Old 03-23-2014, 09:00 PM   #85
dz93
Drives: toyota 86
UPDATE:
today i received one of the DACs i bought.
tested and it works.
i had the nexus with the split otg cable
powered from laptop and a USB HUB connected to the usb end.
the HUB has the DAC connected aswell as a thumbdrive with music on it.
headphones into the dac playing music from the thumb drive and it worked
the only thing is, idk why.. (dont really care cause it doesnt effect my setup)
when i plug my headphones directly into my nexus.
no otg, no power cable or anything i dont get any sound. maybe theres a setting to tell the nexus theres no external dac connected?
Anyways i think this should all work.
USB HUB will have:
-DAC
-Ardiuno
-Thumbdrive (maybe.. still have the option of thumb drive directly to sony headunit)
The only thing im worrying about now is the install.
Ideally id like to be able to remove it as it can get pretty hot where i am.
The audio shop has suggested i get a audison bit 10 processor.
however i dont know how the audio would connect to it.
dz93 is offline   Reply With Quote
Old 03-23-2014, 09:08 PM   #86
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by dz93 View Post
UPDATE:
USB HUB will have:
-DAC
-Ardiuno
What temperatures are we talking about? Also why the processor?
Installed Mods:
Old 03-23-2014, 09:29 PM   #87
dz93
Drives: toyota 86
not everyday but temperatures can be 30+ (degrees celcius)
as for the processor, ive seen a couple other people use them.
im not all that interested as i want to spend as little as possible and dont think i need it.
but they'll give off great sound.
my friend doing an ipad install..
he is getting a cord that goes from the ipad and splits into rca's
the rca's into the processor (no headunit) then onward to the amps.
Old 03-23-2014, 11:40 PM   #88
Sojhinn
Sojhinn's Avatar
I'm in Southern California and I get similar temps. I haven't had issues yet but I can understand your concern. I think you should save you money for the processor if you don't like the sound then maybe buy it.
Installed Mods:
Old 03-25-2014, 07:06 AM   #89
dz93
Drives: toyota 86
yeah thats what im going to do in regards to the processor.
ive just ordered parts to build the arduino board
sony head unit should arrive in the next couple days.
all i need to do is figure out how to make the nexus start the arduino sequence upon power up.
i dont know how to get in contact with that guy though cause i cant sign up to that mp3 audio website without text message verification. commented on the youtube video.
see what happens.
Old 03-25-2014, 09:32 AM   #90
Sojhinn
Sojhinn's Avatar
see what happens.
I believe you download an app called tasker. And it lets you choose a series of events that start when the tablet receives power.
Installed Mods:
Old 03-25-2014, 09:40 AM   #91
dz93
Drives: toyota 86
Yeah sorry.
I've got tasked installed. Just not quite sure which event I have to 'task' etc.
I'm sure it will all become clear once I've got the board put together and plugged in.
Here's hoping for a all round perfect install!
Old 03-30-2014, 09:59 AM   #92
dz93
Drives: toyota 86
Originally Posted by Sojhinn View Post
Also if those don't work I'll buy a good one and send it to you.
just out of curiosity how much would this cost? (also note im in australia)
i received 2 different DACs. Can't remembere atm but i know one had a little bit of white noise if you listen carefully and i think the other made a 'click' sound when connected/receiving power.
-Do i need a dac that is aux out or can it be rca out, because i dont think head units have an rca input?
-I might end up buying a processor if im unhappy with the sound but would i still use the DAC to clean up the sound before going to the processor or not use one and leave it up to the processor?
This DAC seems decent giving rca and headphone output.
http://www.ebay.com.au/itm/Portable-...0f7db2a&_uhb=1
*side note, car arrives in a couple days.
The Following User Says Thank You to dz93 For This Useful Post:
Sojhinn (03-30-2014)
Old 03-30-2014, 10:42 AM   #93
Sojhinn
Sojhinn's Avatar
My dac makes a clicking noise on restarts of the nexus 7 other then that it works great. I'd imagine the cost to ship and buy is around 15-20 dollars. Also I still believe you should try it and see if you like it. Good luck with the install.
Installed Mods:
Old 04-07-2014, 11:54 AM   #94
dz93
Drives: toyota 86
....reconsidering
http://www.ft86club.com/forums/showt...02#post1654102
Old 04-07-2014, 12:09 PM   #95
Sojhinn
Sojhinn's Avatar
Easier but not as customizable. Not a bad option.
Installed Mods:
Old 04-07-2014, 12:16 PM   #96
Namuna
Namuna's Avatar
I saw that thread as well and also thought that might be a decent alternative...UNTIL I saw the cost ($533) and the fact it's only a single-core 1GHz processor (vs. quad-core 1.5GHz of the Nexus7 2013).
Namuna is offline   Reply With Quote
Old 04-07-2014, 12:21 PM   #97
Sojhinn
Sojhinn's Avatar
Ouch yeah that's nuts.
Installed Mods:
Old 04-07-2014, 12:27 PM   #98
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
But if it works well, does it really matter?
Well that was easy... FRyeS Scion FR-S / Toyota 86 GT86 General Forum 17 10-15-2013 11:04 AM
Nexus 7 in FR-S/BRZ DjDATZ Electronics | Audio | NAV | Infotainment 4 06-09-2013 08:10 PM
Nexus 7 Car Audio DIY thejevans Electronics | Audio | NAV | Infotainment 32 05-10-2013 03:55 PM
How easy/difficult is it to keep WRB "clean"? ayau Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 32 06-17-2012 10:17 PM
