Old 03-26-2014, 01:45 PM   #1
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
OEM softwear quesstion
is the stock softwear reliable. i talked to some friends who say that at high rpms, the car doesnt retard timing and causes knock? is this true or is the stock softwear completely fine. if its not i would be interested in getting a ecutek tune. i do track so i would love to get some inputs. thanks soo much for responses.
DanoFA20 is offline   Reply With Quote
Old 03-26-2014, 02:10 PM   #2
wparsons
wparsons's Avatar
I would be VERY suspect of anyone making claims like that without logs to prove it.
flickr
Old 03-26-2014, 02:39 PM   #3
DanoFA20
Shift Down
DanoFA20's Avatar
some one was telling me this but i wanted to make sure. thanks for the input though
Old 03-26-2014, 04:24 PM   #4
stugray
Drives: 2013 GBS BRZ Limited
What year is your car?
The 2013 cars had the issue that is believed to cause the blown DI seals issue.
If your car is a 2014, you already have the updated ROM to solve the transient retard issue.
Old 03-26-2014, 04:25 PM   #5
wparsons
wparsons's Avatar
If the ECU detects knock, it'll pull back timing, but without logs I'd be very suspicious.
flickr
Old 03-26-2014, 04:30 PM   #6
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
On 91 octane, it does indeed knock on stock tune. I'd have to ask @nelsmar if he has the logs from my car when we loaded the first few ROMs when we began road tuning, as I didn't have my tablet PC yet, so I don't have those logs. But, the logs did show knock detection detecting knock and the ECU pulling timing. But it wasn't that the ECU didn't pull timing, thus resulting in knock, like the OP was told by this anonymous "someone", but that the ECU detected knock and thus pulled timing.
My stock ROM was for the 2014 models, so I wouldn't have had the serious transient knock issue anyway.
^GT5 Replay Photo Mode^
Old 03-26-2014, 04:32 PM   #7
wparsons
wparsons's Avatar
Not saying it can't knock on the stock tune, but if it knocks it will pull back timing. The OP's post was asking about the ECU not pulling timing if it detected knock.
flickr
Old 03-26-2014, 05:20 PM   #8
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Didn't know my car came with a nice pair of underwear?
Definitely don't want any knock on my softwear ..
86-tundra is offline   Reply With Quote
Old 03-26-2014, 05:29 PM   #9
forzajuve
Drives: Ultramarine 86 - 6MT
Actually, the OP is reminding me of a post I read a few months back. It was with regard to the very issue he is talking about - knock on the stock tune at high RPM's. In fact, @shiv or @jamesm could probably shed some light on this
forzajuve is offline   Reply With Quote
Old 03-26-2014, 05:39 PM   #10
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
The factory tune does indeed knock on 91 octane, and I've seen it knock on 93 octane as well. Most of this knock was at lower rpms 1600 - 3000rpm and with a fair amount of tip-in knock. It did not have knock issues at the high rpms.
The ECU will pull/retard timing if it is detecting knock, regardless of the rpm you are running at.
There have been a few significant factory ECU flash updates since the earlier models came out. You can bring it to a local dealership to have it flashed to the latest factory update if you have not done so yet. If you have a 2014 you should be good.
If you have installed an aftermarket intake, you may be running too lean depending on the intake. Modifications will need a tune the get the maximum benefit from them.
- Bob
Circuit Motorsports is offline   Reply With Quote
Old 03-26-2014, 05:54 PM   #11
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
If you want at some point, we are close enough that you can see how my car runs with @shiv@vishnu's tune on the OFT. We can also use it to log your car if you wish. The factory tune can be all over the place sometimes. I noticed the IAM drop a few times with the stock tune, but never with Shiv's Stage 1 or EL Stage2 E85 tunes.
Luckrider is offline   Reply With Quote
Old 03-26-2014, 07:03 PM   #12
steve99
I believe your answer is here, transient knock retard was not activated in early ROM's
http://www.ft86club.com/forums/showthread.php?t=50088
Depending on your fuel the stock tune knocks as per above post by Circuit Motorsports. You can also get some knock in 5000-7000 rpm WOT, yes FLCK tries to correct it but its better if you retard your timing so it does not occur in the first place.
Remember the engine must knock before the knock detector can sense it and then the ecu corrects it.
Old 03-26-2014, 08:47 PM   #13
stugray
Originally Posted by Circuit Motorsports View Post
There have been a few significant factory ECU flash updates since the earlier models came out. You can bring it to a local dealership (unless you have a 2013 BRZ) to have it flashed to the latest factory update if you have not done so yet. If you have a 2014 you should be good.
fixed that for you
Subaru will not bring the 2013 models up to date if your car is older than some line in the sand.
Old 03-26-2014, 08:53 PM   #14
SirBrass
SirBrass's Avatar
fixed that for you
Subaru won't, but thankfully you don't have to rely on them to do that. If you've got ecutek, you can always flash your ECU to the latest ROM .
