Old 03-07-2014, 02:04 AM   #1
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Wheels and tires help
I'm looking into the ssr gtv03
I'm looking at running 300 whp with a vortech kit so I'm not sure how wide to go. No wheel poke and the wheel must be flush with the edge of the wheel-well. I was hoping to keep the speedometer as accurate as possible.
As for tires occasional track use but mostly DD. I have dedicated winter tires.
@CSG Mike
cjsporl1996 is offline
Old 03-07-2014, 03:44 AM   #2
CSG Mike
CSG Mike's Avatar
Well, you only have 18x8.5 as an option in 5x100, and 17's are too narrow... have any other wheels in mind?
CSG Mike is online now
Old 03-22-2014, 11:55 PM   #3
cjsporl1996
will do. If you have a moment I want to have a discussion with you about tires, wheels, and your ideal suspension modifications. Let me start with the wheels and tires. I'm looking at the Enkei Raijin wheels but I'm not sure what what offset, width, etc to go with. As for tires, this setup will be for track and street use. I do have dedicated winter tires. Running Vortech Kit.
(prefer no poke, no spacers, and keeping the speedometer reading as accurate as possible)
@CSG Mike
Old 03-23-2014, 08:35 PM   #4
CSG Mike
CSG Mike's Avatar
Ideal is subjective. What kind of experience do you have? How much power are you making? What kind of roads do you drive on and what tracks? What is your tolerance for ride quality and budget?
Old 03-23-2014, 09:16 PM   #5
cjsporl1996
I only have hpde experience and hopefully be making 300whp once my tune is finish. Generally out roads are average as far as the u.s goes. I'm not too concerned about rid quality as long as I get the best handling possible. Budget is not a concern but I don't want to spend a huge amount of money.
Old 03-24-2014, 01:14 AM   #6
CSG Mike
CSG Mike's Avatar
Pick one
Old 03-24-2014, 01:44 AM   #7
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
Have an exact budget? If it is around 1500, may I recommend the perfect wheels for this car!! Gram Lights 57xtremes! They come in 17x9s. Also, Weds tc105n is also an option and they are pretty light! Those should be plenty wide for the tires you will be getting.
IAmNotTheDriftKing is offline
Old 03-24-2014, 07:16 AM   #8
cjsporl1996
Pick one
4-5 grand
Old 03-25-2014, 02:14 PM   #9
cjsporl1996
@CSG Mike
@CSG Mike
Old 03-25-2014, 06:19 PM   #10
CSG Mike
CSG Mike's Avatar
JRZ RS.
Old 03-25-2014, 08:13 PM   #11
cjsporl1996
JRZ RS.
How about Koni inserts with sportline springs? And what do you recommend for tires with those wheel. Width, wheels size, offset? How about kW coilovers? I would think the Koni inserts would be very good.
Old 03-25-2014, 08:16 PM   #12
CSG Mike
CSG Mike's Avatar
Volk TE37RT 17x9.5 +40 with 255 tires of your choice.
Old 03-25-2014, 08:30 PM   #13
cjsporl1996
How about for the enkai raijin? 255 seems to be awful big for a square setup I don't even think they will fit. How about those sportline lines with Koni inserts or the kW v3?
Old 03-25-2014, 08:48 PM   #14
CSG Mike
CSG Mike's Avatar
It'll fit with coilovers.
You're comparing a Jetta to a Cayman.
forced induction, ssr, tires, vortech, wheels
FS Momo Tuner Wheels 5x100 W/ KDW Tires (Rare Wheels) kanundrum Wheels and Tires 19 10-11-2013 09:26 AM
CA FS:OEM BRZ WHEELS + TIRES midnight23 Wheels and Tires 5 07-25-2013 01:00 AM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
WTB: OEM 16" wheels/tires or similar 16" skinny alloy wheels (USA, CA) smmmurf Wheels and Tires 0 04-05-2013 12:42 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
