Old 02-16-2014, 11:01 PM   #211
edsbreezy
edsbreezy's Avatar
Drives: 2014 Subaru BRZ Premium - Red
Originally Posted by FT-86 SpeedFactory View Post
No it clears just fine as well.
K thanks. Im looking at either the wilwood or stoptech setup.
edsbreezy is offline   Reply With Quote
Old 02-17-2014, 12:35 PM   #212
fx35s
Drives: 2013 Subaru BRZ
Correct guys 18x9.5 +38 fits just fine.
You can run 255s or 245s sqaure with no issues.
We run 265s but also add a bit of extra camber in for our track set up. Still no issues.
Look at how SEXY this combo is! Can get them in SBC or Black like pictured below and have the same stance.
sigh..
that's sex...
One day man.. one day.
Do you know how much ground clearance you have?
I know our stock height is like 4.8 inches or something off the ground.
fx35s is offline   Reply With Quote
Old 02-17-2014, 05:47 PM   #213
Ev@n
Ev@n's Avatar
Drives: 2014 brz limited 6AT
Originally Posted by hanabie View Post
I had Swift springs on stock struts with similar specs 18x 9.5 +38.
It will work without rubbing the front perch. I'm assuming you were talking 0 cambers.
Now, are you comfortable with poke and 5-7mm clearance from the perch?
If you want something that aggressive, I suggest you to get coils and a set of camber bolts for your front poke if you don't have any camber plates.
I'm thinking about getiing swift springs with similar specs too 18x95 + 38.. Any issues with this at all? How's the ride? Thanks!
Ev@n is offline   Reply With Quote
Old 02-17-2014, 08:11 PM   #214
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Originally Posted by Ev@n View Post
I'm thinking about getiing swift springs with similar specs too 18x9.5 + 38.. Any issues with this at all? How's the ride? Thanks!
I'd skip springs with that setup unless you don't mind with the front poke. I sold my springs for coils. I got ST coils, and the ride was significantly improved from swift springs.
Swift springs + 18x9.5 = stiff ride and handling.
hanabie is offline   Reply With Quote
Old 02-17-2014, 09:57 PM   #215
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by fx35s View Post
sigh..
that's sex...
Not sure on the exact amount but in that setting daily driving was no issue.
FT-86 SpeedFactory is offline   Reply With Quote
Old 02-18-2014, 10:01 PM   #216
FT-86 SpeedFactory
Originally Posted by yomny View Post
So what camber settings to avoid rubbing. I recall my 9.5" +40 Mirro's with 255 on the rear use to rub on hard dips.
-2 should do it.
Old 02-19-2014, 08:01 PM   #217
BenBrown
Metal up your butt
BenBrown's Avatar
Drives: Subaru BRZ
Can someone tell me if I can find those RPF1s with the same specs but in silver? I know I can find them with a 5x114.3 bolt pattern but I need them in 5x100 and I don't feel like spending money on hub conversion, and new break pads and rotors so the new hubs fit. So again looking for RPF1s 18x9.5 + 38 5x100 in SILVER. Thanks.
BenBrown is offline   Reply With Quote
Old 02-20-2014, 10:55 AM   #218
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Can anybody sell these individually/in pairs?
I want an extra pair of 18x9.5 RPF1s in SBC. I don't need a full set.
Old 02-20-2014, 04:01 PM   #219
jammz
Drives: '13 Scion FR-S Agento
Originally Posted by eseboner View Post
Hey man, car looks dope, I had a few questions. on the mcl photograph pictures are you running spacers? and any fender work?
thanks.
sorry I have been MIA for a while but no fender work was needed for rear.. however The fronts I rolled & pulled slightly ..
jammz is offline   Reply With Quote
Old 02-21-2014, 03:26 PM   #220
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
This is seriously perplexing. Have seen in person wheels 9.5" +40 on the back and the outside if the tire rubs the fender, even with camber. How's is that these fit just fine? Don't mean to be a bug but I just wanna make sure before buying. Normally I find things after I buy that I didn't before!?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 03-26-2014, 06:03 PM   #221
AMAY93
AMAY93's Avatar
Drives: Subaru BRZ limited MT
Enkei Rpf1 SBC 18x9.5 +38
Wheel Specs: Enkei Rpf1 SBC 18x9.5 +38
Tire Specs: Continental Extreme Contact DW 245/40/18
Weight: 16-17lbs
Suspension: Stock
- 2013 silver limited brz 6mt -
AMAY93 is offline   Reply With Quote
Old 03-26-2014, 08:48 PM   #222
CaptivaBlueTeg
Drives: WRB Brz
Any rubbing?
CaptivaBlueTeg is offline   Reply With Quote
Old 03-26-2014, 10:23 PM   #223
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Yeehaw!
slicktop is offline   Reply With Quote
Old 03-30-2014, 09:06 PM   #224
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Merged @AMAY93's topic = same wheel w/ same spec
ft-86 speedfactory
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 11:34 AM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 01:52 AM
