#379 |
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
#380 |
Drives: 2013 FRS
Those will OFT dollars in their account will get $100 discount for the Crawford Power Blocks. But first they have to pass the dyno test on our test car
#381 |
Drives: 2013 FRS
#382 |
Drives: 13 Whiteout 6MT
#383 |
Drives: FR-S 10 #103 AT
That can be remedied, we'll just make Canada the next ten states.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#384 |
Drives: 2013 FRS
#385 |
Troll Hunter
Drives: fr-s, tundra
If the donald had an 86, he would turn his head for you
#386 |
Drives: FRS-Raven-MT
Glad to see shiv is on board. Was planning to order a set today but looks like I'll be waiting for shiv to start selling them. OFT FTMFW!
#387 |
Fanboy
Drives: 2013 ultramarine frs
Mmm I see a wideband and blocks in my future. Now to get a nameless header in your hands.
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#388 | |
Drives: '13 Whiteout FR-S (M/T)
#389 | |
Drives: 2013 Black FR-S
The net result is you have a faster car because you are sweeping through that rev range not just the 7-7.4k range... |
#390 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
You aren't even going to be able to make use of even 10+ extra HP in 500 rpm at the top end. The mid-range is where you are more even for autocross and track days.
#391 | |||
Drives: 2005 Toyota Camry
Even better, MotoIQ will dyno the car again in a few weeks to see if the power remained. -alex Edit: While I agree that the powerband being wider (larger area under the curve) is a good thing, one has to take into consideration transmission gearing ratios and wheel/tire choice to maximize performance. For a street car, this wider powerband is beneficial... however if one were to race, the same can't be said so easily. For drag racing, you'd want to ideally overlay redline and RPM drop points to see what powerband the car will be in. Same for track... sometimes a shift like this necessitates different gearing. A car's powerband isn't laid out arbitrarily, once you change something ideally there should be something else to take advantage of it. |
#392 |
Drives: 2013 Scion FRS
Sub'd - OFT and real dollars waiting if it comes with an e85, OFH, ESC, CBPB tune =)
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
| Tags |
| billet, crawford, magic blocks |
| Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 | ZetaVI | BRZ Photos, Videos, Wallpapers, Gallery Forum | 22 | 04-01-2014 05:19 PM |
| short blocks? | 350matt | Engine, Exhaust, Transmission | 4 | 11-04-2013 08:37 PM |
| Billet Oil Catch Can #BC-175 by Billet Custom | Tim_Asphalt_FRS | Engine, Exhaust, Transmission | 48 | 10-27-2013 02:29 PM |
| ***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 1 | 10-07-2013 09:40 PM |
