#533 | |
AutoX Nut
Drives: 2020 Toyota Supra
#534 | |
Dismember
Drives: 2013 Red Scion FR-S
#535 |
Drives: 2013 Subaru BRZ
I'd vote for going with the OFT stage one. Supringly it made a pretty noticable difference in my car. And I probably have the world's least sensitive butt dyno, lol.
#536 | |
Dismember
| The Following User Says Thank You to EAGLE5 For This Useful Post: | reardrv (03-23-2014) |
#537 |
As you can see below it's completely legit, and it does a really good job of getting rid of the torque dip.
| The Following 2 Users Say Thank You to reardrv For This Useful Post: | EAGLE5 (03-24-2014), Shiv@Openflash (03-23-2014) |
#538 |
Drives: 2013 FRS
I'm genuinely happy you guys are enjoying our OTS tunes. Just one favor through, could you refer to them as "Openflash Tablet" or "OFT" tunes instead of "Shiv's" tunes because while I don't mind being given credit, it would help our business if some mention of our product was mentioned
OFT sales is what keeps the map development machine going after all!
#539 | |
Dismember
| The Following User Says Thank You to EAGLE5 For This Useful Post: | Shiv@Openflash (03-24-2014) |
#540 |
Done! And on a side note I can't wait until my OFH comes in so I can try out the Stage 2 tune. Hopefully its coming soon!
| The Following User Says Thank You to reardrv For This Useful Post: | Shiv@Openflash (03-24-2014) |
#541 |
NASA SpecE30 Racer
Love the butt dyno making more torque than horsepower, haha.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#542 |
Drives: 2008 Bmw 335i
Alright, I'm new to EcuFlash and looking for a little help. I have read through tons and tons of posts and tutorials. Spent hours reading, but i'm not 100% sure and just want some clarification.
So i have a tactrix cable, a 2012 frs, the beta ecu flash installed, and i downloaded all the definition files. This seems like a stupid question even to me, i think i already know the answer to it, i want to re-flash with a OTS Map, do i need to use the same ecu? Say i have ZA1JA01C.bin do I have to use a modified ZA1JA01C.bin or can i used a ZA1JB01C.bin already tuned? And would I be able to go back to the stock bin? It seems like i can but it seems like no one says yes specifically. More so, could i flash any FRS Rom on to my FRS as long as it is MT and US? |
#543 | |
Drives: FT86
WARNING !!! Tectrix/ecuflash will let you flash any ROM to your car regardless of if is suitable or correct. It will READ any ROM but it will not WRITE one without a corresponding definition file. It has no safeguards unlike the Open Flash Tablet which checks ROM type for you and is much more user friendly. You will also need to install the Updated 32bitbase file for ECUflash else this may end in tears. Assuming you have 1. Correct version of Ecuflash BRZ Beta 2. correct definition files for your ROM type and the alternate ROM type you want to flash 3. Correct 32Bitbase file for BRZ 4. update the firmware in you tactrix by going to the licensing tab in Ecuflash first. Read you stock ROM first and save it as SRF and BIN to save as bin you need correct def files. you cannot write a ROM without matching Def files. Open the ROM in ecuflash and make sure the tables look ok and readable. Try writing you stock BIN ROM file first then move onto writing an alternate ROM. I believe A01C and B01C ROM are comparable but you will need def files for both to be able to read and save you A01C ROM and write the b01C ROM. Understand what you are doing and have a backup plan if it goes south. |
| The Following User Says Thank You to steve99 For This Useful Post: | stugray (03-26-2014) |
#544 | |
Dismember
The only thing I do for safety is make sure that I can read the ROM before I write a new one. This just makes sure that the connection is secure. A couple of times, I had a bad connection and the read failed. Would have been bad during a write.
#545 |
Thanks for both your quick replies.
I received my tactrix cable yesterday, and last night, i started with a friends 05 wrx, and flashed it with a stage 2 xpt tune. Everything worked out fine, using the bets ecu flash. Then I decided i would try the FRS. I read the rom, no issue, and then I wrote the stage 1 OTS map. The whole process took less than two minutes on the FRS. The only thing I thought was weirg, on the WRX I had an option to test write the ecu. The FRS had no test write option. The FRS was B00C, So i decided to stay with that rom for now. |
#546 | |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
| Close | iJason | Member's Car Journals | 1 | 08-04-2013 08:26 PM |
| Close | pche | Engine, Exhaust, Bolt-Ons | 3 | 08-04-2013 02:04 AM |
| Sorry. please close. | finch1750 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-31-2013 01:00 AM |
| please close | abutterman | Wheels and Tires | 0 | 07-05-2013 09:40 AM |
