Old 03-25-2014, 08:42 PM   #6175
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Did a few mountain runs. Loving the sun!
FRSfan111 is offline   Reply With Quote
Old 03-25-2014, 10:45 PM   #6176
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Hey are hub centering rings necessary for aftermarket wheels?
Some say no and others say yes
What are your thoughts ?
Sent from my SM-N900W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 03-25-2014, 11:52 PM   #6177
Oly86
Drives:
New Exhaust today !!!
Sent from my SM-N900T using Tapatalk
Oly86 is offline   Reply With Quote
Old 03-25-2014, 11:53 PM   #6178
Oly86
Drives:
New wheels today as well !!!
The Following User Says Thank You to Oly86 For This Useful Post:
*LongFella (03-26-2014)
Old 03-25-2014, 11:53 PM   #6179
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Installed the stage 2 LED kit for the dome light. It's awesome! Will get some pics up soon.
Jyn is offline   Reply With Quote
The Following User Says Thank You to Jyn For This Useful Post:
Oly86 (03-26-2014)
Old 03-26-2014, 12:00 AM   #6180
kavanagh
Fat on Corn Syrup
If you haven't changed a lot of wheels, it's a good idea to use them.
If you've swapped wheels on several different cars, and are confident in your star pattern and proper sequence of hand tightening a little at a time to get the rim to center and then a little more, and then a little more and then tighter and tighter following that star pattern, then you don't technically need them, as the lugs will center the rim when done properly. If you haven't done it before, grab the rings since they're cheap insurance. But get metal ones.
The Following User Says Thank You to kavanagh For This Useful Post:
Young_makaveli (03-26-2014)
Old 03-26-2014, 12:01 AM   #6181
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
What are the specs?
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 03-26-2014, 12:02 AM   #6182
Young_makaveli
Drives: 2013 frs
Why the metal ones ? don't the plastic ones do the same thing?
I heard that the metal ones can warp too
Old 03-26-2014, 12:03 AM   #6183
Oly86
Drives:
Front's are 18x8 225/40 rear's are 18x9.5 255/35.
Old 03-26-2014, 12:05 AM   #6184
*LongFella
*LongFella's Avatar
Mmmmm.... 255.... Nice!
I need to get wider tires!
Old 03-26-2014, 12:06 AM   #6185
Oly86
Drives:
Sunday I am putting on my intake and overpipe.
Old 03-26-2014, 12:07 AM   #6186
Oly86
Drives:
What do you have now?
Old 03-26-2014, 12:10 AM   #6187
kavanagh
Fat on Corn Syrup
Depends on how hard you plan on braking. If you track at all, you'll probably melt the plastic ones and they get stuck in the rim or on the hub. It's true metal ones can warp, but after they're on, their job is done. The lugs are what create the mechanical connection between the hub and the wheel. The rings just help you get the rim centered on the hub until you get the lugs hand tightened.
Old 03-26-2014, 12:20 AM   #6188
*LongFella
*LongFella's Avatar
225/40-18 Hankook V12's all around
I'm running gram lights 18x8.5 +33 square set up...
