Old 03-31-2014, 04:29 PM   #4103
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by xjohnx View Post
I just pushed with moderate pressure, it squeezed through.
The Following 3 Users Say Thank You to Calum For This Useful Post:
chanomatik (04-01-2014), Dimman (03-31-2014), xjohnx (03-31-2014)
Old 03-31-2014, 04:33 PM   #4104
Calum
That Guy
Originally Posted by Decay107 View Post
Quick question for all you guys who also have it installed. How exactly are you determining the presence of exhaust leaks at the head to header connection?
I, like many of you, installed, tightened to factory spec, and got that really loud ticking/blowing sound on startup. I re-tightened to 31ft/lbs (still less than a lot of people are tightening to) and the noise happened again but then went away after the initial warm up cycle. I have since started it cold several times and have yet to hear a re-occurrence. Now I'm a bit paranoid because yesterday, I found a leak between the header and overpipe that only presented itself when I revved the engine.
http://www.princessauto.com/pal/en/D...cope/8006622.p
The Following 2 Users Say Thank You to Calum For This Useful Post:
Decay107 (03-31-2014), wparsons (03-31-2014)
Old 03-31-2014, 06:12 PM   #4105
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
Everyone that is talking about leaks, you should know that after a few heat cycles you should retighten all the bolts as the tend to loosen as the header contracts and expands. Also try some RTV. Finally check the gaskets and the flange to make sure they are pretty flat. I am going to go back to the OEM gasket as they are still leaking after tightening them again, but this time with some RTV sealant!
Headers are a pretty common place for leaks, it just takes a bit more effort but it isn't too difficult.
IAmNotTheDriftKing is offline   Reply With Quote
Old 03-31-2014, 07:08 PM   #4106
xwd
Ugh you should never have to use something like RTV...
I would agree this motor seems to have a lot of header fitment issues but that's soley on the people producing the headers... The P&L header I have needed to have the part that connects to the overpipe modified because it would cause the overpipe to hit the frame. They replaced or modified everyone's pipes and now no issues. The flanges on my P&L are perfect though, I could probably torque them to 5ft-lbs and they wouldn't leak.
The Following 3 Users Say Thank You to xwd For This Useful Post:
Sportsguy83 (04-01-2014), wparsons (04-01-2014), yomny (04-01-2014)
Old 03-31-2014, 08:19 PM   #4107
Callahan
No leaks so far with the double gaskets, not sure which way they are oriented. One set is grimmspeed, the other subaru. Not a perfect install but i am very happy with the performance and sound. I would love for the flanges to meet up flush but maybe thats unrealistic for welded parts that can move during fabrication. That being said, I would buy this header again.
Callahan is offline   Reply With Quote
Old 03-31-2014, 09:26 PM   #4108
Sargy
Long Distance Driver
Sargy's Avatar
Taking mine to a shop tomorrow as I wont have much time over the weekends to look this over. I should have a pretty good answer tomorrow or the next day
Sargy is offline   Reply With Quote
Old 03-31-2014, 11:12 PM   #4109
OrbitalEllipses
Drives: Attitude
A true dual manifold might not make power?
Old 04-01-2014, 10:31 AM   #4110
mad_sb
Drives: 2013 Asphalt FR-S
Anyone else had a chance to dyno and or get a tune yet?
I've been tied up on my 2nd gen 4runner project but that motor is torn down now and headed to the machine shop today so I may have a couple weeks of wait time on my hands now....
The Following User Says Thank You to mad_sb For This Useful Post:
FrsDuke (04-01-2014)
Old 04-01-2014, 01:05 PM   #4111
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Originally Posted by FrsDuke View Post
From behind with a small flathead. Two barbs need to be pressed flat. Do the top and rock the clip down. Then do the bottom and out it comes. Maybe it was left and right not top and bottom but same idea.
Originally Posted by toeout View Post
The clips that were directly in the block I just pried out with a small flathead. The other 2 that were in the small brackets, I first unbolted the brackets, then used pliers to press the clips together and out, from the backside of the brackets.
I was able to remove the grey clip from the bracket and take off the two small clips from the side with a flat head. Can't remove the damn grey clip. What's the trick to this?
Carlitoz3 is offline   Reply With Quote
The Following User Says Thank You to Carlitoz3 For This Useful Post:
jamesm (04-03-2014)
Old 04-01-2014, 01:39 PM   #4112
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Um the 02 plugs?
leave them connected to the bracket and it is either a puch down on the tab and pull off or a pull up on the tab and pull off. the main plug on the harness side should stay connected to the bracket though.
2superblus is offline   Reply With Quote
The Following User Says Thank You to 2superblus For This Useful Post:
Carlitoz3 (04-01-2014)
Old 04-01-2014, 01:47 PM   #4113
Carlitoz3
Carlitoz3's Avatar
Originally Posted by 2superblus View Post
Um the 02 plugs?
Push down. Thank you!
Old 04-01-2014, 02:34 PM   #4114
Sargy
Sargy's Avatar
No leaks from the header flange, my ears need to be checked
It was the Overpipe-Frontpipe Gasket
Also applied Gold Reflective tape under the TRD Intake. No april fools joke about that part. Use protection!
The Following User Says Thank You to Sargy For This Useful Post:
Old 04-01-2014, 02:41 PM   #4115
toeout
So what gaskets did you use?
toeout is offline   Reply With Quote
Old 04-01-2014, 05:29 PM   #4116
Carlitoz3
Carlitoz3's Avatar
Another quick question.
What will make my go by smoother?
Putting on the headers or op/fp first?
Thanks.
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
