Old 04-01-2014, 06:13 PM   #1233
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
I've only run the current SD tune. Currently using a 3 bar MAP sensor, gtx2867, and 2.5" DP back exhaust. Car hasn't been jerky in low RPMs. Granted, I have to use the throttle differently than if it was NA, but that's to be expected, no?
OjiGeorge is offline   Reply With Quote
Old 04-01-2014, 06:29 PM   #1234
pmccut
Drives: Blue Subarus
I expect a little different, but I don't have any logic to support that. Mine felt like I was part of a rodeo below 3k. I'll have to try out SD magic soon.
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
Old 04-01-2014, 07:10 PM   #1235
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Probably due to the poorly designed MAP location on the Innovate superchargers that is causing the OMNI MAP sensors to give strange readings. As @jamesm mentioned, I have no worries using them in the OEM intake manifold.
No. We have had failures for YEARS. Starting with other Subies. The Omni 4 BAR MAP sensor in our track LGT lasted 1 session last year (we tried Omni again to see if they were any better yet), back to AEM. On other cars Bill prefers the AEM MAP sensor. It is the same unit used by Motec in their systems. For the FRS/BRZ we have been working to find the best plug and play solution. The Denso sensors are very accurate and reliable. We will be testing a new Denso sensor this week. ETA for its arrival is tomorrow. We will be testing it on the prototype MAP turbo kit installed in an FRS sitting at my shop now.
Infamous Performance is offline   Reply With Quote
Old 04-01-2014, 07:11 PM   #1236
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Please take good care of her
Sent from my IBrick
Old 04-01-2014, 07:16 PM   #1237
Your heads were fine. Deck is flat. Not sure if head torque (and torque procedure) was correct on prior assembly. These heads require a far different torque procedure than EJ20/EJ25. Gasket appears to have been blown through by over boost. But heads could have lifted too.
I am assembling the motor now. I should have it all buttoned up (on the stand) tonight/tomorrow. Might have the engine and turbo kit back in the car this weekend. If not I have a full day open specifically for your car next week. I might be able to squeeze you into Bills tuning schedule next week too.
The Following User Says Thank You to Infamous Performance For This Useful Post:
pmccut (04-01-2014)
Old 04-01-2014, 07:17 PM   #1238
Sent from my IBrick
We will sir. We will. Lol.
Old 04-01-2014, 08:23 PM   #1239
pmccut
Thanks Mike. I'll definitely be making a separate thread about the head gasket failure. Not sure if you were able to get any photos to post up as well.
Super stoked to finally get the headers/DP ceramic coated. Should've done that from the beginning.
Old 04-02-2014, 03:16 PM   #1240
Dipstik-sportech
Dipstik-sportech's Avatar
My headgaskets are fine and mine is the first one they built so if any one would've messed up it should've been mine, so it's not the torque and or the procedure
The Frozen North
Old 04-02-2014, 03:39 PM   #1241
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We have built many of them and are aware of the torque sequence/procedure. Over boosting or too much timing is usually the cause.
FullBlown is offline   Reply With Quote
Old 04-02-2014, 03:58 PM   #1242
pmccut
The Frozen North
We certainly don't know anything for sure. I drove the car 2,100 miles from Minnesota to California on a 15psi 91 octane tune. When I got home I noticed coolant levels were low, filled it up and didn't think much of it. A couple weeks later I noticed it was low again, and there was a bunch of oil all over the engine bay. It's not even close to being my daily driver, so the majority of the miles put on it were on 'fun' roads where it would run a bit hot so I figured some coolant had boiled off. I could easily move the oil filter with my hand, so I figured it was leaking out of there. I cleaned up the oil around the filter and tightened it back down.
I switched it to E85 and ramped up the boost over a few tanks to 22psi (I believe it was tuned for 24 psi, but I never felt the need to crank the MBC up any further lol). I switched off of the E85 tune after a few weeks. There were some big rough spots in the tune where there was major power loss at specific RPMs (4.5k I believe), and cold+warm starting was really bad. It was fairly consistently a 3 attempt start, even when warm. I got tired of this really quick and had a track day coming up so I switched back to 91 and back to 15psi. I did an oil change days before the track day, with redline 10w30 (I saw FullBlown mention they use this on their engine builds). I filled up a blackstone labs bottle but never sent off the oil to get checked, I should send that in and see if there were any signs of coolant prior to the track day.
The track day went fairly poor. About 2 laps in you'd see the coolant temp go to about 3/4 on the dial. I'd have to do a parade lap to cool it down, then another 2 laps before stopping. I ended the day early as it just wasn't any fun babying it.
I talked to LJ and as always, he does something unexpected and sent me the SPAL fans + shrouding he was working on for free so I could try it out I installed the fans and noticed the oil leak was worse than expected, oil was absolutely everywhere inside the engine bay. Not fun scraping it off the bumper. I had a few friends from ft86 come over to help install the radiator shrouding and fans. Most of the time was spent cleaning up oil lol. We bled the coolant system and the the levels didn't fluctuate enough for me to notice (I filled when cool, but always checked when hot so I can't be sure).
I never switched back to the E85 tune, so I don't really understand how 15 psi caused this issue.
I drove it down to @Infamous Performance to swap GT2871R -> GTX3076R, Perrin 2.5 OP + FP. Shortly after @DeliciousTuning started working on it he noticed something was wrong with the car. He never took the car into boost, but the guys at the shop could tell there was a smell of coolant from the exhaust and the coolant in the overflow tank was expanding. FML.
I'll make a full write-up once I have the car back, with dates and whatever pictures I can get. I'll go send in the blackstone labs oil container that has been sitting on my counter for months. That should hopefully tell me how long the problem had been going on for.
Old 04-02-2014, 04:00 PM   #1243
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Another happy customer
Stock Motor
Automatic Transmission
FBM Stage 1 Base kit with gtx28 upgrade
FBM 3" Dual Exhaust
FBM Radiator and shroud
FBM 93 Pump gas Custom tune with Ecutek
The Following User Says Thank You to FullBlown For This Useful Post:
Dipstik-sportech (04-02-2014)
Old 04-02-2014, 04:09 PM   #1244
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Stock Motor
FBM 3" Dual Exhaust
Looks like and reminds me of my car. I miss her.
ftc~brz (04-02-2014)
Old 04-02-2014, 04:11 PM   #1245
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Loook... TQ reading
Old 04-02-2014, 04:36 PM   #1246
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Loook... TQ reading
I'm sold on the gtx28 with stock compression. I specifically chose it over the 30 and made some serious tq as well. Much more than a gtx30 tuned by the same tuner.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following User Says Thank You to Reaper For This Useful Post:
FullBlown (04-02-2014)
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
