Old 03-26-2014, 10:57 PM   #29
Fast_Freddy
Drives: Passat
Let's also not forget that the JDL result was from a Dyno Dynamics using it's inflated Dynojet "equivalent" mode which reads higher than any other dyno I've ever seen. AFAIK the only NA FA20s to ever dyno at more than 200whp on pump gas were all tested on Dyno Dynamics in Dynojet "equivalent" mode.
Fast_Freddy is offline   Reply With Quote
Old 03-26-2014, 11:16 PM   #30
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
off topic so fast...so many whiners in this thread
The Following User Says Thank You to norsamerican For This Useful Post:
Old 03-27-2014, 02:41 AM   #31
Fast_Freddy
Drives: Passat
Still not apples to apples but not nearly as laughable as the above apple to broccoli comparison.
Borla UEL:
JDL UEL:
Old 03-27-2014, 03:17 AM   #32
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
Drives: '13 Asphalt FRS MT
only in a frs/gt86/brz forum would you see an argument on 10hp differences! lol
IM with you ! they have comedic value though and its fun reading them! technically its not that off topic! the op did ask a question that had to do with headers
FRS_FIEND is offline   Reply With Quote
Old 03-27-2014, 03:34 AM   #33
Fast_Freddy
Drives: Passat
The OP's newbie question was answered in the third post. How many times or different ways would you whiners like to see it answered?
Old 03-27-2014, 06:21 AM   #34
s2d4
s2d4's Avatar
Originally Posted by Fast_Freddy View Post
Admittedly still not nearly as pretty as JDL's but about the same as what you'll find on Revworks, OpenFlash, etc.
You are delusional.
The Following User Says Thank You to s2d4 For This Useful Post:
ATL BRZ (03-27-2014)
Old 03-27-2014, 10:54 AM   #35
reardrv
Drives: 2013 Subaru BRZ
I just think its hilarious how little the actual person who works for Borla knows about the company's products, that would be enough for me to stay away from them. I used to work customer service for a major firearms manufacturer and if I put out information on a forum that was that wrong, I would have been fired pretty quickly.
reardrv is offline   Reply With Quote
Old 03-27-2014, 02:51 PM   #36
Fast_Freddy
Drives: Passat
Originally Posted by s2d4 View Post
You are delusional.
Says the ignorant fool.
Old 03-27-2014, 07:02 PM   #37
s2d4
s2d4's Avatar
anyone can see who the ignorant fool is.
Borla != OFH in quality.
"Looks good" on dyno != No logging required to confirm all is well for DD.
Old 03-27-2014, 09:55 PM   #38
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
Why is everyone trying to justify what they bought? You bought it, enjoy it!! You honestly won't feel the difference in power between the Borla or JDL, anywhere in the rev range. JDL has great quality, but the Borla is a great value(although the OFH are better IMO). It is only car parts people.
Also, yes it does remove the cat. Will you get a code, only if you aren't tuned. Otherwise you are fine.
IAmNotTheDriftKing is offline   Reply With Quote
The Following 3 Users Say Thank You to IAmNotTheDriftKing For This Useful Post:
Fast_Freddy (03-31-2014), mmmcambelsoup (06-30-2014), WRXGuy1 (04-22-2014)
Old 03-27-2014, 10:20 PM   #39
Turdinator
Señor Member
Turdinator's Avatar
Jesus, can we all just put our e-peens away for a minute. The Borla and JDL UELs are made made for different sections of the market and their respective pricing and quality reflect this. The borla is significantly cheaper than the JDL because not everyone can afford to buy the best of every part they replace on their car. JDL fanboys need to stop being elitest. Borla fan boys need to recognise their header was made to a price point not a preformance goal.
And the Borla Rep SHOULD have done their research before posting but it is not the end of the world. Everyone makes mistakes. [/RANT]
Originally Posted by jjkerr626 View Post
Hello, I have the Innovate SC and the Borla UEL header. I have not installed any of these parts yet but I also wanted to add the Borla frontpipe/overpipe but I wanted to ask if anyone has any experience with this throwing CEL codes because there is no cats anymore?
I plan on getting an ECUTek tune.
Any help is appreciated, thank you.
To run the innovate supercharger you will need a tune. That tune will turn off the CEL you would get from running a header without a CAT. The overpipe and front pipe wont have any bearing on this.
1974 TA22 Celica
2013 86 GT
The Following 2 Users Say Thank You to Turdinator For This Useful Post:
Fast_Freddy (03-31-2014), jjkerr626 (03-31-2014)
Old 04-19-2014, 01:40 AM   #40
DJLtoronto
DJLtoronto's Avatar
Drives: Mazda
Just some pics of the Borla UEL header
Enjoy.
DJLtoronto is offline   Reply With Quote
Old 04-20-2014, 12:24 PM   #41
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
There seem to be many knowledgable people in this thread so my question is now that I've added the Innovate SC and the Raceseng 70mm pulley do I need to change my map sensor to a 2.5 bar? My tuner suggested this as he said the ECU can't read over 7psi on the stock one. I have also read that some people say not to change it so I just need a few opinions please. Thank you.
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
Old 07-28-2014, 05:44 AM   #42
akahenry
akahenry's Avatar
Drives: '18 STi
Just out of curiosity, is it recommended to install a brand new header (UEL in this case) along with an overpipe at the same time? If not, would it be fine to simply install an aftermarket catless header while keeping the stock overpipe? I know for a fact an aftermarket overpipe isn't going to give any significant or noticeable horse power improvement over the stock overpipe, but is it worth it to upgrade to an aftermarket overpipe (performance wise)? Is it worth it to spend a couple hundred bucks on an overpipe for slightly better flow- is my real question. (I feel like this second question is redundant and voids my aforementioned question lol) Comments, suggestions, and opinions are greatly appreciated!
akahenry is offline   Reply With Quote
Overpipe and Frontpipe (CA Questions) FUN BRZ Northern California 17 03-21-2014 02:36 AM
3" overpipe/frontpipe nameless Victor Draken Engine, Exhaust, Transmission 14 11-12-2013 06:31 AM
WTB:Headers and Overpipe/Frontpipe MrTranxD Engine, Exhaust, Bolt-Ons 0 10-30-2013 10:38 AM
WTB - Stock Overpipe and Frontpipe DanVIIIVI Australia Classifieds 2 09-25-2013 04:16 AM
Overpipe or frontpipe? feldy Engine, Exhaust, Transmission 8 09-10-2013 01:01 PM
