Wrapped your entire front pipe with the header wrap and foil?!
even the cat?
Old 04-02-2014, 07:55 AM   #10
frslee
Just drive it
Drives: 13' FR-S
oh by the way, the setup is very simple.
Borla UEL
Invidia Q300 Catback
Stock overpipe, front pipe.
Old 04-02-2014, 09:02 AM   #11
Gt86_nick
Drives: Scion FRS asphalt
That's the exact noise that's been driving me insane! So heat wrap will do the trick??
Gt86_nick is offline   Reply With Quote
Old 04-02-2014, 01:21 PM   #12
6speed_Sam
Thumper
6speed_Sam's Avatar
Drives: 2013 FRS
even the cat?
I wrapped the whole front pipe but I do not have a cat. it's sheet aluminum not aluminum foil
Old 04-02-2014, 01:26 PM   #13
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
Do you hear a ticking noise when on the throttle? If so, it is most likely a leak.
IAmNotTheDriftKing is offline   Reply With Quote
Old 04-02-2014, 01:39 PM   #14
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
Dont forget that you changed the header to a much thinner stainless steal piping replacing the stock thick flanged cast manifold. You are going to hear more noise coming from the header itself.
lickitysplit is offline   Reply With Quote
Borla Header Rattle Noise tonytduc Issues | Warranty | Recalls / TSB 40 05-09-2014 01:28 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
FS Borla UEL header. Sgt.Beardface Engine, Exhaust, Bolt-Ons 22 03-17-2014 08:16 PM
Borla UEL Header - CEL FIX SpectreRT Engine, Exhaust, Transmission 14 01-30-2014 05:15 PM
WTB: Borla UEL header 86TruenoFRS Engine, Exhaust, Bolt-Ons 0 01-18-2014 10:32 AM
