Old 03-24-2014, 02:32 PM   #15
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Kinda off topic, but is there some other oil gallery port in the engine aside from the one right beside the AC compressor? I already have my oil pressure gauge hooked up to that port, and I'd like to run an oil temp gauge as well.
HRTROB is offline   Reply With Quote
Old 03-24-2014, 02:37 PM   #16
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
AFR/boost combo gauge, then oil pressure and/or temperature.
seconding this.
XanRules is offline   Reply With Quote
Old 03-24-2014, 02:40 PM   #17
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by mines13 View Post
When this goes in to production in the next couple of months it will be an excellent option. AFR, Boost (up to 44psi), boost control, boost cut by RPM and/or AFR, programmable shift light, and 0-5v analog output for AFR. You can also log solenoid duty cycle, manifold pressure, AFR and engine RPM to your laptop or iPhone provided you use it in conjunction with the OT2 device. You can also daisy chain this device with our other MTX-D series gauges to also log your oil pressure, oil temp temperature, etc. A ton of functions for a single gauge.
OBD2 or dedicated sensors? Im really not a fan of reading off the obd
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
OrbitalEllipses (03-24-2014)
Old 03-24-2014, 02:50 PM   #18
mike the snake
I'm not sure why the PLX gauge isn't used more. It can operate off your OBD port, and/or uses it's own sensor modules, and can display every parameter needed.
I'm getting oil temp, oil pressure, boost, coolant temp, and can add AFR, EGT, fuel pressure, and read all of these by simply pushing one button and scrolling through.
The only disadvantage to multiple gauges is it only displays one thing at a time.
I plan to leave it on boost or oil temp, and check the other values periodically.
Old 03-24-2014, 03:27 PM   #19
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Logging from ODBII port?
No, this product does not require an OBD2 interface. It will ship with a custom spec solenoid, 4BAR map sensor, and a WB02 sensor. You can optionally use it in conjunction with our WiFi OBD2 device, the OT2 but it is not required. As mentioned you can also chain it with other Innovate devices to log via the OT2 to your WiFi enabled Apple device, our PL-1 SD card logger or directly to a laptop.
mines13 is offline   Reply With Quote
The Following User Says Thank You to mines13 For This Useful Post:
mrk1 (03-24-2014)
Old 03-24-2014, 03:31 PM   #20
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The two popular ones are to tee off of the OEM low oil pressure sensor on the front driver side of the engine or get a fitting to replace the large plug on top of the engine below where the intake enters the throttle body:
http://www.rallysportdirect.com/Suba...il-Galley-Plug
With oil temp gauges you really have to be careful that you are reading the temp of the oil and not the temp of the fitting or metal. I normally like seeing those in the oil pan.
Old 03-24-2014, 03:48 PM   #21
mrk1
I'm about to put my temp sensor in the pan, I don't like how it fits in the sandwich plate.
The Build Thread
Old 03-24-2014, 04:14 PM   #22
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Thanks for the info! I already have that oem Subaru oil gallery plug hooked up to my oil pressure gauge. I'm having a hard time looking for a decent fitting to tee off the stock oil pressure sensor. I've only seen brass ones which are said to be weak. I know I could use an oil filter sandwich plate, but I'm already running one for my oil cooler and I don't want to stack another one
Old 03-24-2014, 04:16 PM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I think drilling and welding a fitting to your oil pan would be a good option or an aftermarket oil pan with a fitting already installed would be a better option.
Old 03-24-2014, 04:47 PM   #24
mrk1
An inline sensor manifold is another option, mount this on the hot side going to the cooler. Preferably as close to the motor as possible.
Im trying to reduce the amount of Tee's and adapters needed since every connection is a possible leak.
The Build Thread
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
Cheeseballs (03-26-2014), Hawaiian (03-25-2014)
Old 03-24-2014, 06:20 PM   #25
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Never seen one like that. Great idea since he is running an oil cooler.
Old 03-24-2014, 06:23 PM   #26
Calum
That Guy
Drives: 2013 asphalt FRS MT
You should make a sensor that can replace the factory oil pressure sensor, giving two outputs, one to your gauges and another to the cambus simulating the factory sensor. Make an oil temp gauge that can do the same and you'd completely eliminate the need for all these T's.
Old 03-24-2014, 08:25 PM   #27
diss7
Drives: AE86, 2x GT86, TE27
Personally I think gauges now a day are pointless.
Set your ecu to not allow certain parameters and let it do its job.
An ecu can react much faster than you can, thats if you're even looking at the gauge when something goes wrong.
diss7 is offline   Reply With Quote
Old 03-26-2014, 02:30 AM   #28
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
^^in worst-case, absolutely, fail-safes are awesome. One of the pluses for having gauges as well is that it's comforting having something there so you can have an idea of how things are running without having to log things to review later. Also helps you learn your car, and the state it is likely to be in, in a given situation. Constantly logging and reviewing is a pita.
OjiGeorge is offline   Reply With Quote
The Following 2 Users Say Thank You to OjiGeorge For This Useful Post:
Cheeseballs (03-26-2014), OICU812 (03-26-2014)
Just Another (Turbo) Build rb6freak Member's Car Journals 184 03-22-2017 09:25 AM
Do Boy's Turbo FR-S build!!! Do Boy Member's Car Journals 417 11-29-2015 02:17 AM
Turbo Kit & Shop Car Build Carolina Dyno Forced Induction 11 01-22-2014 03:59 PM
pick-a-turbo for beginners! subatoy Forced Induction 20 07-25-2013 07:09 PM
Gauges for Turbo, boost controller options? gdrider77 Forced Induction 27 05-13-2013 06:57 PM
