Old 02-23-2014, 10:38 PM   #29
JerryMichaels7
Drives: Whiteout FRS
What are you guys using for catchcans?
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 02-24-2014, 08:03 AM   #30
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Originally Posted by ptuning View Post
Nice video...even better bottle of Patrón by the computer 👍👍...quality in everything you guys do.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following 3 Users Say Thank You to ecko04 For This Useful Post:
kanundrum (02-24-2014), Mrc@ptuning (02-24-2014), SnapOv3st3r (02-24-2014)
Old 02-24-2014, 09:00 AM   #31
NickFRS
Drives: 2013 Asphalt FRS
Originally Posted by slicktop View Post
Good work guys. Advancing the platform is really coming along fast. I think daily 400whp is easily sustainable for the long haul (5+ years) IMO.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 03-01-2014, 12:57 AM   #32
kanundrum
Drives: 2013 Whiteout FR-S
hmmm heard it in person yesterday, sounds so mean
Old 03-31-2014, 07:59 PM   #33
JerryMichaels7
@ptuning any updates with your other products to support this
Old 03-31-2014, 08:06 PM   #34
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
torque curve, which is all that really matters in the end.
Why is it that the tq curve matters more than the hp curve? Everyone keeps saying a flat tq line is optimal...why?
Old 03-31-2014, 08:13 PM   #35
sw20kosh
Drives: 2013 Black FR-S
The torque curve shows you what you will actually feel when you accelerate. A flat torque curve means you get a constant amount of thrust as you sweep through the rpm range. This is more desirable because it makes the acceleration predictable at any rpm point and doesn't unsettle the car as much as a peaky curve would. It also makes it feel like the motor wants to rev beyond redline instead of feeling exhausted before redline.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
Hicklinc (02-04-2018), ptuning (03-31-2014)
Old 03-31-2014, 08:16 PM   #36
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
So why is it that torquey cars are more desirable? Is it that the actual tq of the engine is what dictates the amount of acceleration? someone told me a while back that tq determines how fast you get to your top speed, and hp determines the top speed.
Idk if that's right or wrong, or whatever lol
Old 03-31-2014, 08:17 PM   #37
CSG Mike
CSG Mike's Avatar
I have an odd question. Do you guys have plans to do anything with a smaller turbo with a wider powerband and faster transient response?
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
cdrazic93 (03-31-2014), Hicklinc (02-04-2018), OICU812 (03-31-2014)
Old 03-31-2014, 08:55 PM   #38
sw20kosh
HP is just a calculation based on Torque. Torque is the actual force being measured at the wheel or flywheel.
If you have 150 TQ at 3000 rpm and 150 TQ at 7000 rpms, both are the same amount of force. If you stomp on the pedal at either of those two RPMS you will feel the same thrust propelling you forward (in the same gear of course).
The only thing HP tells you is where that torque is maintained too. To explain it in the simplest of terms....A bigger HP number (relative to the TQ number) means the torque is maintained to a high rpm. A bigger TQ number (relative to the HP number) means the torque is not maintained (drops off early). But really you should look at a Dyno graph rather than just looking at numbers. This is why the torque curve is important.
This is why an s2000 that revs to 9000 rpms has such a giant HP number. It maintains 150-160 ft lbs of torque all the way to 9000 rpms.
HP=(RPM * T) / 5252
The Following 4 Users Say Thank You to sw20kosh For This Useful Post:
cdrazic93 (03-31-2014), CSG Mike (03-31-2014), Hicklinc (02-04-2018), ptuning (03-31-2014)
Old 03-31-2014, 10:29 PM   #39
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
HP=(RPM * T) / 5252
So what is T? A constant or just time?
One last question so I don't throw this thread off topic...what determines if a engine can be torquey or not?
Old 03-31-2014, 10:29 PM   #40
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
T in this case is Torque.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 03-31-2014, 10:30 PM   #41
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Ah, I should have seen that one coming....lol
Old 03-31-2014, 11:05 PM   #42
ptuning
ptuning's Avatar
Drives: White FR-S
Our 4-1 header, oil cooler, washer reservoir, and WMI system are all going into production right now. Our production return style, swirl pot, flex fuel system will follow shortly after these components have been completed.
- Toan
ptuning is offline   Reply With Quote
The Following User Says Thank You to ptuning For This Useful Post:
winning
PTUNING: FR-S/BRZ/GT86 Spec-SS Turbo System (Now Shipping) ptuning Forced Induction 151 09-23-2016 10:48 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
PTUNING: TOM'S LED Tail Light Red Lens (US Spec) - Now IN STOCK! ptuning Exterior Parts - Lighting 0 09-19-2013 12:31 PM
PTuning Spec RS *pics inside* Dragonitti Other Vehicles & General Automotive Discussions 121 11-19-2011 11:52 PM
