Old 03-31-2014, 03:59 PM   #15
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
Originally Posted by Ocean-Grown 86 View Post
Is it just me or does this design look identical to the stock headers, which are 4-2-1 barely unequal
I believe this should be the equal length.
h4nh is offline   Reply With Quote
Old 03-31-2014, 04:10 PM   #16
frslee
Just drive it
Drives: 13' FR-S
Yep, no idea where the UEL came from. You sure you looked into parts before they told you it's UEL? The car definitely sounds it has more flow, but like other member said... it does exactly look like the stock header with less restricted catalytic converter. I remember seeing a stock header with heatshield removed and I can still remember it's almost identical to these aftermarket sub $500 or whatever headers.
If you can post dynos, that would be the best way to prove the increased power!
frslee is offline   Reply With Quote
The Following 2 Users Say Thank You to frslee For This Useful Post:
ATL BRZ (03-31-2014), ramiram1984 (05-24-2014)
Old 03-31-2014, 04:37 PM   #17
Hotlava86
Hotlava86's Avatar
Drives: 2013 Hot lava Fr-s, 2007 Mazda 3
I have an appointment to get a Dyno run later this month, there is only one shop that is open on the weekend here where i live..
Raising the bar one step at a time!
Kansas City FR-S/BRZ Facebook group. https://www.facebook.com/groups/452909128083343/
Hotlava86's Build thread!http://www.ft86club.com/forums/showthread.php?t=14152
Hotlava86 is offline   Reply With Quote
Old 03-31-2014, 10:20 PM   #18
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
excited to see the results!
malubawla is offline   Reply With Quote
Old 04-01-2014, 03:55 AM   #19
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Originally Posted by calmtigers View Post
do you know the diameter of the piping on the header?
They are the exact same inner diameter as the stock runners. The only difference is that the inner diameter coming out of the high flow is a 1/2in bigger
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 04-01-2014, 07:38 AM   #20
mid_life_crisis
Drives: FR-S 10 #103 AT
So it has a cat that is half as dense as stock with a 1/2 inch larger outlet?
That should be an improvement, but by how much?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 04-01-2014, 07:45 AM   #21
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I wouldn't order this if my life depended on it. The fitment of the dual canister Top Speed Catback was atrocious. Plus they lie about the piping diameter. This company is a joke.
Old 04-01-2014, 08:24 AM   #22
diirk
diirk's Avatar
Drives: 4Runner
Well, I'm pretty curious what the length of the runners is compared to stock. And would love to see the dyno results.
I do have a Top Speed Cat Back and fitment was nearly perfect. I probably need to adjust one hangar a tiny bit for it to sit perfectly. But I'm the only one that has noticed the imperfection. Everyone else just compliments the exhaust.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 04-01-2014, 09:56 AM   #23
jblmr2
jblmr2's Avatar
I have a complete TopSpeed exhaust system on my MR2 Spyder. Workmanship is decent. Fitment wasn't the greatest, it required quite a bit of tweaking. The header itself is essentially a tubular copy of the stock cast manifold. Any power gain is probably the result of the elimination of the precats and the utilization of a high flow main cat, not system design. As with the header on the Spyder, I'm sure this will not pass California emissions requirements if that's a concern. Any advantage this offers will be price, I woundn't expect to see performance gains of the magnitude offered by more expensive units. Hope I'm wrong!
jblmr2 is offline   Reply With Quote
Old 04-01-2014, 10:00 AM   #24
BlueDubbinTDI
Which catback? My dual canister was literally sitting against the rear axel and wouldnt connect to the stock front pipe, tips we SOOOO off and nearly all the exhaust gas runs out the right side. Stay away from this company.
Old 04-01-2014, 10:08 AM   #25
diirk
diirk's Avatar
Drives: 4Runner
I have the single canister dual exhaust. Pretty much the OEM design.
diirk
Old 04-01-2014, 10:22 AM   #26
BlueDubbinTDI
Burnt tip? Probably the 1 i shoulda gotten. Is it even a noticeable sound level though?
Old 04-01-2014, 10:26 AM   #27
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
so guys... I'm on the fence with purchasing the cat-back and the header...
can someone tell me if I will have fitment issues with either one... seems to be mixed reviews.
sissupr is offline   Reply With Quote
Old 04-01-2014, 10:38 AM   #28
diirk
diirk's Avatar
Drives: 4Runner
Yeah. It's the burnt tip one mentioned here: http://www.ft86club.com/forums/showthread.php?t=53599
The sound level is close to stock except when WOT.
diirk
Catted Headers EN2_Squirrel Engine, Exhaust, Transmission 53 12-16-2016 09:52 PM
Long tube catted headers possible? wparsons Engine, Exhaust, Transmission 6 01-31-2014 09:56 AM
So any chance for catted UEL Headers? Flasher Engine, Exhaust, Transmission 20 07-01-2013 11:51 AM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 12:29 PM
