| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 | |
PROUD OF BOXER
Drives: Raven FR-S
...... what is scary about it?
#16 |
Drives: 2013 GBS BRZ Limited
Whoa! wait. I dont see dual springs in that pic above.
These engines dont have dual springs? I thought valve float was an issue above ~6k unless you had dual springs.... |
#17 |
Drives: 2008 Civic Si
shit works fine lol.
#18 | |
Now i rev to 9000 rpms with 88lb dual springs. |
#19 |
AIM4APX
Drives: 2013 WRB BRZ Limited
55k on my odometer and I don't think there has been any loss. I also don't notice any hesitation, or idle issues. I've been running 93/E10 pretty much the whole time aside from a couple tanks of 91 when in Iowa.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#20 |
Basically my post was to say, single springs aren't really the limiting factor on revving high. It's more dependent on your camshafts and the springs ability not to coil bind and hold the seat firm.
#21 |
#22 |
PROUD OF BOXER
Drives: Raven FR-S
negative. it wont hurt anything.
#23 |
On intakes that are REALLY clogged up with carbon buildup, I wondered whether Seafoam might break large chunks of carbon loose that then find themselves stuck in, or clogging up the catalytic converters.
I did read that the stuff works. On DI-only cars, it can't be added to the fuel because no fuel touches the intake ports or valves, so it needs to be sprayed into the intake, upstream of the valves. |
#24 |
Drives: Sterling BRZ Ltd
Run a catch can and drive it like its meant to be, let it warm up. I'm not a fan of any of those sea foam cleaners.
Even with the port injectors I believe we will see problems with these motors and build up when they are older and higher miles.
#25 |
Drives: 2015 Series.Blue
Read the MSDS on Seafoam and you'll know why it's in a steel bottle instead of aluminum...
(hint: I'll NEVER use the stuff) |
#26 |
With all the "snake oil" products on the market, Seafoam is one of the only products I've seen old-timers and knowledgeable people say actually works.
It has many uses, as a gas and oil stabilizer for storage, engine and trans cleaner (I read about people adding it just before rebuilding or working on stuff because it cleans everything so well). It also works to soften and remove carbon on valves and combustion chambers. It does work. That said, I wouldn't use it on my new car personally. |
#27 |
Has a million uses...uses that destroy engines, transmissions, catalytic converters...
#28 |
Drives: FR-S 6MT
| eguerin's SSM/Carbon BRZ Build | eguerin | Member's Car Journals | 9 | 07-08-2014 03:53 AM |
| JUN carbon intake box | Kakawate | Engine, Exhaust, Transmission | 2 | 11-19-2013 11:53 PM |
| AIRAID u-build-it intake system | swift996 | Engine, Exhaust, Transmission | 9 | 03-19-2013 12:33 PM |
| Carbon fiber intake | Hawk77FT | Engine, Exhaust, Transmission | 17 | 01-17-2013 03:58 PM |
| dual injection is just a long overdue solution to carbon build up? | Hasjwandje | Engine, Exhaust, Transmission | 19 | 11-08-2011 05:53 PM |
