Old 02-09-2013, 06:42 AM   #43
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by Pandle View Post
No. Anyway I'm having trouble getting the actual panel off. I've removed the silver trim and the 3 screws plus the plastic piece near the front of the door but I just can't get it off. Is there a certain spot I should start at? Possibly a video tutorial or a picture of what it should look like where you start pulling it off at?
Originally Posted by Honeydew View Post
How do you take of that silver trim piece on the handle???
You guys may have got this already, button remove the panel I started by the speaker. There are no clips there so it has a gap to get under.
For the silver piece go from the bottom to pull it off.
Old 02-09-2013, 07:11 AM   #44
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Great write-up! An audio install is one of the first things on my list to do when I get home, so this will be very helpful.
kmbkk is offline   Reply With Quote
Old 07-22-2013, 09:49 PM   #45
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Thanks! a great help this evening.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 07-31-2013, 11:57 PM   #46
laley81
Scion FR-S
laley81's Avatar
Drives: Scion FR-S 2013
Help got some coins stuck inside and they are rolling like there is no tomorrow when I move. I guess it's inside the door. I think it went threw the cup area. Do I have to take the whole door out?
laley81 is offline   Reply With Quote
Old 03-25-2014, 01:33 AM   #47
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
Thread revival! I accidentally rolled the window down with a parking sticker affixed to my window, when I rolled the window back up the sticker got lost down in the door. Will this get me to it?
2016 Scion FR-S
1991 Acura NSX
2012 Mazda Miata (Track)
2019 Triumph Bonneville Bobber
2007 Suzuki SV650 (Track)
akiranakayama is offline   Reply With Quote
Old 03-25-2014, 08:53 AM   #48
AdamBomb518
Stealth ***e
AdamBomb518's Avatar
Yes you'll be able to access it once the panel is off. You'll have to remove the plastic liner on the actual door skin itself to get to where the window track is. Reach down towards the bottom and you'll get whatever was dropped.
AdamBomb518 is offline   Reply With Quote
Old 03-25-2014, 01:21 PM   #49
akiranakayama
Sweet. Thanks! The plastic liner is glued on with that black goop. Will that stuff reseal properly if I just press it back on?
2016 Scion FR-S
1991 Acura NSX
Old 03-25-2014, 04:04 PM   #50
AdamBomb518
Stealth ***e
It should. It probably won't come off in 1 swift "swoop" though as that black stuff they use is pretty nasty. Some people recommend to take off when it's hot, I recommend when it's cold - because adhesive doesn't work as well in the cold so less residue.
I'm leaving mine off when I do my doors as I'm just doing a full sound deadening with Dynamat Xtreme and Dynaliner. That's an added expense though of course.
Old 03-25-2014, 04:08 PM   #51
akiranakayama
What the heck is the plastic sheeting for, anyway? I've heard some refer to it as a "vapor barrier"?
2016 Scion FR-S
1991 Acura NSX
Old 03-02-2015, 03:59 PM   #52
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Thread revival ... ok I need help ..I've looked at the window tsb but I had a hard time understanding the steps ..
Anyways ..over the winter my driver side window got loose somehow and I'd like to put it back in track ..anyone have pictures of exactly what I'm suppose to do? Would be greatly appreciated
Here is a short video of what I mean
[ame]http://youtu.be/BhuAdfvoOYs[/ame]
Thanks
Young_makaveli is offline   Reply With Quote
Old 03-27-2015, 05:44 PM   #53
Young_makaveli
Drives: 2013 frs
Thanks
Bump please help
Old 04-02-2015, 02:04 PM   #54
Young_makaveli
Drives: 2013 frs
Ok I will remove the door panel but how do I put the window back in track so it won't be loose ?
Old 04-03-2015, 04:40 PM   #55
Young_makaveli
Drives: 2013 frs
I removed the panel but I have no idea how to fix the loose window ...
The plastic that's behind the door panel ..can I just remove it and throw it away or is this necessary?
Old 04-04-2015, 01:12 AM   #56
That's a very important vapor and noise barrier. The inside of our doors gets very wet.
I used a razor blade to carefully slice away at the black adhesive stuff while stretching it to separate the plastic from the door.
The window adjustment is a different story. First off, your window doesn't look loose. It looks pretty normal. What else brings you to the conclusion that something is wrong?
Getting the window adjusted properly is a HUGE deal. I've had mine apart 3 times to tinker and get it just right. Last year I got a little ahead of myself and promised a DIY. Then I figured out how tricky the adjustment actually is. I'm still not confident I can explain it effectively.
Young_makaveli (04-04-2015)
Pillar Removal? kmbkk Electronics | Audio | NAV | Infotainment 2 07-12-2015 11:55 AM
Dent Removal 7thgear Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 10-23-2012 06:38 PM
Scion boost card? Mo707 Scion FR-S / Toyota 86 GT86 General Forum 30 08-01-2012 09:20 AM
Buying a car on credit card? SteelReign Other Vehicles & General Automotive Discussions 8 06-25-2012 12:54 AM
FR-S Badge Removal skoodge Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 12:46 AM
