Old 03-29-2014, 08:39 PM   #519
nelsmar
Originally Posted by gramicci101 View Post
That good, huh?
I cut my finger on the clamp on the sound tube and bled all over the donor car.
My flickr - Canibeat
Local magazine scout
Old 03-29-2014, 08:41 PM   #520
gramicci101
Off Topic
Don't wash it with hot water, the blood will set.
Or maybe that's clothing. Either way, all bleeding stops eventually.
Old 03-29-2014, 08:41 PM   #521
Luis_GT
Originally Posted by Sojhinn View Post
As a physics teacher I really appreciate this explanation.
As a Civil engineer... I hate dynamics...
Old 03-29-2014, 08:44 PM   #522
Dipstik-sportech
Dipstik-sportech's Avatar
Hydrogen peroxide for cleaning and a band aid for the boo boo lol
The Frozen North
Old 03-29-2014, 08:47 PM   #523
nelsmar
The Frozen North
I just held a rag around it while @Ninjin magically happened to show up and help me finish the install.
Oh and btw we finished hours ago.
Old 03-29-2014, 09:10 PM   #524
fa5tco
fa5tco's Avatar
Drives: 2013 Firestorm FRS
good god man! tellllllll ussssssssss
fa5tco is offline   Reply With Quote
Old 03-29-2014, 09:11 PM   #525
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by FrsDuke View Post
Did you fall asleep during lecture? He said the compression wave can move at mach1.0 but no material breaks the sound barrier. His post was just to clear up the guy claiming sonic booms from flow velocity at the valves. I'm not making a claim about the validity of your statement only that it is not a correction of gov's.
The gas flow issue comes from the difference between mean and instantaneous flow. While some people calculate a mean supersonic velocity depending on valve lift, the overall flow can increase because of the way the pressures change at valve lift isn't linear. So a calculated supersonic flow rate isn't actually supersonic through the whole event.
This is why some people talk about supersonic flow while others say un-possible.
The waves are the priority, though.
Because titanium.
Old 03-29-2014, 09:19 PM   #526
nelsmar
Oh right. Maybe I should stop teasing everyone who has been texting me. Was late returning the car. I'll make a thread that is actually on topic when I get home. But they worked. sustained most of the gains through tune.
Old 03-29-2014, 09:22 PM   #527
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
That is a less than exciting teaser...
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 03-29-2014, 09:39 PM   #528
mike the snake
Now it's been properly Christened with blood.
Old 03-29-2014, 10:21 PM   #529
governor
Drives: 2013 FR-S Navy Blue
I'm not 100% certain on the gas itself (there is often talk of sonic choking if velocity gets to high) leaving breaking breaks the sound barrier, but there is a wave produced that travels at the local speed of sound. The wave is what is used to increase gas speed and flow by modifying the pressure differential across the valves. It's timing, sign and effective strength are affected by the tubing cross section, distance traveled, gas density etc... which is what part of header and intake tuning is about. You want a high pressure positive wave at the intake as it opens and a low pressure negative wave at the exhaust when it opens.
This is why you sometimes see headers "shift" power up or down the rpm range, with a bump at high rpm. The higher rpm bump is typically from flow improvement, whereas the shift is from acoustic changes.
I did a quick search and found a thesis that affirms that through a valve it is possible to go from subsonic through to transonic and then to supersonic but there are some disclaimers in the text as well. http://www.diva-portal.org/smash/get...FULLTEXT01.pdf entitled 'Simulations of Compressible Flows Associated with Internal Combustion Engines'. Jump to Section 8.1 for a summary.
In my previous post I was considering the average flows and choking through the system and neglected to mention what was happening at the valve. Across the valve there will be a pressure reduction followed by a pressure recovery. In this area potential energy is converted to kinetic energy and then back to potential energy again. However, order to maintain supersonic speeds after the pressure recovery zone a very precise geometry is required. This was the point I wanted to make and perhaps misinterpreted what the original post I quoted was referring to.
-gov
governor is offline   Reply With Quote
Old 03-29-2014, 11:06 PM   #530
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Very curious to see the details... Also what happens when you add headers as well.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 03-29-2014, 11:12 PM   #531
nelsmar
http://www.ft86club.com/forums/showthread.php?p=1635741
I will be updating the post w/ header gains as well.
Enjoy guys! The gains were matching up with the other third party test & Crawford. This looks like a legitimate product!
Old 03-30-2014, 10:03 AM   #532
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by Turdinator View Post
Thank you for the photos. I like how you can't really see them.
I wonder if the grimmspeed strut bar would still fit. Do you know how tall the blocks are?
HI,
I plan to order Grimmspeed strut bar.
Do you think this block can fit with Grimmspeed strut bar?
The block height is 35.8 mm from the thread.
Thanks a lot.
cslntuee is offline   Reply With Quote
billet, crawford, magic blocks
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 05:19 PM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 08:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 02:29 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
