Old 03-16-2014, 04:08 PM   #183
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by s2d4 View Post
How would you do OL MAF scaling?
Would I still need it is my LTFT is always between -2 and 0?
the easiest way to do ALL scaling is to turn off all fuel trims and run full time open loop, Then you can do the entire maf curve in one shot from idle to the rev limiter. However, this is dangerous for newbies to do since you could end up running very lean if your scaling is way out. Using this method all you need to know is actual afr and target afr and maf voltage. Correction = actual afr / target afr.
The Following User Says Thank You to mad_sb For This Useful Post:
s2d4 (03-16-2014)
Old 03-16-2014, 04:11 PM   #184
s2d4
s2d4's Avatar
Originally Posted by mad_sb View Post
actual measured afr
What is the AFR in his equation then?
Old 03-16-2014, 04:35 PM   #185
nelsmar
Originally Posted by Snoopy_TXR View Post
That's true and I acknowledge that. I'm stubborn and hate the look of the stock intake so I guess I'm SOL.
I guess I won't be purchasing an OFT until someone here who has the knowledge to tune/adjust the run too rich with the 2.5" Perrin CAI.
I can only hope someone with knowledge will figure this out and share a stepxstep, DIY. for us cheap noobs lol!
I posted a near step by step above :P I just didn't type 1. 2. 3. James had posted quite a bit and there is more on the rom raiders forums with basic information as well
Target/Requested AFR.
My flickr - Canibeat
Local magazine scout
Old 03-17-2014, 03:52 AM   #186
Kodename47
Kodename47's Avatar
Drives: UK GT86
AFR is the ratio that is logged. AFRx is the adjusted AFR after taking into account for the trims, ie the AFR that would be produced if the ECU wasn't adding or removing fuel. This allows you to use a log with any LTFT included.
Once your LTFTs become zero, it becomes as simple as how @mad_sb described.
I did a fair bit of reading into MAF scaling and now have it down to a T. It's simple once you get your head around it, massively helped if you can use macro based Excel as the tools are already out there. I had to build my own spreadsheet as I can't.
.: Stealth 86 :.
Kodename 47 DJ:
s2d4 (03-17-2014)
Old 03-22-2014, 08:00 PM   #187
ScionFrsFan
Not sure if it's been said on another thread, but the base tune on a completely stock car...how much faster is it to 60? I understand it makes the car "feel" better but I'm curious on how much faster it really is. I had the Unichip about a year ago and I enjoyed that, but ended up selling because of E85. Thanks!!!
PS: I drive a auto
ScionFrsFan is offline   Reply With Quote
Old 03-22-2014, 08:40 PM   #188
Sonolin
PS: I drive a auto
I'll do you a favor and try to get a semi-accurate way of reading this on vid and do a completely stock vs. stage 1 vs. e85
No guarantees, no hard launches. Don't want to destroy my axles.
Sonolin is offline   Reply With Quote
The Following User Says Thank You to Sonolin For This Useful Post:
ScionFrsFan (03-23-2014)
Old 03-22-2014, 08:57 PM   #189
Proof
Proof's Avatar
Drives: 2007 STI Limited / 2014 BRZ Limited
Had a chance to really test out the Stage 2 EL E85 flash today. Ran a second full tank of E85 on a nice long road trip. Once at our destination I was able to fill it up again for a 3rd full tank and go on a 3 hour rally. With plenty of time for the ECU/DME to adapt I had a few good pulls with the butt-dyno agreeing that gains were there. No hick-ups at all in starting or running. Torque dip is mostly gone for me even running a stock header and cat.
Best money I have spent on any car I have owned / modded to date.
Proof is offline   Reply With Quote
The Following 3 Users Say Thank You to Proof For This Useful Post:
Garrett@Openflash (05-29-2014), Robert@Openflash (05-30-2014), Shiv@Openflash (03-22-2014)
Old 03-22-2014, 09:58 PM   #190
steve99
Drives: FT86
Might be more repeatable just to do a rolling 3rd gear from 2000-7000 log it then find the time and compare
Sonolin (03-24-2014)
Old 03-23-2014, 03:29 AM   #191
ScionFrsFan
That would be amazing!
Old 03-23-2014, 08:39 AM   #192
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I have not seen any. I only found scaling for the 3".
http://www.ft86club.com/forums/showp...&postcount=850
Old 03-24-2014, 03:59 AM   #193
Sonolin
Thank you, I'll try to do this as well.
Just filled up with gas so plenty of time to get it done before my next tank which will be wonderful wonderful e85
I'd also like to say I highly doubt the gains are as good as I think they will be. But that's ok because it just *feels* way better than 91, I don't care about the numbers when my brain is telling me YES.
Old 03-24-2014, 05:16 AM   #194
uncivilised
Drives: 86 GT
any way to change the oil temp to read in *c rather than *f?
uncivilised is offline   Reply With Quote
Old 03-24-2014, 10:33 AM   #195
s2d4
s2d4's Avatar
Quick rule of thumb. Minus 30 then divide by 2 will get you very close to degrees Celsius.
The Following 4 Users Say Thank You to s2d4 For This Useful Post:
BuBlake (08-15-2014), DC2R (04-16-2014), leicaboss (03-24-2014), unsurety (06-08-2014)
Old 04-15-2014, 07:30 PM   #196
ScionFrsFan
Any 0-60's?
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
***VISHNU OpenFlash Tablet IN STOCK*** Garrett@Openflash Engine, Exhaust, Bolt-Ons 15 12-17-2013 01:30 PM
Vishnu OFT tablet software mod request... Tromatic Software Tuning 5 12-07-2013 07:52 PM
FS: Vishnu OpenFlash Tablet - Unused, Mint Condition AyJay Engine, Exhaust, Bolt-Ons 6 11-09-2013 11:45 AM
