Old 03-27-2014, 09:14 PM   #1
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Question How to achieve -2.0 front Camber with stock suspension (if possible)?
I just wanted to see if there is a way to achieve -2.0 front and similar rear camber with stock suspension. I've searched and many people claim that the camber bolts help that as well as the camber plates and/or aftermarket control arms but I would rather not to use anything besides the camber bolts.
What kind of camber bolts did you end up using with the stock setup and how much of camber you gained?
I think the best route would be coilover and lower ride height to do that but I just want to be able to use my R compound tires (235/40/17 Nitto Nt01s with Enkei RPF1 17x9 +35mm wheels) with stock suspension for now to and upgrade it gradually.
Thanks in advance
glamcem is offline   Reply With Quote
Old 03-27-2014, 10:35 PM   #2
cnk
Drives: '13 DGM BRZ Limited
Maybe lowering springs and camber bolts? Then save up for coilovers if that's what you want.
Old 03-27-2014, 10:48 PM   #3
ayau
Drives: Some rust bucket
Impossible to gain -2 at the front with just bolts. Lowering springs won't work either because the front doesn't gain camber under compression. Max camber I've seen with just bolts is -1.5. You could slot the strut, which would give you more camber.
The Following User Says Thank You to ayau For This Useful Post:
glamcem (03-27-2014)
Old 03-27-2014, 11:03 PM   #4
glamcem
glamcem's Avatar
What kind of camber bolts can I use on this car?
Any bolt is required for the rears?
Thanks
Old 03-27-2014, 11:18 PM   #5
DarkSunrise
DarkSunrise's Avatar
It seems that most people get about -1.3 with just one set of camber bolts. Not sure how far a second set of bolts will take you, but I doubt it'll get you to -2.0.
Edmunds got -2.0 max on stock suspension using HVT camber plates, so that might be the route to go if that's your target.
http://www.edmunds.com/scion/fr-s/20...er-plates.html
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
glamcem (03-28-2014)
Old 03-27-2014, 11:32 PM   #6
Lone Starr
Drives: WRB Limited
I've been searching this topic myself for a few days now and came across this thread:
http://www.ft86club.com/forums/showthread.php?t=44660
Looks like running camber bolts on both the top and bottom can get you the camber you're looking for.
So...at last we meet for the first time for the last time...
Lone Starr is offline   Reply With Quote
The Following 2 Users Say Thank You to Lone Starr For This Useful Post:
glamcem (03-28-2014), solidONE (03-28-2014)
Old 03-28-2014, 01:18 AM   #7
ayau
Thanks
I use the OEM crash bolts. I just prefer OEM. Some people use SPC bolts, and I believe they can get maybe a tenth more.
No bolts for the rear. You'll need adjustable lower control arm or upper control arm bushings to get rear camber. You could also lower the ride height to gain negative at the rear.
Old 03-28-2014, 02:00 AM   #8
Turdinator
Señor Member
Turdinator's Avatar
Thanks in advance
I would have thought top and bottom camber bolts would get you there. But you will get better answers in the CSG and RCE tag-team suspension Q&A thread! Ask us anything! thread.
Also I am 90% sure the front struts do gain camber as they compress or are lowered.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Old 03-28-2014, 02:06 AM   #9
ayau
It's very little if it does. Plus, you don't want to lower the car too much on OEM dampers or you'll run out of shock travel and/or ruin the suspension geometry.
Increasing positive caster will also increase negative camber when the wheel is turned. There's no factory caster adjustment, but I thought it's worth mentioning.
Old 03-28-2014, 02:47 AM   #10
glamcem
glamcem's Avatar
Do you have a part number or any link ?
Thanks again
Old 03-28-2014, 02:49 AM   #11
glamcem
glamcem's Avatar
Thanks but like I said I'd much rather use camber bolts or go with an affordable coilovers instead of camber platers due to NVH
Old 03-28-2014, 02:51 AM   #12
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I can confirm for certain that -2.0 front camber is achievable with doubled up SPC camber bolts. Although every car will be different, also might be different side to side. It's probably more like -1.9* camber (+- .2*) You'll likely get more if you just slotted your mounting holes tho... but I have no experience with slotting the holes.
And yes you do gain a tiny bit of camber lowering the front end. I can confirm that certainly as well.
The Following User Says Thank You to solidONE For This Useful Post:
Old 03-28-2014, 02:55 AM   #13
ayau
Thanks again
http://www.ft86club.com/forums/showp...11&postcount=1
Old 03-28-2014, 03:11 PM   #14
Wepeel
Drives: '13 BRZ Ltd
I bet you could get -2 up front (and possibly more) by doubling up on the OEM available crash bolt. Someone else with a more structural background would have to comment on how advisable that is.
But I'd feel better with the OEM crash bolt vs. aftermarket - the threaded portion is still the same dia/pitch and the torque/clamping force is still the same as stock. The aftermarket ones (at least the SPC) are narrower and have a lower torque spec.
Wepeel is offline   Reply With Quote
The Following User Says Thank You to Wepeel For This Useful Post:
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
Cheapest way to get more camber on stock suspension Snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-11-2014 09:45 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
Front stock struts/bolts max camber Q.. OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-15-2013 05:45 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 09:51 PM
