Old 03-30-2014, 08:35 PM   #127
flashburn
Drives: 2014 Subaru BRZ Limited 6MT
Put on my Rota Titan 17X8's in gold this weekend. Wrapped in Continental DW 225/45's, and lowered on Eibach Pro's. Very happy with the look.
flashburn is offline   Reply With Quote
The Following User Says Thank You to flashburn For This Useful Post:
akahenry (06-02-2014)
Old 03-30-2014, 08:46 PM   #128
Boxer486
Drives: small
Can you take a close up angled pic of the spokes and dish like post #126? I'm curious if they keep the same concavity at 8" as the 9". TIA.
Boxer486 is offline   Reply With Quote
The Following User Says Thank You to Boxer486 For This Useful Post:
fstlane (03-31-2014)
Old 03-30-2014, 09:40 PM   #129
flashburn
Boxer486 (03-31-2014)
Old 04-03-2014, 10:10 PM   #130
Sgtfluffy16
Drives: White BRZ Limited
So you ordered them in gold, not sports bronze? I am not a fan of this color. I like the sports bronze color better but wheeldudes web site is throwing me way off, especially when you are looking at all their wheels labeled color as sports bronze and then you look at the Titans in the 17x9 also labeled as a "sports bronze" and it looks like a gold wheel. I asked if they could open a box of one and send it to me. Hopefully they will and if its the color I want ill buy them tomorrow. Haha
Sgtfluffy16 is offline   Reply With Quote
Old 04-03-2014, 10:13 PM   #131
Sgtfluffy16
Originally Posted by fstlane View Post
Yes, I was running -1.9° front camber on the stock suspension without spacers but I'm using camber plates. If you plan on using just camber bolts you should be pretty close to -1.5°. However, there isn't much spring perch clearance (see pic). It never rubbed with the ZII's but they have pretty stiff sidewalls. A slip on 3mm spacer would probably be the easiest way to get a little more clearance and you should still be able to use the factory studs.
Hey looking at your picture here is this the amount of clearance I will have if I take off my stock wheels and run a 17x9 with a +42 offset with 245/40/17 tires? I was hoping to run 255's but from your picture it does not look like I can run the 255 :-(
Old 04-03-2014, 10:46 PM   #132
fstlane
fstlane's Avatar
Drives: BRZ Limited
Originally Posted by Sgtfluffy16 View Post
Hey looking at your picture here is this the amount of clearance I will have if I take off my stock wheels and run a 17x9 with a +42 offset with 245/40/17 tires? I was hoping to run 255's but from your picture it does not look like I run the 255 :-(
It depends on the tire as the section width varies by brand but running ZIIs I don't see 255's clearing. I would personally try but have 3mm spacers on hand just in case the clearance is too tight. I know Mach V stated that they fit 255's on their 17x9+42 wheels running stock struts but I don't know what tires they used. Good luck!
fstlane is offline   Reply With Quote
Old 04-04-2014, 02:23 AM   #133
Boxer486
Drives: small
You got the wrong person man.
Old 05-07-2014, 09:24 PM   #134
Goya
Goya's Avatar
Drives: 2013 SWP BRZ
Rota Titan Hyper Black (Silver) 17x8 +45
Rota Titan Hyper Black 17x8 +45 5x100
These are wedssport tc105n replicas
no spacers
RSR super down springs
stock 215 tires
I didn't think anyone has posted pics of the Titans in Hyper Black yet.
I'm pretty happy with the wheels. Even with the weak offset, they still have a slight concave look.
I tried out some gold lug nuts but I wasn't really feelin it. Threw black ones on there after. Heres pictures with both
Goya is offline   Reply With Quote
The Following 2 Users Say Thank You to Goya For This Useful Post:
FT86Z (06-08-2018), xuimod (07-21-2016)
Old 05-07-2014, 10:03 PM   #135
Code:Red
Code:Red's Avatar
Drives: 2013 Firestorm 6MT
Those look really good! That particular finish blends really well with SWP.
Code:Red is offline   Reply With Quote
The Following User Says Thank You to Code:Red For This Useful Post:
Goya (05-09-2014)
Old 05-08-2014, 01:09 AM   #136
jflogerzi
jflogerzi's Avatar
Looks good. I have Rota Toque in Hyper Black. Like my wheels, but I need some spacers.
Old 05-08-2014, 01:32 AM   #137
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
What's the weight difference between these and the Wedsports?
Wise is offline   Reply With Quote
Old 05-08-2014, 01:36 AM   #138
jflogerzi
jflogerzi's Avatar
Rota Titans are one of there lightest wheel. These should be mid to high 17LBS.
Old 05-08-2014, 02:12 AM   #139
Goya
Goya's Avatar
I know the 17x9s weigh 17.8 lbs, so i would guess just below that.
Old 05-14-2014, 06:34 PM   #140
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Merged @Goya's topic = same wheel w/ same specs
The Following User Says Thank You to DarrenDriven For This Useful Post:
Goya (05-15-2014)
Group Buy - Rota Slipstreams or Rota Grid davidsolarbell Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 12-17-2013 01:04 PM
Wheel Directory: Rota Grid 2 17x8.0 +38 stvrjs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-02-2013 05:08 AM
Rota SDR in Gunmetal? zooki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-10-2012 01:08 AM
Wheel Directory Rota PWR 18x9.5 +35 gabeg86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-31-2012 02:38 PM
