Old 03-27-2014, 12:12 PM   #911
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Originally Posted by AustinTX View Post
245/45/17 will be quite a bit taller than stock. I would not attempt.
I agree.
I have a set of 235/45R17 ZII's and I think I may already be beyond the bounds of competitiveness based on reduced acceleration. We have some big courses in the area, so maybe it'll offset some.
I now have a set of 235/40R17 R1Rs that will get tested back to back with the 235/45R17 ZIIs on April 19th at a test and tune, so we'll see.
I'm just trying to decide which set I want to try out in Wilmington the week prior at the Match Tour. The ZIIs I'm good to go now, the R1Rs I need to have mounted.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 03-27-2014, 12:22 PM   #912
itzmik3
DBC Racing
itzmik3's Avatar
Originally Posted by Sccabrz192 View Post
I agree.
quick question. 235 r1r on a c street car?
just from previous experience be ready for an "interesting" ride. we ran 225 r1r in the past and with the lack of camber and inability to stretch the tire we were only able to get 50-60 runs out of them.
#194 SM
itzmik3 is offline   Reply With Quote
Old 03-27-2014, 12:25 PM   #913
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
speaking of longevity, will the Yoko at either 235 or 245 on a 7" hold up to about 120 runs plus 10k road driving?
Old 03-27-2014, 12:28 PM   #914
itzmik3
DBC Racing
itzmik3's Avatar
that i do not know.
the yoks don't see any street miles and we are only 29 runs in
one thing i can say is that even with the tires hot to the touch it actually became more grippy
#194 SM
Old 03-27-2014, 12:34 PM   #915
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Longevity wasn't a concern, no point having them around for next year since they will be illegal anyway. The whole street tire landscape will be very different next year, so might as well go for broke see what happens, and worry about next year in 12 months.
Haha, I'm interested in your definition of "interesting"
The Following User Says Thank You to Sccabrz192 For This Useful Post:
AustinTX (03-27-2014)
Old 03-27-2014, 03:35 PM   #916
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
i did the math on the ZII's from tirerack, i'm not winning after conversion, shipping, customs and taxes . Well, maybe a little bit, but not enough for a swaybar. Also in this particular case i really do want to support local.
Ouch, didn't think about customs and the conversion. FWIW, supporting locally, any of the Star Specs, ZIIs, or Rivals you buy go through Tirerack no matter where you buy them. So either you buy them directly through Tirerack or your local shop buys them from Tirerack and then marks them up a bit to cover their own costs.
DylanFRS is offline   Reply With Quote
Old 03-29-2014, 05:57 PM   #917
jpjamiso
Drives: FR-S MT Ultramarine
Hands down best thread on the forum, you guys are so helpful.
I started last year and am hopelessly hooked. Still need to finish the installs, but by the first local event I will be running rpf1, rivals, ferodo pads, camber bolts. My question is what to say when I get an alignment after installing the camber bolts? Should I start with zero toe? Any suggestions on where to go?
jpjamiso is offline   Reply With Quote
Old 03-29-2014, 08:22 PM   #918
FastWhite
Drives: Subaru BRZ Limited M/T
For me, this is my daily driver. So I kept it at 0 toe for wear. Some hear run some toe out in front and toe in at the rear. They can chime in on the numbers and wear on the tires.
FastWhite is offline   Reply With Quote
Old 03-30-2014, 02:30 AM   #919
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
@jpjamiso, I also daily drive my BRZ and my region doesn't have access to very wide open locations (i.e., we tend to have tighter courses), my co-driver and I are trying a total of 1/8" toe out in the front and 0 toe in the rear. I haven't noticed extra wear from that front toe.
G_Ride is offline   Reply With Quote
Old 03-30-2014, 07:02 AM   #920
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
If youre still new to the sport, front toe is best kept to a minimum. I would suggest at least .1-.15 degrees toe in for each rear wheel though. No noticeable wear for me.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 04-02-2014, 10:08 AM   #921
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
for the guys running ferrodo's
front only or rears as well?
Old 04-02-2014, 10:49 AM   #922
Kido1986
Dodging cones
Kido1986's Avatar
Started with just front, worked well for stopping. Once I did rear though, I found the on-brake-rotation I was missing (due to heavier front brake balance with the gripper front pads)
Old 04-04-2014, 10:50 AM   #923
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
how does C-Street handle bumpstop modification. I've re-read the paragraph 50 times last night and it seems that so long as the distance between the shock body and the engagement is not shortened (ie, faster engagmenet) then you get carte-blanche on the rest?
Old 04-04-2014, 11:54 AM   #924
Wepeel
Drives: '13 BRZ Ltd
As I understand it you can use any bumpstop as long as it is not longer than the stock one. Being that the stock bumpstops are somewhat close to being engaged at stock ride height, I think there is a lot of tuning potential here, especially considering shocks that generate a lot of rebound are an option.
Bumpstop tuning is a common thing for Miatas, and I've heard for Minis as well.
Wepeel is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
