Old 03-20-2014, 12:19 AM   #1
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
Borla UEL Header & Overpipe/Frontpipe
Hello, I have the Innovate SC and the Borla UEL header. I have not installed any of these parts yet but I also wanted to add the Borla frontpipe/overpipe but I wanted to ask if anyone has any experience with this throwing CEL codes because there is no cats anymore?
I plan on getting an ECUTek tune.
Any help is appreciated, thank you.
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
Old 03-20-2014, 12:35 AM   #2
jpit
Drives: Subaru BRZ
The frontpipe and overpipe combination will be fine - there are no 02 sensors located there.
The header may cause an off and on problem even with a tune. I have an 02 sensor extender on my Borla header with an ECUTEK tune and it throws a code every 1000 miles or so. Easy to reset and really doesn't cause a problem.
jpit is offline   Reply With Quote
The Following User Says Thank You to jpit For This Useful Post:
jjkerr626 (03-20-2014)
Old 03-20-2014, 02:49 AM   #3
Fast_Freddy
Drives: Passat
You don't need cats with a Ecutek tune. If you have an Ecutek tune and still get a cat related CEL it's probably because you're running an O2 spacer (extender). Your CEL is for low O2 because of the combination of tune + spacer. Remove the spacer and the CEL will go away.
Fast_Freddy is offline   Reply With Quote
The Following 2 Users Say Thank You to Fast_Freddy For This Useful Post:
jjkerr626 (03-20-2014), kuhlka (03-25-2014)
Old 03-25-2014, 12:46 PM   #4
deletedbilly
Drives: 04 BMW 330ci, 90 180sx, 13 FRS
Hi jjkerr626,
Our headers do NOT remove the factory catalytic converters. While a CEL is possible at any given time, you should not expect one from the installation of our parts. That said, if you do proceed to install our header (part #17284) with a tune, you will usually find more power from our parts than without.
http://www.borla.com/products/frs_br...rt__17284.html
deletedbilly is offline   Reply With Quote
Old 03-25-2014, 12:53 PM   #5
FR-S Matt
Originally Posted by lindsay@borla View Post
Hi jjkerr626,
Um, you sure about that? The factory header has a cat in it and the header you just linked below is catless. Unless something has changed, Borla doesn't have a catted option.
The Following 2 Users Say Thank You to FR-S Matt For This Useful Post:
ATL BRZ (03-25-2014), FRS_FIEND (03-26-2014)
Old 03-25-2014, 12:57 PM   #6
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
The Following User Says Thank You to carbonBLUE For This Useful Post:
Old 03-25-2014, 02:05 PM   #7
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Hi jjkerr626,
You're joking, right?
wow, just wow
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
FR-S Matt (03-25-2014), FRS_FIEND (03-26-2014)
Old 03-25-2014, 02:15 PM   #8
FR-S Matt
wow, just wow
Don't forget the collector was also created by the top collector welder in the world. So glad I didn't go with Borla... lol. Bunch of corporate robots that don't even know their own products.
ATL BRZ (03-25-2014), nor cal frs (03-26-2014)
Old 03-25-2014, 02:17 PM   #9
ATL BRZ
ATL BRZ's Avatar
J-W (03-25-2014), nor cal frs (03-26-2014)
Old 03-25-2014, 02:24 PM   #10
woode
Boosted Member
woode's Avatar
Send a message via MSN to woode
Does Toni work for Borla!?
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following User Says Thank You to woode For This Useful Post:
Old 03-25-2014, 02:43 PM   #11
Fast_Freddy
Drives: Passat
That's one very popular photo you posted yet again. I've seen that posted and reposted at least 100 times now. Just for the sake of a little factual accuracy, usually missing on this forum, I'm posting a photo of a much more typical Borla collector. Admittedly still not nearly as pretty as JDL's but about the same as what you'll find on Revworks, OpenFlash, etc.
The Following User Says Thank You to Fast_Freddy For This Useful Post:
Old 03-25-2014, 03:01 PM   #12
woode
Boosted Member
woode's Avatar
You're not helping your [Borla's] case..
Old 03-25-2014, 03:20 PM   #13
FR-S Matt
He's a Borla fanboy for life. You can't sway him.
I'll put my JDL UEL and full exhaust up against this header and full exhaust any day. You will see which one comes out on top because of proper collector engineering.
Why do you think Nameless ended up with a pointy sharp collector similar to JDL as well? Granted they both aren't the same header as they have different power ranges because of EL vs UEL, but the one similar characteristic is the merge collector.
The Following User Says Thank You to FR-S Matt For This Useful Post:
ATL BRZ (03-26-2014)
Old 03-25-2014, 03:43 PM   #14
FRS-Jonathan
FRS-Jonathan's Avatar
Drives: 2013 6spd manual Scion FRS
What's funny is the Dyno showing more torque on the borla but meh who pays attn to that stuff XD
FRS-Jonathan is offline   Reply With Quote
The Following 2 Users Say Thank You to FRS-Jonathan For This Useful Post:
Fast_Freddy (03-26-2014), FRS_FIEND (03-26-2014)
Overpipe and Frontpipe (CA Questions) FUN BRZ Northern California 17 03-21-2014 02:36 AM
3" overpipe/frontpipe nameless Victor Draken Engine, Exhaust, Transmission 14 11-12-2013 06:31 AM
WTB:Headers and Overpipe/Frontpipe MrTranxD Engine, Exhaust, Bolt-Ons 0 10-30-2013 10:38 AM
WTB - Stock Overpipe and Frontpipe DanVIIIVI Australia Classifieds 2 09-25-2013 04:16 AM
Overpipe or frontpipe? feldy Engine, Exhaust, Transmission 8 09-10-2013 01:01 PM
