Old 03-26-2014, 09:13 PM   #15
shif7i7down
Erected Member
Drives: frs
Originally Posted by trevorovert View Post
Didn't know my car came with a nice pair of underwear?
Definitely don't want any knock on my softwear ..
wear do i start ....LOL, having knock on softwear does sound scary
shif7i7down is offline   Reply With Quote
Old 03-27-2014, 10:42 AM   #16
wparsons
wparsons's Avatar
fixed that for you
Subaru will not bring the 2013 models up to date if your car is older than some line in the sand.
That's ridiculous, are they trying to have to fix DI seal issues more?
flickr
Old 03-27-2014, 11:17 AM   #17
stugray
Drives: 2013 GBS BRZ Limited
They directly denied any "DI seals" issue and said they had not seen any cases of a repairs for the seals.
Old 03-27-2014, 11:19 AM   #18
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
fixed that for you
They will update for idle/stall issues which will update through the DI timing retardation update.
Luckrider is offline   Reply With Quote
Old 03-27-2014, 12:00 PM   #19
stugray
The most recent ROM they would install is ZA1JAOOC.
I do not believe that ROM has the transient retard fix in it.
I would just look, but I dont have a RR def file to use to examine it.
Old 03-27-2014, 01:16 PM   #20
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
I wonder if that is dealer specific. I'll check on a couple local Subaru dealers here to see what they say. Maybe it's just your specific dealership.
With an EcuTek license, cable, and software, you could flash an updated ROM onto your car yourself, or have the new ROM base included with a tune.
You are correct, the transient knock issue correction was included in the A01 ROMs.
Circuit Motorsports is offline   Reply With Quote
Old 03-29-2014, 09:26 AM   #21
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
i called the toyota dealer i bought the car from and they said there are no "recalls" on my production date which i find to be some bs. i bought my car october 2012. im thinking of driving over to the dealer today and asking them in person or is that a waste of my time? i track the car and auto x it so im concerned. could i go to a Subaru dealer to have the same thing done or would they deny me because its not a "Subaru" ?
DanoFA20 is offline   Reply With Quote
Old 03-29-2014, 11:03 AM   #22
Luckrider
Luckrider's Avatar
There is a big difference between Recall and TSB.
Old 03-29-2014, 05:00 PM   #23
DanoFA20
Shift Down
DanoFA20's Avatar
I understand that. But if it could cause di seals to blow then youd think they wpuld let their customers.
Old 03-29-2014, 05:03 PM   #24
Luckrider
Luckrider's Avatar
My point is that you need to site a reason for the replacement to get a TSB. A recall is mandatory. In all reality, that ignition retard fix is to cut down on the heat that attacks the DI seals when shifting from/to specific RPMs. They sent the car out from the factory with an incomplete table which is just stupid.
Old 03-29-2014, 05:04 PM   #25
DanoFA20
Shift Down
DanoFA20's Avatar
Agreed good sir I was just doing the " with the fingers lol. But yah there is a tsb for it right?
Old 03-29-2014, 05:14 PM   #26
Circuit Motorsports
Check the TSBs here:
http://www.ft86club.com/forums/showthread.php?t=21868
There is a TSB for both the FRS and BRZ for the idle stability/idle drop issue.
FRS: TSB: S-SB-0040-13
BRZ: TSB: 11-136-14
Both TSBs will get you flashed with the latest B01 ROM.
- Bob
Old 03-29-2014, 05:18 PM   #27
Luckrider
Luckrider's Avatar
The one posted above is the one you want. There isn't one for the DI seals, but they did fix the tune with newer revisions and the idle drop is how people have gotten the new calibration flashed.
Old 03-29-2014, 06:59 PM   #28
CARNZ
CHECK ENGINE
Drives: 2004 STi
I work at a Subie dealer and if any(not a certain prod date range) 2013 BRZs come in and they mention/need the reflash we install ZA1JB01C/D (depending on MT/AT).
i don't cry about crickets
CARNZ is offline   Reply With Quote
