Old 03-19-2014, 07:52 PM   #323
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by Sniper2606 View Post
I did the installation.
Ill fill it out, but it shows that it must be sent within 30 days of purchase...bought this in june.
Call and explain what happened, tell them you didn't get the envelope with all the warranty stuff so you didn't know you had to send anything in
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 03-21-2014, 01:59 PM   #324
Dezoris
Dezoris's Avatar
What is the new part numbers for the idler and belt they switched to?
Old 03-21-2014, 03:16 PM   #325
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I ordered my kit January 2014. It came with a Dayco 89052 pulley and K060970 belt
HRTROB is offline   Reply With Quote
The Following User Says Thank You to HRTROB For This Useful Post:
Dezoris (03-21-2014)
Old 03-21-2014, 05:19 PM   #326
Sniper2606
Sniper2606's Avatar
They must have a lot of pulley issues. My kit came with Gates, you say Dayco, but when i called 2 weeks ago they said a ford pulley F8KZ-8678-AA......Gotta love it...
Sniper2606 is offline   Reply With Quote
Old 03-21-2014, 05:54 PM   #327
DJCarbine
Thupercharged
DJCarbine's Avatar
The ford part number you gave cross references to the gates 38006
2013 FRS
Vortech V3 11psi
Old 03-22-2014, 11:28 AM   #328
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Originally Posted by nelsmar View Post
The race unit can spin to iirc 62krpm vs 50krpm.
This seems to be dependent upon who answers the phone over at Vortech. I called again last week just to get some clarification on the H/D V-2 H67B compressor max RPM and this time I was told that the H/D V-2 H67B was 52,000rpm which is the same as the V-3 H67B compressor. I was under the impression the V-2 had a higher max RPM too but they insisted it does not this time around. Bummer cause I need more revs
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following User Says Thank You to AZFA20 For This Useful Post:
Sonolin (03-22-2014)
Old 03-23-2014, 04:20 PM   #329
nelsmar
Really? I was standing next to @Brian@Vortech when he got a text on the results. Maybe they re-tested and things weren't the same. Brian Chime in and help us out!! This sounds like someone was just confused when you called in 0.0
My flickr - Canibeat
Local magazine scout
Old 03-23-2014, 04:39 PM   #330
AZFA20
AZFA20's Avatar
I assumed perhaps now that there are more of the H/Ds on the street they have determined 52k is the new max. I am curious what Brian has to say about it too.
Old 03-24-2014, 12:35 PM   #331
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
I remember it being higher based on different bearing, either 55k or 65k rpm
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 04-08-2014, 02:18 PM   #332
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Going to be running the 4TF218-124 kit engine oil fed kit. Where's the best place to tap for the oil return?
It looks like here is the spot for the feed.
Easier to just get an aftermarket oil pan?
EDIT**Picked up the MAP aftermarket oil pan that's got the fitting and is a larger capacity.
Now, oil coolers. Looking at the Perrin/Mishimoto/Greddy/Etc.. where are you mounting the oil cooler rad at ?
FyeaFRS is offline   Reply With Quote
Old 03-12-2016, 06:19 AM   #333
GT86_2014
Drives: Raven
Hello Brian and Vortech team!!
I already have oil fed H/D V-2 H67B SC.
If I would like to exchange my blower for bigger one or rebuild it to get more boost and power.
Which way (rebuild or change) would you reccomend?
Is it possible rebuild my blower to T-trim (change impeller and volute) or send my you and pay some amount so you send me bigger unit which will fit to the existing place.
Thank you.
Please respond.
GT86_2014 is offline   Reply With Quote
Old 03-12-2016, 09:47 AM   #334
tirespin782
Drives: 02 s2k, 08 350z, 08 Fit sport
^The T-trim is a different blower though it has the same bolt pattern as the S and Si trims (the blower you have). Your current blower cannot be rebuilt into a T-trim since it's an entirely different blower. You can contact Vortech to see if they will give you credit on your current blower for the T-trim upgrade. The T-trim has straight cut gears so it'll be louder.
The s2k community has taken the Si trim to about 500whp (this author included though i was mid 400s last dyno). The impeller has been over spun without excessive high AIT with supportive bearings and few have reported destroyed blowers as a result. This is also with A/W heat exchangers.
HTH
tirespin782 is offline   Reply With Quote
Old 03-12-2016, 11:47 AM   #335
GT86_2014
Drives: Raven
HTH
Hi!!
T-trim is not only strait cut!
they have V2-Ti 1000 hp blower which is H/Cut,
so that's why question about upgrading my blower to T-trim ia actual..
I might need new impeller and also it's housing, bolt pattern is same..
upgrade seems to me much cheeper than exchange because V2Ti or V7Ysi cost is about 3500$ and Vortech will credit for my blower about 700 only as for any used blower..
Also question is about how much power (parasitic) I will loose in case of using such big 1000hp blower as V2Ti or V7 because I think that 2.0L engine will have to "work much harder" to spin that monster...
My heads and engine are fully built with 10CR so I want to try to get close to 600hp with supercharger setup.
That's my idea..
I did't find any 500++ or 600hp setups with SC, turbos only..
so I might be first in that...
but I need help from Vortech...
Vortech make nice SChargers but their customer support is so ..... let's say not good They never reply.... I sent many letters during two years
Only Brian helped me a lot here, but now hi is not accepting any pm's because his mail box if full
that's why I'm trying to get in touch with him here...
Old 03-12-2016, 12:43 PM   #336
tirespin782
I spoke with vortech about this very subject and they told me I could not upgrade/rebuilt the blower. This was 3 years ago and they haven't updated their website since then (at least from what I could see). At one point you could upgrade to the T trim, but the vortech rep I spoke to said that was no longer supported. If you wanted to go the T trim route, the outright purchase was the only method to get there via vortech.
This is why the S2k community just "overspins" the novi 1200 ( Si trim) for 500 whp. 600 whp was achieved with a novi 1500 blower (T trim). However, it appears the fa20 runs around 80 whp less than a similarly FI'd f20c (I'm thinking the "extra" 1200 rpm helps) so you may need to go right to the novi 1500 for 500 whp.
There is always the option of doing your own work via superchargerrebuilds.com and add your own impeller and high speed bearings, but vortech may no longer service your blower after that.
HTH
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
aFe Power/Takeda Air Intake System and Exhaust aFePower Engine, Exhaust, Bolt-Ons 10 08-06-2012 03:03 PM
