Old 03-26-2014, 04:03 PM   #4061
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Thatruth2001 View Post
I know, but does he intend to test with the ESC or NA.
Seeing as he has all the components in question and that is the thread for the new variable, it seemed the logical location to ask the question.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 03-26-2014, 05:39 PM   #4062
fenton
Had no idea of these before you mentioned them. Looks promising.
Im sure @shiv@vishnu will test them with ESC, no reason not to as the compressor can be added and removed with ease
Im very interested in the results.
Hopefully he can get them tested before the group buy ends.
fenton is offline   Reply With Quote
Old 03-26-2014, 10:49 PM   #4063
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Full throttle Electric Supercharger Build Thread
Edit... Just read the thread. Sounds interesting. Here I thought I was going to be done after the header. Now I need to raise an extra 300 bucks.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
DAEMANO (03-27-2014)
Old 03-27-2014, 06:09 PM   #4064
Robftss
Drives: VW
------Aussie update------
Work has begun!
I have shipped out a mock up kit to @Gums.
He has offered to solder/modify/fab WOT bracket etc... for RHD applications.
Also, compressor housing blanks have finally arrived.
Rob.
Robftss is offline   Reply With Quote
The Following 6 Users Say Thank You to Robftss For This Useful Post:
BRAWL (03-29-2014), cuddefred (03-27-2014), Gums (03-27-2014), keen as (03-28-2014), Pistol (03-30-2014), s2d4 (03-27-2014)
Old 03-27-2014, 06:31 PM   #4065
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Sounds like progress is being made, more kits available soon (for USA)?
Also a question, would there be any benefit to running a higher spec alternator? The dual dump config sounds like it makes the most of the 250 system but relocating a battery is not high on my list. If recharging could occur faster with a higher output alternator I would prefer that.
Thanks
F1fletch is offline   Reply With Quote
Old 03-27-2014, 06:33 PM   #4066
Thatruth2001
Drives: Raven FR-S
If Shiv shows any note worthy gains I will add to my setup ASAP.
Thatruth2001 is offline   Reply With Quote
The Following User Says Thank You to Thatruth2001 For This Useful Post:
Sojhinn (03-27-2014)
Old 03-27-2014, 09:07 PM   #4067
sato
sato's Avatar
Drives: Dodge Patitas
Thanks
It would be nice to compare how much a bigger alternator would increase parasitic drag and power loss
Sent from my C6906 using Tapatalk
sato is offline   Reply With Quote
Old 03-27-2014, 09:14 PM   #4068
cuddefred
Drives: Black 86 GT
Coming to Oz soon with a bit of luck
Work has begun!
Rob.
cuddefred is offline   Reply With Quote
Old 03-29-2014, 02:07 PM   #4069
WNDSRFR
Drives: FR-S,GTI
What do you guys think about this.
You take a turbocharger and divide it into it's two parts, the compressor and the turbine.
You connect the turbine to the exhaust manifold and connect the compressor to the intake manifold.
Get two super high speed brushless motors.
Attach the motors to the compressor and turbine.
Wire the motors together.
Hope that the motor on the turbine works as a generator.
This would eliminate all the pesky tubing between the turbo and the intake manifold.
Do you think this might work? I have a big old turbo laying around doing nothing.
Old 03-29-2014, 02:09 PM   #4070
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
I think the turbine motor would melt.
Old 03-30-2014, 06:32 AM   #4071
no chrome
She said member
Drives: fr-s firestorm
If it didn't melt, it would have the most turbo lag ever
no chrome is offline   Reply With Quote
Old 03-30-2014, 08:20 AM   #4072
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
I think thermoelectrics are a better route to pursue than a turbine driven generator, except, like batteries, the efficiency isn't there yet. Some day we'll see an oem setup using regenerative braking, exhaust energy recapture. full time boost available, but that kind of integration would be beyond an aftermarket kit. We could definitely integrate motor control into the ecu programming now, but are still limited by storage and recharging. Rob has hit the nail on the head with the goals and limitations of this system. I almost want to keep my brz just to play with the ESC, or even buy one to adapt to my truck.
As far as eliminating turbo tubing...higher boost will still need intercooling and the tubing that comes with that. Maybe what you want is a setup similar to the fa20dit, very minimal tubing.
Mobius357 is offline   Reply With Quote
Old 03-30-2014, 10:46 AM   #4073
Sojhinn
Sojhinn's Avatar
It looks like we are moving towards a kers oem setup. Volvo is testing it out right now. On a side note... The Perrin op / front pipe are awesome and installed.
Installed Mods:
Old 03-30-2014, 10:48 AM   #4074
Sojhinn
Sojhinn's Avatar
I have to go to stock mode today. Taking in my car tomorrow for my last free oil change, to replace the fuel pump (no more crickets) and seal up my cam plate that is leaking under load. Should be interesting to drive the car stock again.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
