Old 03-24-2014, 04:56 PM   #4047
fenton
Originally Posted by stevo585 View Post
To change topic:
Why can't we make this a 36V system? I know the electrics are limiting this but I wonder if the motor can take it?
Or run high amp hour batteries so they can supply more amps @ 24V?
Just wondering why it is capped to 24V and 18AH batteries.
Yes we have a dual dump pack which up the total capacity at 24V.
Rob has made 36V systems, right now the sweet spot for gains is the 24v system.
The reason for the caps is to keep the price down. If Rob was to up to 36V and higher AH batteries the whole cost of the system starts getting close to full time FI.
Rob likes the price point he is at now at approx 50% of the cheapest full time FI build before installation and tuning.
fenton is offline   Reply With Quote
The Following 2 Users Say Thank You to fenton For This Useful Post:
DAEMANO (03-24-2014), HunterGreene (03-24-2014)
Old 03-24-2014, 05:32 PM   #4048
Robftss
Drives: VW
Originally Posted by Sojhinn View Post
The dual pack setup answers your question about amperage. It can be done and is being done currently.
As for the higher voltage, Im assuming there is a reason that @Robbfts can answer.
UL 508A Section 43 Low-Voltage Limited Energy Circuits
specifically 43.1.2
Buzzzzzzzt
Robftss is offline   Reply With Quote
The Following User Says Thank You to Robftss For This Useful Post:
Old 03-24-2014, 08:28 PM   #4049
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
specifically 43.1.2
Buzzzzzzzt
The Following User Says Thank You to SloS14 For This Useful Post:
raven1231 (03-25-2014)
Old 03-24-2014, 11:25 PM   #4050
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by SloS14 View Post
How how I wish I could post that in my classroom....
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Shiv@Openflash (03-25-2014)
Old 03-25-2014, 09:14 AM   #4051
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by HunterGreene View Post
If I had to guess, its compatibility with the car. Besides, if you up voltage, you decrease available current, unless I'm mistaken.
You are not mistaken. There is a finite amount of electrical power (watts) that you can take from the car's electrical system to recharge the batteries without major mods to the electrical system (read upgraded alternator).
Wattage is current times voltage. You can't increase the watts, so if you increase current or voltage, the other must be reduced to keep the watts the same.
Simple example:
12.5V x 80A = 1000W or
25V x 40A = 1000W or
50V x 20A = 1000W.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following 2 Users Say Thank You to mid_life_crisis For This Useful Post:
DAEMANO (03-25-2014), HunterGreene (03-25-2014)
Old 03-25-2014, 03:27 PM   #4052
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
PIE
power(watts) = I(current) X E(voltage)
oh, and don't ask me why I stands for current and E stands for voltage, It's been over 10 years since tech school. I think my teacher said C and V were already used.
Target70 is offline   Reply With Quote
The Following 2 Users Say Thank You to Target70 For This Useful Post:
Old 03-25-2014, 07:59 PM   #4053
dnavas
Drives: Elantra & UM A/T FR-S ex-Saturn
E = Electromotive force
I = Intensity
dnavas is offline   Reply With Quote
The Following 2 Users Say Thank You to dnavas For This Useful Post:
DAEMANO (03-25-2014), Target70 (03-25-2014)
Old 03-25-2014, 09:17 PM   #4054
R2
Originally Posted by Mars2 View Post
what speed where you cruizing? 180 km/h is 110 Mph or around 5000 rpm in six gear
at that speed on light throttle engine is on vaccum
You are looking at around 0.7g/rev of engine load at that speed in sixth gear.
Now, we need someone with an ESC and something to monitor engine load via MAF readings to do this experiment. You need to drive in any gear at 5000rpm, then use the brakes and throttle, modulating both until you you see ~0.7g/rev load at a constant speed. If the ESC drag reduction is activating then you have your answer.
Last edited by R2; 03-26-2014 at 12:21 PM. Reason: Corrected load unit from g/s to g/rev
R2 is offline   Reply With Quote
Old 03-26-2014, 02:51 PM   #4055
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Latest Configs
Guys, I have been following this thread eagerly and the more I learn the more I gain interest in purchasing. I have a few questions and thought it would be best posted here.
The 250 seems the best route to decent power and clean install, but what does the dual dump setup look like and does it require battery re-location?
Have different impeller, turbine wheels been tried and or with special coatings for compressor/turbine for thermal efficiency?
What about ceramic bearings in the motor or compressor?
Is battery re-location to trunk only for dual dump applications, can someone explain the benefits of this?
I am a total F1 geek and have been involved in many hobbies/builds involving hi tech so this is truly intriguing and this thread has been well contributed by Fenton, Gary in NJ, Shiv (who's shop is not far from me) and others. Thank you all!!
F1fletch is offline   Reply With Quote
Old 03-26-2014, 03:25 PM   #4056
Target70
Target70's Avatar
Here is shiv's post of his dual dump setup / and yes it requires the starter battery relocation: http://www.ft86club.com/forums/showp...postcount=3695
I don't know about the wheels or coatings, but with the low temporary boost, I think temperatures remain close to ambient, but I am just guessing.
I believe I was told the compresser uses sealed ceremic bearings.
Yes, with a single dump pack the smaller starter battery fits in the tray beside the dump pack. You can see a picture of this in the first post: http://s1277.photobucket.com/user/fe...76175.jpg.html
Also from the first post is this part which is under the Dyno Session Update: "We did another pull after this with a extra little battery pack that Rob rigged up and made ALMOST 210hp but we arent posting that dyno as that will probably be considered a power adder or something like that."
That extra battery pack, has turned into a second dump pack. I am waiting on shiv's next dyno post with his dual setup to see what type of performance boost the dual setup will provide, But from my understanding, it gives faster spool up, longer sustained boost, and higher peak power.
The Following 3 Users Say Thank You to Target70 For This Useful Post:
DAEMANO (03-26-2014), fenton (03-26-2014), Gums (03-26-2014)
Old 03-26-2014, 03:50 PM   #4057
Thatruth2001
Drives: Raven FR-S
Anyone with the ESC installed have plans to test the Crawford Billet Power Blocks? On the fence with my order, but wanted to inquire if anyone plans to be the initial test subject....
Thatruth2001 is offline   Reply With Quote
The Following User Says Thank You to Thatruth2001 For This Useful Post:
Crawford Performance (04-01-2014)
Old 03-26-2014, 03:53 PM   #4058
mid_life_crisis
You probably want to check out the thread for the blocks.
Shiv has a set.
Old 03-26-2014, 03:55 PM   #4059
Thatruth2001
Drives: Raven FR-S
Shiv has a set.
I know, but does he intend to test with the ESC or NA.
Old 03-26-2014, 04:00 PM   #4060
DAEMANO
Time Traveller
I think we might need to modify the intake hose connecting the compressor to the throttle body as the power blocks raise it. Am I right?
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
