Old 03-20-2014, 02:28 PM   #1163
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by FullBlown View Post
You and Kingtut must of had our first two kits. All the issues have been addressed since.
It doesn't matter if you purchased it used or not. If you have any issues, hit us up and we will take care of you
I should have had the first one. I sold the car before LJ could take care of me.
Old 03-20-2014, 02:58 PM   #1164
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Where did the car go? do you still talk to the owner?
FullBlown is offline   Reply With Quote
Old 03-20-2014, 03:11 PM   #1165
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I have not heard from him since the week after I sold it to him. He was a local guy in Destin, FL. None of the locals have seen my car either since I sold it to him. I hope it is still running well.
Old 03-20-2014, 09:30 PM   #1166
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
Originally Posted by Sterz View Post
Seriously it is the only issue that I have had so far. It wasn't just the fitting of the XRP lines that are leaking. It is literally coming out of the ENTIRE line. It looks like the entire line is sweating oil.
Then oil most likely soaked the lines. Not from the inside out. The oil soaked into/through the braid so it appears to be weeping though the line. Same thing with the lines supplied with the kit. When they leaked we had oil EVERYWHERE. It was even pooling on the bumper beam as it ran down the lines from the sandwich plate.
XRP is considered a step above Earls and Russell. I could have used Earls too, but Earls fittings are not as good as XRP (even the anodizing on Earls fades fast) imho. I am intrigued, do you have the lines still? If I send them in for testing and they have failed I should be able to get some kind of a refund for you.
Infamous Performance is offline   Reply With Quote
Old 03-21-2014, 08:05 PM   #1167
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
any opinions on this for Drag Racing
ill be using Sparco Rims (rears only) 20 lbs
http://www.tirerack.com/tires/tires....cleSearch=true
Old 03-21-2014, 08:09 PM   #1168
Dipstik-sportech
Dipstik-sportech's Avatar
Would be better than a straight up street tire but not as good as a real drag radial.
The Frozen North
Old 03-21-2014, 08:27 PM   #1169
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
The Frozen North
what do u recommend and what size for a 18x8
Old 03-21-2014, 08:49 PM   #1170
Dipstik-sportech
I'd step down to a 17" to get more sidewall for better bite but if you're set on an 18" I'd run the 245/40-18 in the soft compound
The Frozen North
Old 03-21-2014, 08:52 PM   #1171
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
The Frozen North
so 17s i can get 255/40 but i was thinking of keeping my 18s in the front and just buy for the rear
what brands do u recommend for 245/40/18
Old 03-21-2014, 08:55 PM   #1172
Dipstik-sportech
R888's are a deadly tire. it's hard to find ones in the short sidewall sizes that actually work well.
http://www.tirerack.com/tires/tires....R888&tab=Sizes
The Frozen North
Old 03-21-2014, 08:55 PM   #1173
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
if youre getting special drag only rims, there are some really light weight 16's that are a lot easier to find rubber for. and cheaper.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 03-21-2014, 10:39 PM   #1174
Sterz
Great White
Drives: 2013 Whiteout FRS
The Frozen North
I am running R888 in 245/40/17, On a 8 psi speed density tune I can't spin the tires in any gear except first. These things are STICKY. Also did a 1:29.508 at streets of willow with zero upgrades except for the tires. Everything else was stock. They are amazing.
Sterz' Great White 86
http://www.ft86club.com/forums/showthread.php?t=54533
Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe
Sterz is offline   Reply With Quote
Old 03-22-2014, 01:47 AM   #1175
Dipstik-sportech
Yup they're a great tire and I'd be running them if I had the cash
The Frozen North
Old 03-22-2014, 09:58 AM   #1176
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
are u running r888 all around?
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
