Old 03-31-2014, 05:46 AM   #1
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
EcuTek map switching with OFT?
so has anyone cracked the EcuTek software code on how they implement the map switching with the cruise control? flashing roms with OFT isn't too bad but when switching between maps constantly it can get time consuming... thoughts?
andrew5826 is offline   Reply With Quote
Old 03-31-2014, 07:30 AM   #2
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
This is something that I don't see happening with the hardware as is. It requires breaking and rewritting essential code that dictates the way the ECU operates. @shiv@vishnu mentioned possibly integrating the PROcede box into the OFT for such functions. You can find it here: http://www.procedetuning.com/styled/styled-2/index.html
Looks like this:
Luckrider is offline   Reply With Quote
Old 03-31-2014, 09:31 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
Or you could just buy Ecutek...
1974 TA22 Celica
2013 86 GT
The Following 8 Users Say Thank You to Turdinator For This Useful Post:
chadstyle (04-13-2014), DBW (05-09-2014), Fast_Freddy (04-08-2014), jamesm (05-10-2014), raul (05-09-2014), SirBrass (05-09-2014), SmsAlSuwaidi (05-09-2014), Sportsguy83 (04-03-2014)
Old 04-02-2014, 07:45 PM   #4
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
but EcuTek doesn't change anything hardware. if ffs and lc could be implemented (is it from EcuTek?) then shouldn't the map switching technically be possible? just as soon as the code is cracked.. thoughts about this? @shiv@vishnu
The Following User Says Thank You to andrew5826 For This Useful Post:
Grymm86 (04-02-2014)
Old 04-02-2014, 07:48 PM   #5
Luckrider
Luckrider's Avatar
ECUtek hacked apart the base programming of the ECU to add such function. The open source community isn't "cracking" the programming of the ECU, they are translating the Hex Code of the tables to usable definitions so that tables can be modified for the desired effects.
The Following 2 Users Say Thank You to Luckrider For This Useful Post:
Fast_Freddy (04-08-2014), Sportsguy83 (04-03-2014)
Old 04-02-2014, 07:56 PM   #6
steve99
Drives: FT86
+1
Correct
It a whole new level to alter the actual ECU program to get it to perform additional functions.
Kind of like Editing an excel spread sheet as opposed to editing the actual excel program to get it to perform addition functions.
Its technical possible but unlikely as the open source guys work for free and the time and effort required would be large.
FFS/LC were tables in the original ECU code that were just not used.
Old 04-02-2014, 08:03 PM   #7
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
hmm I see, thanks for the explanation guys. looks like this is something the typical computer user won't really be able to do..
Sent from my SGH-I337M using Tapatalk
Old 04-02-2014, 08:05 PM   #8
Luckrider
Luckrider's Avatar
+1
Correct
LC is used on tons of vehicles from the factory and I believe the twins are included in this. I know my mom's Grand Cherokee has it set to something like 4500RPM (with ~6500RPM Redline). This function is used to keep cars from being overreved with no load. It is just a secondary Fuel Cut Rev Limit in the instance that speed is less than the set value.
Old 04-02-2014, 08:06 PM   #9
Luckrider
Luckrider's Avatar
Not something an advanced user can do either. It takes a special skillset in programming to pull off. It really comes down to a lot of invested time moreso than skil though.
Old 04-03-2014, 08:25 AM   #10
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Or you could just buy the Ecutek software and keep it simple.
pixel67 is offline   Reply With Quote
The Following 3 Users Say Thank You to pixel67 For This Useful Post:
Fast_Freddy (04-08-2014), SirBrass (05-09-2014), Sportsguy83 (04-03-2014)
Old 04-03-2014, 08:28 AM   #11
Kodename47
Kodename47's Avatar
Drives: UK GT86
You can even use the open maps in ECUtek as well....
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
Old 04-03-2014, 10:30 AM   #12
Luckrider
Luckrider's Avatar
Originally Posted by vgi View Post
OFT isn't open source.
the open source community (or rather folks that have the skills and need for a specific feature) does "hack" the ecu code and add new features - patches (eg FFS, LC, SD tuning, etc).
I haven't seen evidence of a hacked ECU anywhere. FFS and LC are defined in the stock setting. My understanding is that SD is accomplished through table modifications and is not available from open source tuning options for the twins.
Old 04-03-2014, 08:20 PM   #13
steve99
Drives: FT86
have you visited romraider forums?
not necessarily for brz/frs (yet):
http://www.romraider.com/forum/viewt...hp?f=25&t=7674
http://www.romraider.com/forum/viewt...=8024&start=75
https://github.com/Merp/MerpMod
where did you get that from?
the first (maybe not) FFC+LC patches were written by tyniwrex, here's his site (which btw has BRZ patch - so I HIGHLY doubt it's defined in stock rom): http://www.ecu-mods.com/online/
here's another interesting read: http://www.romraider.com/forum/topic...unch%20control
I Learn something new every day
Not accessible in stock ROM, only in OFT ROM's (or other patched ones)
Luckrider (04-03-2014)
Old 05-09-2014, 04:15 AM   #14
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Pardon my ignorance, but I figured I'd bump this thread since I found it while searching...
Why would you want to switch tunes, or why do you guys do it "often"? Only reasons I can think are going from E85/unleaded, and for smog or dealership visits.
unsurety is offline   Reply With Quote
The Following User Says Thank You to unsurety For This Useful Post:
Mike86 (05-09-2014)
Wrote off the FR-S, now switching sides Wilso Scion FR-S / Toyota 86 GT86 General Forum 14 03-01-2014 11:27 AM
Switching to E85 and back bfrank1972 Engine, Exhaust, Transmission 8 09-10-2013 10:16 PM
ecutek map switching defroster ft86me Software Tuning 8 08-04-2013 02:09 PM
Switching oils ArKiTeCkT Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 04-24-2013 01:24 PM
