Old 03-29-2014, 04:25 PM   #85
lamptaco
Drives: 2014 BRZ
Hey everyone just to be clear. If I order a set of 18x9.5 +38 square what will daily driving be like? I have a set of BC coils and will set them low. What am I going to have to do in order to drive them without rubbing? Do I need to purchase camber bolts/rear LCAs/ect? Asking all this because I drive ALOT. Is the camber going to have to be massive?
lamptaco is offline   Reply With Quote
Old 03-29-2014, 04:55 PM   #86
raytrix
Drives: Series 10 FR-S
17x9 +35 Mag Blue finish on Z2 tires 235/40R17
raytrix is offline   Reply With Quote
The Following 9 Users Say Thank You to raytrix For This Useful Post:
alpine (07-31-2014), Bimble Bamble (09-01-2015), fooddude (03-29-2014), humanshield (04-17-2014), jliongh (10-15-2019), korhun (06-16-2019), P@ul (05-05-2014), pcuerpo (06-05-2016), TylerLieberman (04-05-2014)
Old 03-29-2014, 05:04 PM   #87
loogs
Drives: on cruise control
WHERE DID YOU GET THOSE!
loogs is offline   Reply With Quote
Old 03-29-2014, 10:03 PM   #88
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
sexy as fuck
Scalzo is offline   Reply With Quote
Old 03-30-2014, 11:35 PM   #89
MooseRS
Drives: 2013 FRS ashpalt 6MT
17 x 8 Eibach sport springs stock Bridgestone tires
MooseRS is offline   Reply With Quote
The Following 3 Users Say Thank You to MooseRS For This Useful Post:
brz7400 (04-01-2014), hattrickey (03-31-2014), SkAsphalt (04-21-2014)
Old 03-31-2014, 12:25 AM   #90
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
A few crappy phone pics of the car after the Eibach Pro springs and camber bolts were fitted.
Wise is offline   Reply With Quote
The Following User Says Thank You to Wise For This Useful Post:
fooddude (03-31-2014)
Old 03-31-2014, 12:34 AM   #91
mtblackfrs
mtblackfrs's Avatar
Drives: 2014 black Scion FR-S
Question for you guys.. I'm purchasing the Eibach Sportline for 1.4" drop and still debating if I should get a 17's or 18's.. I just want it to look decent since this is gonna be my daily. But if I can close the wheel gap, then it'll look alog better. But the thing is I don't want to ruin my mpg..
So 17X9 or 18X8.5/18X9.5 ?
mtblackfrs is offline   Reply With Quote
Old 03-31-2014, 11:44 PM   #92
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
How much are you guys paying for these?
tigermack is offline   Reply With Quote
Old 04-01-2014, 05:31 PM   #93
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
Really looking forward to bolt these on to my white BRZ.
Hopefully the 245/40r17 PSS tires will arrive shortly.
17x9 et35
Andreas83 is offline   Reply With Quote
Old 04-01-2014, 05:33 PM   #94
eyedeez
eyedeez's Avatar
Drives: 2014 Firestorm FR-S 6MT
17x9 et35
I'm considering PSS' for my rpf1's. Do you have any previous experience with those tires?
eyedeez is offline   Reply With Quote
Old 04-06-2014, 12:49 AM   #95
Scion
Drives: Scion tc
17x9 35
245/40
Scion is offline   Reply With Quote
The Following 3 Users Say Thank You to Scion For This Useful Post:
adprokid (07-19-2014), fooddude (04-06-2014), VuDism (04-19-2014)
Old 04-06-2014, 01:41 AM   #96
N_A
Drives: 2013 Raven
Originally Posted by Scion View Post
17x9 35
245/40
What are you lowered on? and what camber are you running?
N_A is offline   Reply With Quote
Old 04-06-2014, 01:15 PM   #97
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
17x9 +20 up front. 17x9 +30 rear.
215/45 Federals.
-3 camber/-1.7 camber. (f/r)
Lowered on Stance Coilovers and LCAs.
Going to switch to 215/40s up front and add some RacerX toe links and go to -1.5 rear camber. Also adding MAX subframe and diff risers. Probably going to lower another 5-10mm when it's all done.
Old 04-07-2014, 03:44 PM   #98
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Wanting to know....
Does anyone have (or have pics) of 16" RPF1's on their car??? Preferably, low-offset and similar flat/concave spokes like on the 17x9et35 (I don't really like the convex/bubble-out spokes of slim and high offset RPF1s)
fooddude is offline   Reply With Quote
The Following User Says Thank You to fooddude For This Useful Post:
Trettiosjuan (04-07-2014)
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 04:50 PM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 12:34 PM
Enkei RPF1 17x7.5 +48 5x100 SBC and wheel/tyre question Victor Draken Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-19-2013 02:28 PM
Track wheel Enkei RPF1 in 16" ?? stockysnail Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-07-2013 10:13 AM
