Old 03-25-2014, 09:33 PM   #15
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
It'll fit with coilovers.
You're comparing a Jetta to a Cayman.
So the kW are not as good. Will 245 all around work with stock suspension for now?
cjsporl1996 is offline
Old 03-26-2014, 02:06 PM   #16
CSG Mike
CSG Mike's Avatar
If you have the right offset wheel, yes
CSG Mike is offline
Old 03-26-2014, 09:29 PM   #17
cjsporl1996
ok, Will a 255 all around work without suspension mods or should i do a 245 front 255 rear?
Old 03-26-2014, 09:35 PM   #18
CSG Mike
CSG Mike's Avatar
What wheels
CSG Mike is offline
Old 03-26-2014, 09:37 PM   #19
cjsporl1996
What wheels
enkai raijin
Old 03-26-2014, 09:40 PM   #20
CSG Mike
CSG Mike's Avatar
Originally Posted by cjsporl1996 View Post
enkai raijin
specs?
CSG Mike is offline
Old 03-26-2014, 09:53 PM   #21
cjsporl1996
specs?
18x9.5
Old 03-26-2014, 10:20 PM   #22
CSG Mike
CSG Mike's Avatar
18x9.5
Offset?
CSG Mike is offline
Old 03-26-2014, 11:16 PM   #23
cjsporl1996
Offset?
http://www.enkei.com/size_chart/RAIJIN.pdf
Old 03-26-2014, 11:25 PM   #24
CSG Mike
CSG Mike's Avatar
Are you running a 05+ STI hub conversion?
CSG Mike is offline
Old 03-27-2014, 06:21 AM   #25
ecdhunt
Drives: 2013 SSM BRZ Limited MT
Man - with $5k, there's so many other options than the Raijins, especially for a track/DD car. Unless the Raijins are just for turning heads on the street and you're spending the rest on your track wheels.....
Don't get me wrong - I like the raijins too and was planning to get a set because they fit my modest budget. I only decided against them because they don't come in 17", and I don't see the benefit of 18" wheels for performance of this car, especially NA like mine. Looks, yeah. But for performance, 17" is likely better.
Anyway - with minimal budget constraints - I think you would likely be leaving a lot on the table by going with the Raijins.
ecdhunt is offline
Old 03-27-2014, 10:14 AM   #26
cjsporl1996
No I'm not
Old 03-27-2014, 12:45 PM   #27
CSG Mike
CSG Mike's Avatar
I'd run a 5mm spacer with 255
CSG Mike is offline
Old 03-27-2014, 01:16 PM   #28
cjsporl1996
Ok will do. So with this setup how much of an improvement will I see in handling? 255 seems pretty beefy to put up front... Wouldn't it require more steering input?
Also, these wheels only allow either a 35 or a 45. Which would be better? I believe a 35 wheel would have too much poke.
forced induction, ssr, tires, vortech, wheels
FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) kanundrum Wheels and Tires 19 10-11-2013 09:26 AM
CA FS:OEM BRZ WHEELS + TIRES midnight23 Wheels and Tires 5 07-25-2013 01:00 AM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
WTB: OEM 16" wheels/tires or similar 16" skinny alloy wheels (USA, CA) smmmurf Wheels and Tires 0 04-05-2013 12:42 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
