Old 03-24-2014, 06:51 AM   #71
newports
Drives: 2013 Scion FRS
Originally Posted by SurfAndSand View Post
I have no issues with mine making odd noises. My shocks are relatively new, so I have no roll when making tight fast turns either.
I would guess that unless you're some kind of special bad ass driver, that the super downs will be fine on the occasional track day. Just don't go off track - you definitely have less stroke. LOL.
Awesome thanks.
I think I'll go with the rsr supers. Stech are a little lower I think but I seriously think i saw only one negative comment abouy the rsr super downs while for the stechs its pretty balanced between people who liked it and didn't.
Plus if the ride is still as comfy as stock thats awesome.
newports is offline   Reply With Quote
Old 03-24-2014, 08:23 AM   #72
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
I personally feel the ride is more comfortable than stock. They're softer at low speeds
supramkivtt2jz is offline   Reply With Quote
Old 03-24-2014, 09:57 AM   #73
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Originally Posted by newports View Post
Awesome thanks.
This suspension is pretty darn stiff don't fool yourself into thinking its "comfortable" or youll be sorely disappointed.
The Following User Says Thank You to BlueDubbinTDI For This Useful Post:
supramkivtt2jz (03-24-2014)
Old 03-24-2014, 01:16 PM   #74
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
I find it to be incredibly comfortable at low speeds. The increased stiffness is evident at anything above 45 mph. btw, retorquing the control arm helped with our issue.
Old 03-24-2014, 01:45 PM   #75
BlueDubbinTDI
The shop discovered that same issue about 2 weeks ago and in the interest of time I asked if theyde fix it when i got my new exhaust installed by them and said absolutely. I ordered the exhaust last night so probably going to be fixed Saturday if it arrives by then. It's been a long 3 months of the rattles I can't freaking wait
Old 03-24-2014, 04:39 PM   #76
Wander
Wander's Avatar
Drives: 2013 BRZ Limited LR
Just installed the Swift BRZ springs the weekend before last. So far ride comfort hasn't really changed. The 1" drop looks fantastic, though.
Wander is offline   Reply With Quote
Old 03-24-2014, 07:46 PM   #77
newports
So there are rattles from this spring?
And I understand it will be much stiffer. How could it not be. But for springs being able to lower that much and people can still say it's comfortable as lower speeds that's good enough for me.
Old 03-24-2014, 08:37 PM   #78
BlueDubbinTDI
I believe the upper strut bolt is loose or something to do with the endlinks. I don't think it has anything to do with the springs.
supramkivtt2jz (03-25-2014)
Old 03-24-2014, 08:58 PM   #79
VuDism
NASIOC: AzNSTiImpreza
VuDism's Avatar
I have no rattles no noises. Smooth as eggs.
VuDism is offline   Reply With Quote
Old 03-25-2014, 04:58 PM   #80
SurfAndSand
8SiX
Drives: FRS 10series
The springs have a higher spring rate, and the dampener remains unchanged, other than it's riding an inch more into it's stroke pattern. It's probably more into it's "high speed" compression pattern, so is that why the ride feels softer to some?
I don't know how much of the stroke compression/rebound is caused by depth into the stroke pattern, and how much of it is speed related due to shearing of the oil in the shock.
But to me, although the ride is still okay, I would definitely say it feels stiffer than stock (but still tolerable) on a bumpy road. On smooth pavement though, everything is friggin excellent.
On another note, I've read somewhere that the spring rate is still within the rated specifications of the stock dampeners, but I can't confirm it. I mean, it must be, because they're designed the springs around them, right? I'm just wondering how much faster the stock dampeners will wear compared to the stock springs.
I installed my springs about 3000 miles into the life of my car, and right now, I have just about 7000 miles. They still feel pretty good. To all the other guys running similar springs (RSR, Swift, Eibach, etc) What kind of mileage do you have on your stock dampeners, and what experience have you had as they've worn in?
SurfAndSand is offline   Reply With Quote
Old 03-25-2014, 07:08 PM   #81
VuDism
VuDism's Avatar
Installed for about 500 miles. Car has 12500 miles
Old 03-26-2014, 12:04 AM   #82
SurfAndSand
8SiX
How are the stock dampers holding up?
Old 03-26-2014, 07:58 AM   #83
VuDism
VuDism's Avatar
Fine to me.
I installed eibach prokits in my 55000 mile GC8 impreza on stock shocks back in the day. Everything was fine
The Following User Says Thank You to VuDism For This Useful Post:
SurfAndSand (03-26-2014)
Old 04-25-2014, 11:01 AM   #84
TM
TM's Avatar
Drives: DGM BRZ 6MT
I noticed that the RS*R and Swift spring rates for the FR-S and BRZ are different. If I want more oversteer, would I be able to get RS*R or Swift FR-S springs for my BRZ?
Chart I made when comparing:
Last edited by TM; 04-25-2014 at 02:51 PM. Reason: oops, fixed - swift rates was backwards
TM is offline   Reply With Quote
Swift Springs BRZ TouchMyHonda Suspension | Chassis | Brakes -- Sponsored by 949 Racing 149 05-12-2015 12:33 AM
Prototype Swift Springs for FR-S mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 09-17-2013 09:36 PM
wtb:swift frs springs bkblitzed Want-To-Buy Requests 0 06-16-2013 04:03 PM
Swift springs rate ID subaruferrucci Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 04:26 PM
SWIFT lowering springs ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 10-31-2012 06:15 PM
