Old 03-31-2014, 12:37 PM   #561
Midarete
Midarete's Avatar
Drives: Whiteout FRS
Originally Posted by JW89225 View Post
How hard is it to open up these winjets? was thinking of painting them and them re sealing them
I actually had them painted so I don't know how hard it was to do
Midarete is offline   Reply With Quote
Old 03-31-2014, 01:20 PM   #562
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by STS-V View Post
Should we silicone the sides before installing?
A good rule of thumb for any aftermarket light is to seal them with a strategically-placed bead of silicone before installation...
They almost always have condensation/fogging issues eventually if you don't seal them yourself
Old 03-31-2014, 01:41 PM   #563
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
So,
What can we use to seal them and where do they need to be seal?
I love boost!!!!!!
Old 03-31-2014, 02:07 PM   #564
RCSlide
Drives: Ultramarine 2013 FR-S
Originally Posted by clayrush View Post
Well crap.
Mine are fogging up. I not sure if I should open them up when the weather gets warm or see about trying to get them replaced.
I am also used to having hid bulbs in, so I feel blind now. New bulbs are coming in Monday.
mine also fogging =[
RCSlide is offline   Reply With Quote
Old 03-31-2014, 02:29 PM   #565
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Originally Posted by whitefrs View Post
So,
I love boost!!!!!!
RTV black silicone is pretty easy to find and works good. 3M makes some sealants too.
You need to seal the area where the lens meets the black plastic. The same 2 parts you would separate if you baked them.
headlikeahole is offline   Reply With Quote
The Following User Says Thank You to headlikeahole For This Useful Post:
Lonewolf (03-31-2014)
Old 03-31-2014, 02:39 PM   #566
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Thanks!!!!!
Ill be doing this
I love boost!!!!!!
Old 03-31-2014, 03:54 PM   #567
FRSHunter
Drives: Asphalt FRS
I've always wondered with the whole baking thing, is it actually safe to bake it in an oven? My friend wants to open his up to get it painted, but I told him a heat gun would probably be safer but would take longer to open. Also I heard that the seal is just a rubber gasket instead of Butyl rubber like most headlights.
FRSHunter is offline   Reply With Quote
Old 03-31-2014, 05:00 PM   #568
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Read yesterday heat is needed....but you can use a heat gun! Safer for sure...but baking isnt dangerous if youre smart and mind the oven
Fett4Real is offline   Reply With Quote
Old 03-31-2014, 05:02 PM   #569
headlikeahole
10 minutes at 200 is not exactly dangerous. Using your oven will make for more even heat over the heat gun.
Old 03-31-2014, 05:29 PM   #570
FRSHunter
Drives: Asphalt FRS
Just concerned of possible toxins being released due to the rubber weakening.
Old 03-31-2014, 06:23 PM   #571
-Ozzy-
Drives: Raven FR-S - Chevy Cobalt Coupe
Installed mine today. No fogging yet.
It's been 2 hours.
-Ozzy- is offline   Reply With Quote
Old 03-31-2014, 06:25 PM   #572
headlikeahole
If thats your concern then just run your oven through a cleaning cycle afterward.
Old 04-01-2014, 12:04 AM   #573
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
I've done it both ways. I prefer a heat gun, personally (you could pick one up from harbor freight for $20) but the oven method works perfectly fine.
86-tundra is offline   Reply With Quote
Old 04-01-2014, 09:03 PM   #574
Midarete
Midarete's Avatar
Got mine installed finally. No HID yet thanks to @Vic for installation.
The Following 2 Users Say Thank You to Midarete For This Useful Post:
86SPEED (04-01-2014), Vic (04-01-2014)
Winjet Headlights and HIDs HakunaMiata Cosmetic Modification (Interior/Exterior/Lighting) 27 07-18-2017 10:24 PM
New Winjet Headlights LED FLICKER?! Jeremehh Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 03:26 PM
Winjet headlights fogging up? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 23 05-17-2014 01:26 PM
Has anyone modified the winjet headlights to keep led's on? 86black Cosmetic Modification (Interior/Exterior/Lighting) 0 01-24-2014 12:42 AM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 08:28 AM
