#15 |
Drives: Monogram Firestorm
What keys should I expect to get with a new Monogram? My understanding is that the "key" will essentially just be a key fob. So I should expect to get 2 of those, right? Is there a "valet fob"? The actual keyhole is plugged/covered on Monograms, right?
#16 |
Drives: 16 CBS WRX Limited
You will get 2 fobs; no valet. There are physical keys in the fobs that can unlock the driver side door as well as the trunk. I believe that those are the only places where you can use the physical key. No hole in the passenger side door.
#17 | |
Noob
Drives: FR-S Mammogram
#18 | |
#19 | |
All this info is in the manual. |
#20 |
#21 | |
Drives: 2008 FT86 GTS
DIY
Yes, if you have still have one key in hand, it can be done. Using x100 plus, Toyota G chip supported. |
#22 | |
Drives: Subur / Scion
There are companies out there that are pretty reputable. When I got my key I made sure that the company had a customer service line so that I could talk to an actual human if there was an issue. This is not just to protect your money, but also to make sure that the job gets done. And it made all the difference. I made it through the entire list of instructions and it was not working. One more time to try and find my mistake...and still nothing. There was something really small that I would totally forget if I had to do it again. It was not on the instructions, but the person over the phone knew it somehow. Do what you need to do not to pay the dealership. It saves money, and seems like less of a hassle personally, then doing it yourself and hopefully leaning something (Just to prepare you, there is no real skill you get out of this, because the reprograming does not transfer to most other cars). |
#23 | |
#24 |
Bumping this. I recently bought my 2013 FRS used and the dealership only had one key for it. The local Toyota dealership quoted me $425 for a new fob, laser-cut key and reprogramming for the fob. Out-friggin'-rageous.
#25 |
Some info on the topic. Not sure but Toyota probably has something similar that I just can't find.
http://www.ft86club.com/forums/attac...1&d=1355508627
| issue with dealer setting lock options. | michaelahess | Electronics | Audio | NAV | Infotainment | 8 | 08-29-2012 12:26 PM |
| What options can be dealer fitted to the GT? | kharn83 | AUSTRALIA | 28 | 06-06-2012 07:43 PM |
| FR-S Purchased! Now Dealer Extra options...worth it? | FutureFT86 | CANADA | 10 | 05-22-2012 07:02 PM |
| Any pre-installed options when car arrives at Dealer? | frs23 | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 05-22-2012 03:57 PM |
| Dealer just called me about options & delivery | terrypm | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 05-07-2012 05:11 PM |
