#575 |
Drives: 2013 FRS hot lava
Question about Winjet Headlights
For you guys worried about fogging...some fogging during the first few days after installation is normal. If you do choose to bake the headlights to take them apart...about 200 deg for 8 min should do the trick. Get the 3m window weld to use for the new sealant (works better than silicon sealants). The 3m window weld has never leaked with my projects. For the guys wanting hids for their winjets...just get a set of hid bulbs and don't bother with a retrofit. Ive done retrofits before and believe it or not my winjets have great light output, aim and cutoff with hids and no retrofit.
#577 |
Drives: Ultramarine toyobaru
Hey @Midarete what did you do to make your LED light up with the projectors? Or is the shot taken with the high beams?
#578 | |
Drives: Whiteout FRS
#579 | |
Drives: The silvertrooper 10 series
We tested these - they are bright but not bright enough to blind anyone If needed we will work on a Dimmed design - and one specific for 10 series and Monograms |
#580 |
Thought they dimmed them, if the mod doesn't dim them then would it be problematic to drive with the highbeams on?
#581 |
Drives: 2013 Scion FR-S 6 MT Raven
I can't find that DRL mod
#582 |
| The Following User Says Thank You to 86SPEED For This Useful Post: | Midarete (04-02-2014) |
#583 |
#584 | |
We have tested about 5-6 different bulbs and found that some compare well while others compare above and beyond - There is a major light output difference in all the Retrofits we have done also - I have watched Thomas "tune them" to get a good crisp light output @Gixxersixxerman |
#585 |
So the correct HID setup for these is H7?
#586 | |
Drives: 2013 Scion FR-S Raven
Output Photos Please of the cutoff, real curious as to the cutoff These are D2S projectors at 25 feet, how do yours compare?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
| The Following User Says Thank You to tonystewart For This Useful Post: | 86SPEED (04-02-2014) |
#587 |
#588 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I'll post up what we did here in the shop
Stock winjet bulb and projector ![]() Stock winjet projector with upgraded Morimoto XB35 5K bulb ![]() Retrofitted Mini D2S projector running upgraded Morimoto XB35 D2S bulb ![]() As you can see the stock projector doesn't come close to a retrofitted one. These are cheap Q5R replicas or knockoffs, while better then a OEM projector in the cars, and a lot better once they have a hid kit installed in them, they just don't come close to a retrofitted set.. I'll put my retrofitted setup against the shops 10 Series stock HID setup and know mine is better. I have "tuned" my set up and I run 185$ Osram 66240 CBI bulbs.. And Bulbs make a big difference.. Anyone that says a cheap 30$ kit bulb is the same as a quality ORM bulb or even the XB35 bulbs with the handmade German capsules don't know anything.. If your wanting the most out of your lights, then doing a retrofit is the way to go.. |
| Winjet Headlights and HIDs | HakunaMiata | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 07-18-2017 10:24 PM |
| New Winjet Headlights LED FLICKER?! | Jeremehh | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 03-08-2016 03:26 PM |
| Winjet headlights fogging up? | Frs32907 | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 05-17-2014 01:26 PM |
| Has anyone modified the winjet headlights to keep led's on? | 86black | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-24-2014 12:42 AM |
| Custom Purple Winjet and Black Winjet Headlights | xclusive_brett | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 12-17-2013 08:28 AM |
