Old 03-25-2014, 06:47 AM   #1
djmm
djmm's Avatar
Drives: toyota
Break-in for Auto transmission?
I've done search but it seems like all break in instructions/ opinions are related manual transmission cars.... any tips for breaking in auto cars? Thanks
djmm is offline   Reply With Quote
Old 03-25-2014, 08:31 AM   #2
Rakshaa
Milton 86 Club
Rakshaa's Avatar
Drives: Lexus IS350, GT86, Mini Cooper, CBR
I just picked up my AT monogram over the weekend. I'm no expert, but what I am doing is keeping revs below 4k rpm and making sure to not keep it at same speed for too long (I.e long highway drives). Also, I'm doing this for first 1600 kms/1000 miles
Hope this helps.
Rakshaa is offline   Reply With Quote
Old 03-25-2014, 09:20 AM   #3
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
No difference. If anything, there would be less concern with an automatic than with a manual transmission.
BRZfan is offline   Reply With Quote
Old 03-25-2014, 11:53 AM   #4
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
I would not be too granny on the gas. And even use the paddles to shift properly.
You want the car to downshift if you accelerate up hills. Sometimes if you granny the gas, the transmission won't downshift and you can lug the engine.
subiestyle is offline   Reply With Quote
The Following User Says Thank You to subiestyle For This Useful Post:
Blue14inTracy (03-25-2014)
Old 03-25-2014, 12:03 PM   #5
Snowball
Snowball's Avatar
Drives: 2013 Whiteout Scion FR-S
Hope this helps.
That's exactly what I did
Snowball is offline   Reply With Quote
The Following User Says Thank You to Snowball For This Useful Post:
Rakshaa (03-25-2014)
Old 03-26-2014, 08:31 AM   #6
djmm
djmm's Avatar
Drives: toyota
I'm more concerned of not being able to get to speed as I live around suburb - not many highways around so speed is most likely to be on low most of the time..
Old 03-26-2014, 09:04 AM   #7
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
You'll want to spend roughly 10% of your time in reverse between 2200-4100 RPM. Seeing that you're in Australia, you will want to convert that to metric. It's also important to only engage your windshield washers at an incline no less than 10 degrees and no greater than 17 during break-in unless it's daylight savings time. If you don't follow these directions perfectly, your car will explode as you are walking away from it in slow motion.
Just drive it like a normal person.
The Following User Says Thank You to SloS14 For This Useful Post:
bee_are_zee (03-26-2014)
Old 03-28-2014, 12:57 AM   #8
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Yup, just drive like a normal person.
It's not just the trans you're breaking in, it's the whole car. Brakes, suspension, engine-everything!
Old 03-30-2014, 03:09 PM   #9
onzippy
Drives: 2014 FRS
I've got an automatic too. Follow the owners manual procedure. Easy on the gas, avoid constant speeds, braking, etc... for 1000 miles.
At 1150 miles I installed a turbo and now I floor it...
onzippy is offline   Reply With Quote
The Following User Says Thank You to onzippy For This Useful Post:
Ocala FR-S (04-05-2014)
Old 04-05-2014, 10:30 PM   #10
Ocala FR-S
Ocala FR-S's Avatar
Drives: 2013 FR-S AT Argento
The FR-S in full auto mode will downshift before it lugs no matter how little throttle. You can however lug it by not downshifting while in manual mode.
Ocala FR-S is offline   Reply With Quote
Old 07-13-2014, 01:46 AM   #11
technoid
Drives: Silver BRZ
Drive it like you are going to drive it, starting day 1. Never had an issue with any car I bought new.
technoid is offline   Reply With Quote
Keep Auto Transmission or Switch to Manual Stayreal Engine, Exhaust, Transmission 41 03-23-2014 10:02 AM
Kits for auto transmission FR-S? Sparda29 Forced Induction 14 06-27-2013 12:34 PM
Auto transmission, really that slow? husker741 Engine, Exhaust, Transmission 82 03-22-2013 11:29 PM
Replace auto transmission at 60k? supramkivtt2jz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 03-09-2013 06:20 AM
WRB Premium BRZ Auto. Transmission Available! ShoShin BRZ First-Gen (2012+) — General Topics 1 11-16-2012 07:25 PM
