#3935 |
Long Distance Driver
Installed, used grimspeed header gaskets and now a leak has been presented on the right passenger flange. gunna drive around and hopefully something happens...if anything.
its about 1 inch away from the TRD intake by the way. Coated is the way to go!
| The Following 3 Users Say Thank You to Sargy For This Useful Post: |
#3936 |
Fanboy
Drives: 2013 ultramarine frs
Got a surface temp gauge? Be interested to know what the temp is on that pipe.
Also an exhaust leak won't fix itself. Get under there and tighten it up.
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#3937 |
Drives: 2013 Scion FRS
Good thing I got it coated + heat reflective tape! Do you think it could melt it even if coated?
#3938 |
Fanboy
An inch of air is a lot of thermal insulation particularly when it is moving air.
#3939 |
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
how long would be the wait if order one today?
#3940 |
Yeah an inch is probably enough space to keep anything from melting. I didn't relocate my radiator fan plug when doing my P&L coated header and it has about 1/8" between the two and it hasn't done anything to the plug.
Great results after the tuning especially on pump gas. I'm interested in some of the fit issues though since the P&L went through the same pains and they ended up fixing/replacing a portion of the header to change the angle it connects to the overpipe. Also not a fan of people having to crank down on the flanges to get them to seal, the P&L was perfectly flat and aligned on both sides. |
#3941 | ||||
Drives: 2013 Asphalt FR-S
Also I believe the OP stated he has a stock midpipe along with an axle back. My comment was the stock midpipe could be holding back the power at higher rpm. Guys, my issue is not the gains, it is where the gains are. I don't want a header that is as biased as this one seems to be below 5k. Where do you spend most of the time on a road course.. 5k plus. Autocross and daily driving is where this header will shine and I do not autocross. What i want from a header is to fill in the torque dip (not turn it upside down) and give the biggest gains from 4k and up. If anyone wants to buy my coated never installed header shoot me a pm with a reasonable offer. I may wait a few days before i make a final decision.
~Namaste~ |
| The Following 3 Users Say Thank You to mad_sb For This Useful Post: |
#3942 | |
Fanboy
| The Following User Says Thank You to FrsDuke For This Useful Post: | mad_sb (03-22-2014) |
#3943 | |
Drives: Scion Fr-s
Here's a pic of how close it is
#3944 |
The way this header turns the dip into a mountain is quite impressive. I am concerned about how much it intrudes into the engine bay and the effect of all that heat on the surrounding components (belts, etc.).
2022 BRZ Build 2013 FR-S Build |
#3945 |
Drives: Raven FR-S
#3946 | |
Kuruma Otaku
We get an expansion pulse at every cross section change. Primary to collector 1, secondary to collector, pipe to atmosphere. These expansion pulses are what drive the rpm specific gains or dips. And tubing length changes the return timing, since the waves travel at the local speed of sound. So we can change when the good wave gets there (also what you are chasing with your valve timing tuning) but we can't tell that gain to split itself and divide into two different rpm ranges. If it comes back at 4000rpm, you get all of the VE gains thereabouts. The 4-2-1 concept is to add another expansion to the 4-1's single expansion. This is as close as you can get to 'dividing' the waves into two positions. We could get another useful expansion with a pretty short exhaust (think side pipe) but practical applications say nope. This header we always knew would be AutoX friendly, but it is also track day and road course friendly, by how much corner exit should be improved. Top end is for drag racing. To get what you want, it will probably take a complimentary intake manifold for your current 4-1 that fills in the midrange a bit.
Because titanium. |
| The Following 3 Users Say Thank You to Dimman For This Useful Post: |
#3947 |
You could simply put some reflective tape like the gold stuff on the airbox if you want but that's a pretty decent margin between the two, I certainly wouldn't be worried about melting anything.
#3948 | |
Your point is taken. Most of what I had read indicated that with a 4-2-1 design you could optimize the length and diameter of the 3 stages to get 3 harmonics to build the power across a broader rpm range than you could with a 4-1 design. I would like to see a shoot out between the new revision JDL 4-1 and the Nameless, with an unbiased tuner. I'm not giving up on this header yet, like i said, i think the stock midpipe was likely squeezing the gains from 5k and up. But i am also going to hold off a bit on the install since the value will drop the second the flanges touch the block ![]() EDIT: I went back and looked at the plots nameless posted from the final revision... Those results look smoother through the 4-6 range and less peaky... way more of what i was expecting.. I know it's silly to be complaining about "extra" torques in some areas.. i am ocd about dyno plot shapes though because I know how the shape translates to the seat of the pants.
~Namaste~ Last edited by mad_sb; 03-22-2014 at 09:45 PM. |
| Tags |
| 21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag |
| Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 03:23 AM |
| Nameless Performance Axleback is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 114 | 07-23-2012 11:38 PM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 05:57 PM |
| We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-19-2012 12:32 AM |
| Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 05:32 AM |
