Old 03-19-2014, 04:36 PM   #99
ericvanderwoodsen
ericvanderwoodsen's Avatar
Drives: 2013 SWP Subaru BRZ Premium
Originally Posted by Lithium View Post
It will, I would advise you to use a connection on the source wire (DRL 12Volt). I personally life delphi connections myself
http://www.mouser.com/Search/Refine....233+4294759211
Thanks, I like those connections. I'm not to picky about the lights coming with the headlights, is there a way to have the DRLs to a switch and them on manually when the headlight are on? Reason is I'd love to have them on the highway but not in the city.
ericvanderwoodsen is offline   Reply With Quote
Old 03-20-2014, 10:45 AM   #100
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
I think I'm going to tackle this mod this weekend, and will probably build a "harness" like @modena mentioned so I don't have to solder diodes on the car.
Originally Posted by modena View Post
To make the install a bit easier, solder the diode between your wires.
Just made one in about 5 minutes, (To take some pictures)
Shrink-tubed my cable from the headlight to the DRL's to make it look like a wiring harness.
(If you wouldn't know you might think it was part of the car)
A connecter on the DRL side will make it easy to disconnect when removing the bumper.
If I'm digesting things correctly, I would cut the green wire to the headlight connector, connect the car-side of that to the the black lead in modena's wiring rig, and the right-hand red lead to the connector-side of the cut green wire. To keep the DRLs from turning on with the main headlamp beam I would stick another diode on the left-hand red lead (cathode toward the headlamp end of things), and connect the end of that red lead to the white wire on the DRL?
Am I close?
codesplice is offline   Reply With Quote
Old 03-20-2014, 11:45 AM   #101
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by EvilBeaverFace View Post
Happened to notice that when I finished one side and turned my lights on that both of my DRLs stayed on and it kind of surprised me, shouldn't only the side I completed stay on? It doesn't really matter and isn't important I was just curious.
Just to be clear. After you did one side, both DRL came on, but only one boomerang lit up, when DRL is turned on. Is this correct?
BTW, awesome write-up, Lithium. I would do this, but I've never soldered anything before. Makes me kind of nervous.
What heat-shrink tubing size would I need to fit the diode and wires?
TM is offline   Reply With Quote
Old 03-21-2014, 12:06 AM   #102
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
Both boomerangs were on, both headlights were on, and both DRLs were on when it should have only been one DRL, IIRC - its been a few weeks now.
For tips on soldering I would just watch a youtube how to video and you should be good man, its not like welding or anything. Use flux and it almost does the work for you.
For heat shrink the easiest thing to do is get a small assortment and just eyeball it. You only need about 6 inches to do the whole thing.
EvilBeaverFace is offline   Reply With Quote
Old 03-21-2014, 09:18 AM   #103
TM
TM's Avatar
Drives: DGM BRZ 6MT
The headlights turned on, too?? Why does that happen?
I'm wondering if I will need to do it on both sides or just one.
Old 03-21-2014, 10:55 AM   #104
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Watch a couple good HOW-TO solder videos, and practice on some spare wire FIRST.
Deathalo is offline   Reply With Quote
Old 03-21-2014, 12:42 PM   #105
sshole
Could be that the DRLs are wired together somehow? I know on the 08+ STIs, if you jumped the DRL relay to the passenger side fog light, both fog lights would turn on.
sshole is offline   Reply With Quote
Old 03-22-2014, 02:50 PM   #106
EvilBeaverFace
No no, when I turned my headlights on the DRLs would normally be off. I had only modded one side but both DRLs were on.
Old 03-23-2014, 11:13 PM   #107
Lithium
Lithium's Avatar
Drives: like an asshat
Absolutely, I would grab 12 volts from an ignition source (12 volts when key is in the run position) to the switch of your choice. Than from the switch to DRL anode (positive). Make sure to do a write up if you do this.
Lithium is offline   Reply With Quote
The Following User Says Thank You to Lithium For This Useful Post:
ericvanderwoodsen (03-24-2014)
Old 03-23-2014, 11:17 PM   #108
Lithium
Lithium's Avatar
Am I close?
I'm not following well, what color wire is the diode attached to in Modena's adapter harness?
codesplice (03-23-2014)
Old 03-23-2014, 11:22 PM   #109
Lithium
Lithium's Avatar
did you ever get it figured out?
Old 03-23-2014, 11:24 PM   #110
codesplice
codesplice's Avatar
No worries, I got it sorted once I stopped trying to overthink it. Works great!
Thanks for posting the DIY
Sent from my Nexus 4 using Tapatalk
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
Old 03-24-2014, 09:59 AM   #111
EvilBeaverFace
It was never really a problem. I just modded both sides and it was the same anyway. Just thought it was weird on one setting that both sides were the same even though only one side was modded. No big deal.
Old 03-24-2014, 05:44 PM   #112
Cato
Diode will drop voltage by 0.6 volts
I like the idea of this mod and will probably get around to it eventually. One thing that no one has pointed out is that the diode has a voltage drop of 0.6 volts or so, though you probably wouldn't notice that loss in brightness.
If someone electronically inclined could try wiring a simple MOSFET circuit together on small breadboard, you might be able to get around this.
Thanks for all of the pictures and instructions on accessing the wires. That's the toughest part to figure out.
Cato is offline   Reply With Quote
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
Right headlight wont turn on Matt90 Issues | Warranty | Recalls / TSB 9 11-11-2013 03:56 PM
My turn. =( jonbonazza Scion FR-S / Toyota 86 GT86 General Forum 28 07-15-2013 02:57 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
