Old 03-26-2014, 04:02 PM   #253
Aznsky
Drives: Nissan 350Z (sold) 13' Whiteout FRS
Installed my bar the other day, which I purchased about a year ago lol.
Issues I ran into was the bushings were way too tall which ended up making us cross thread the bolts when we tried to attach the bushings back to the bracket. Ended up having to shave down the bushing height quite a bit and run a tap through the bracket and bolts to clean up the threads.
Also had a buddy round off the corners of each end for additional clearance as a precaution.
Aznsky is offline   Reply With Quote
The Following User Says Thank You to Aznsky For This Useful Post:
2superblus (03-27-2014)
Old 03-26-2014, 08:08 PM   #254
xwd
Much easier to remove the mounting brackets to the chassis than try to put the swaybar brackets back on with larger bushings.
Old 03-26-2014, 09:37 PM   #255
Aznsky
We actually did remove the bracket from the car, but still had the same issue.
Old 03-26-2014, 10:08 PM   #256
vroom4
You have to flip the bushings around when they don't fit. I had the exact same problem and nearly cross threaded both sides. Flipped them around and it went together perfectly. They aren't exactly symmetrical apparently.
vroom4 is offline   Reply With Quote
Old 03-27-2014, 06:34 AM   #257
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Should the slit be forward in car or rearward in car? Mine went together but it was a bear.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 03-27-2014, 11:35 AM   #258
vroom4
I dont remember, I just know that both ways work, but the one way really really sucks and the other way is nice and easy.
I think if you already got it together, it is good.
Old 03-27-2014, 11:36 AM   #259
vroom4
I think it is the OPPOSITE of the way the stock slit goes, now that I think about it. Because I tried to match stock...nearly stripped out both sides...and then realized maybe it was a mold flaw and tried the other way. Bam, worked great.
The Following User Says Thank You to vroom4 For This Useful Post:
Sccabrz192 (03-27-2014)
Old 03-27-2014, 12:09 PM   #260
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Mine were way to big as well. Nothing a bit of trimming couldn't fix.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 03-27-2014, 01:22 PM   #261
celica73
I guess I'm pulling the sway bar this weekend. I didn't strip any bolts, but I had a rigid sway bar after installation. Couldn't budge the thing, and it resulted in a ton of push. Since then I just shimmed the brackets with washers, but I'd rather flip the bushings and have it work. At least it isn't a hard job. More time to take off the undertray than the sway bar.
Old 03-27-2014, 01:40 PM   #262
was385
Drives: MT WRB BRZ Limited, 2007 911s
Originally Posted by celica73 View Post
I guess I'm pulling the sway bar this weekend. I didn't strip any bolts, but I had a rigid sway bar after installation. Couldn't budget the thing, and it resulted in a ton of push. Since then I just shimmed the brackets with washers, but I'd rather flip the bushings and have it work. At least it isn't a hard job. More time to take off the undertray than the sway bar.
I think I'm going to have to do the same thing. The biggest pain is definitely the under tray and undoing the endlinks. Everything else is a snap.
was385 is offline   Reply With Quote
Old 03-27-2014, 01:49 PM   #263
Thorpedo
The SquadWhisperer
@Sam Strano Which way is the proper direction for the slit to face?
I installed mine last summer (with great results) but I have no idea if I have them in there the right way.
I should add that the change in balance of the car was spot on IMO.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 03-27-2014, 01:49 PM   #264
vroom4
I would be suprised if this is your problem....
Old 03-28-2014, 09:40 PM   #265
celica73
I just tried flipping the bushings and it was a major fail. I couldn't even get it bolted together with the bushings flipped. Oh well, it's a good time to freshen the grease.
Old 03-28-2014, 10:51 PM   #266
toeout
The stock bushings have a slit forward, so that's how installed mine. I also tried them the other way just for kicks and it seemed the same.
Also bought the collars mentioned on page 11. Rotating the bar around, the collars didn't make any contact with the bushing brackets
toeout is offline   Reply With Quote
Autocross video of Strano Performance Parts FR-S, first time out. Sam Strano Tracking / Autocross / HPDE / Drifting 18 10-02-2014 09:01 PM
Lutz Performance | Performance parts SALE Diego@lutzperformance Engine, Exhaust, Bolt-Ons 8 10-08-2012 10:09 AM
TRD/STI & Performance Parts newft86 Australia Classifieds 31 08-27-2012 07:17 AM
Strano Performance Parts making use of Suspension and Brakes Sam Strano Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-11-2012 07:52 PM
