Old 03-26-2014, 02:24 PM   #365
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
Will this work, hypothetically, with aftermarket inlets? Since it moves the intake manifold up about 36mm, wouldn't that make it more difficult for an inlet to reach the airbox? Or has this been accounted for?
XanRules is offline   Reply With Quote
Old 03-26-2014, 02:25 PM   #366
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
It should still work depending on which inlet you have.
Old 03-26-2014, 02:29 PM   #367
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
I'm still skeptical on this. Idk why, but I am.
husker741 is offline   Reply With Quote
The Following 3 Users Say Thank You to husker741 For This Useful Post:
86-tundra (03-26-2014), kodyo (03-26-2014), SmsAlSuwaidi (03-27-2014)
Old 03-26-2014, 02:31 PM   #368
XanRules
XanRules's Avatar
Supertek.
Old 03-26-2014, 02:32 PM   #369
Luis_GT
I'm skeptical your header won't leak... you should sell it to me...
Old 03-26-2014, 02:33 PM   #370
Thorpedo
The SquadWhisperer
Originally Posted by White64Goat View Post
If max HP is now at 6300-6400 instead of 7000, how is that a negative? Seems like less wear and tear on the internals to me. I know you'd like to see the HP continue to go up, but if this mod lowers the rpm's with the same amount of peak HP, it seems like a benefit to me.
I don't care about streetable RPM, I want top end for track days and Autocross. You should perhaps open your mind to the fact that people may use the car for what it was designed to do.
Thorpedo is offline   Reply With Quote
Old 03-26-2014, 02:34 PM   #371
husker741
Ok. $10,000.
The Following User Says Thank You to husker741 For This Useful Post:
Luis_GT (03-26-2014)
Old 03-26-2014, 02:35 PM   #372
hunter3232792
hunter3232792's Avatar
Drives: FRS
Originally Posted by shiv@vishnu View Post
Just got ours today. Testing/mapping will commence immediately. If results are positive and repeatable with no significant downsides, we will be offering them with the OFT. And yes, we expect to provide significant OFT dollar discounts to our customers
very interesting please keep us updated shiv!
hunter3232792 is offline   Reply With Quote
Old 03-26-2014, 02:41 PM   #373
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by BRZerk View Post
eh. easier said than done id imagine. injection molding tooling can be very expensive.
I could get one 3d printed for that price, but of course, that wouldn't be feasible on production item scale. Still, molds can be surprisingly cheap when sourced outside of the country. I know of a company that has custom molded polycarb parts on a scale that would be lower than what this would be and their end user price for a kit with multiple molded parts and some springs. Total packaged cost with shipping less than $40.
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Tim_Asphalt_FRS (03-26-2014)
Old 03-26-2014, 02:49 PM   #374
Boxer486
Drives: small
Originally Posted by nelsmar View Post
35.8MM
Thx. I can say these will not fit under a Hotchkis strut bar. At least for sure with the engine cover on.
Boxer486 is offline   Reply With Quote
Old 03-26-2014, 02:55 PM   #375
BRZerk
Some guy in a white car
BRZerk's Avatar
Drives: 2013 SWP BRZ Limited
3d printed would never last and i would never like that material in an engine bay near oil/gas etc.
it all depends on scale and mold/design complexity. something with this part volume is going to have significant wall thickness variations and will result in a lot of coring. to retain rigidity it will need ribs, this brings in the issue of side actions. With all these thickness variations warpage becomes an issue if you are trying to keep a flatness tolerance within spec. then you are going to want to use a nylon or other s/c material due to their ability to withstand the environment it is going to be used in. so yes it is doable. is it worth it? meh, billet is good enough for me.
2013 Subaru BRZ Limited 6MT - Satin White Pearl
BRZerk is offline   Reply With Quote
The Following User Says Thank You to BRZerk For This Useful Post:
Turdinator (03-26-2014)
Old 03-26-2014, 02:58 PM   #376
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
shiv for president
(one day this will really happen)
86-tundra is offline   Reply With Quote
The Following 5 Users Say Thank You to 86-tundra For This Useful Post:
ck-GT86 (03-26-2014), enjoi23 (04-20-2014), Proof (03-26-2014), Shiv@Openflash (03-26-2014), Walla Walla (03-26-2014)
Old 03-26-2014, 02:58 PM   #377
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Ugh...I'm going broke. This is going to be such a great summer w/ all the new parts
1Cor10:23 is offline   Reply With Quote
The Following 3 Users Say Thank You to 1Cor10:23 For This Useful Post:
DAN_BRZ (03-26-2014), Shiv@Openflash (03-26-2014), Superhatch (03-26-2014)
Old 03-26-2014, 03:06 PM   #378
Andrew025
Andrew025's Avatar
Supertek.
I'm gonna say yes.
The hose pieces they supply you with are kinda long.
billet, crawford, magic blocks
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 05:19 PM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 08:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 02:29 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
