Old 03-19-2014, 10:38 PM   #1
mswhong
Drives: FT86
Which EBC?
Hi guys,
I currently have the AEM failsafe - was wondering which EBC you guys use? I really want utilise the failsafe function and was wondering if there are any models that fit below the aircon/heating controls, in that little tray area.
Cheers!
mswhong is offline   Reply With Quote
Old 03-19-2014, 11:01 PM   #2
mrk1
Drives: Sterling BRZ Ltd
Maybe try turbo smart eboost street, it's small and rectangular.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
mswhong (03-19-2014)
Old 03-19-2014, 11:24 PM   #3
mswhong
Drives: FT86
would the 2.72bar sensor be sufficient enough for when I build my engine? Looking into doing so later on the down the track
Old 03-20-2014, 12:04 AM   #4
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
I use a COBB 3 port so my boost is electronically controlled via the ECU (and therefor switchable via maps on the fly thru EcuTek).
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following User Says Thank You to woode For This Useful Post:
mswhong (03-20-2014)
Old 03-20-2014, 03:43 AM   #5
mswhong
Drives: FT86
Unfortunately I'm not going down the path of ecutek.
Will be using a haltech unit as I live in Australia - that said, i would still like an EBC.. will most likely be using the eboost1 at this point
Old 03-20-2014, 07:57 AM   #6
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Same as Grimm Speed: http://circuitse7en.net/fantcube/ind...d&productId=13
OjiGeorge is offline   Reply With Quote
Old 03-20-2014, 09:39 AM   #7
mswhong
Drives: FT86
^I was after an EBC not a manual one, which I presume that one is
Old 03-20-2014, 10:02 AM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by mswhong View Post
Hi guys,
Cheers!
I had the GFB G-Force II and it fit in that little tray area. I would just pull it out when I wanted to adjust it:
Old 03-20-2014, 09:03 PM   #9
mswhong
Drives: FT86
OO that looks nice and simple - here in australia EBCs are deemed illegal so something like that would be nice.
Cheers!
Old 03-20-2014, 09:54 PM   #10
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
I tried both Turbosmart and AVO EBCs, they both work well if you know how to set them up right, but its not as simple as 10 PSI = 10 PSI, you have to set wastegate duty cycle and gain settings to achieve the proper boost at the proper rate.
Pure Automotive is offline   Reply With Quote
Old 03-20-2014, 10:46 PM   #11
mrk1
Is this all that difficult? Arn't those adjustments the advantages of a EBC over a manual.
The Build Thread
Old 03-21-2014, 12:13 AM   #12
OjiGeorge
OjiGeorge's Avatar
It's actually a solenoid that is run by your ECU (EcuTek tune). The Grimm Speed boost solenoid is a popular option for subie owners as a direct factory replacement. Best to check out Grimm Speed's site, as they have done a better job at marketing it, even though it's the identical solenoid. This route is more integrated than a stand-alone ebc, as you can have different maps/boost settings that change in tandem via your ecu map. Ie. one for race gas and one for crap gas. Just switch the map the way you normally would via the cruise control stalk, and instant change to different maps/boost settings.
You can also easily wire the AEM fail safe gauge to provide boost-cut to the solenoid so your boost drops to wastegate spring pressure if the AEM gauge detects anything off.
The Following User Says Thank You to OjiGeorge For This Useful Post:
mswhong (03-21-2014)
Old 03-21-2014, 12:16 AM   #13
OjiGeorge
OjiGeorge's Avatar
Just noticed that you won't be using EcuTek.. not sure about the Halteck's abilities for controlling a boost solenoid.. but for the price I'd assume it can? If EBC's are illegal in Aus, this is also a much more stealth way to have ebc without an external controller.
Old 03-21-2014, 12:26 AM   #14
mswhong
Drives: FT86
hmm, that is some very useful insight - Say I get that boost solenoid, I wouldn't need to purchase an ebc as the solenoid can tap into the AEM failsafe so I can enable it's failsafe function - am I on the right track? EBCs are freaking expensive down under, the turbosmart eboost cuts close to $800 AUD - the boost solenoid would be a much cheaper option at this point for me.. might have to take up your offer on that if that is the case!
I would also assume that the haltech unit can be wired up to solenoid you linked me to - I mean, you would expect it to when I am paying something close to $1200 for the Platinum Sport 1000.
