Old 02-17-2014, 01:26 PM   #15
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Update?
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
TouchMyHonda is offline   Reply With Quote
Old 03-20-2014, 07:58 PM   #16
autoCAR
Drives: 5/2013 scion frs
Originally Posted by TouchMyHonda View Post
Update?
Car has had thousands of miles on the whiteline bushings and all is good.
autoCAR is offline   Reply With Quote
Old 03-20-2014, 08:35 PM   #17
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
can you share how he fixed the problem? re-tap the hole? helicoil?
Old 03-20-2014, 08:55 PM   #18
autoCAR
i only cross threaded a small section of the threads, 3/4th's were still good, he retapped with original threaded tap, and the bolts went in with no problems, red locktite was used aswell.
Old 03-20-2014, 10:52 PM   #19
Wepeel
Drives: '13 BRZ Ltd
I just installed these last weekend. If you are trying to get the rears back in, loosen the front subframe bolts - this will give some slack. If you just take the rears out and drop it enough to get the upper bushings in, the bolts will only hand-thread in a few turns then stop. If this happens, do not get a wrench to apply more torque! Loosen the front bolts and play with the height of the rear or shift it around a bit as you hand tighten the bolt. You should be able to hand tighten it most of the way.
Wepeel is offline   Reply With Quote
Old 07-26-2014, 12:02 AM   #20
Brinks
Brinks's Avatar
Wish I read this before I started my install, Fucked both sides up. Not too bad but enough to be stuck without the tap. Lead time for a long 14 1.5 is about three weeks. Went to 6 different stores today with no luck, only 14x 1.25. Good thing I have another car. The Whiteline instructions should tell you that it might be a good idea to loosen the front mounts to get a better angle on the rear bolts.
Brinks is offline   Reply With Quote
Old 07-28-2014, 12:59 PM   #21
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Well I'm one of the guys who messed up my passenger rear subframe mount, that was mentioned in a previous thread. My tap is on its way to @Brinks . I said I would make it a community tap for anyone needing it, so if you need one in the near future... contact Anthony @Brinks).
Kwaziekeller is offline   Reply With Quote
Old 07-28-2014, 07:43 PM   #22
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
wow, red loctite? You wont be taking those off again haha.
Glad its all fixed though, and a good thread as a heads up to people installing bushings.
Old 07-29-2014, 03:09 AM   #23
Natheria
Overlord
Natheria's Avatar
Drives: SWP 13 BRZ, 94 Miata
Someone 10-15 years from now who gets the car and wants to take those out will want to strangle him (I think we all know that feeling when dealing with used cars).
"FR-S or BRZ, it doesn't really matter, they're the same to me. It's a matter of choice, like mass effect, but then the thought of boxer engines make my mass erect!" -The Roman
Natheria is offline   Reply With Quote
Old 07-29-2014, 12:09 PM   #24
continuecrushing
haha, right? I picked up a motorcycle a few months back, and the previous owner(s) did some "interesting" things.
I sometimes wonder if/when I sell my car, if the next person will be like "wtf did this guy do"
Old 07-31-2014, 01:26 AM   #25
Brinks
Brinks's Avatar
Just got everything dialed in. The threads were not messed up too bad. loosened up the front mounts to align the rear and hand tighten the bolts till they came flush with the sub frame. Its kinda obvious in retrospect that you need to loosen the fronts before threading the rears.
To anybody that is thinking about this install, make sure you look up through the sub-frame mounts to see if everything is aligned first before you even start to thread the bolt. If the bolts stops by hand, take it out and preposition the subframe.
Thanks again @Kwaziekeller
If anybody needs a long 14x1.5 Tap hit me up,,.
Probably not a good idea to use red lock tight either, you have to use a torch to loosen that stuff up.
Old 07-31-2014, 12:00 PM   #26
Kwaziekeller
No problem, glad u got everything fixed and the car back on the road. I figured that I only bought the tap for that purpose so why not share it around since I probably won't need it ever again.
Old 07-31-2014, 04:34 PM   #27
Brinks
Brinks's Avatar
Anybody have to have the rear alignment done after installing? I'm getting some vibration through the gas pedal.
Edit - ended up being an exhaust leak
Old 08-21-2014, 02:37 PM   #28
Luis_GT
Had this happen to me... wish I had found this thread earlier... friend lent me a tap and die set with the 14x1.5 set, and now have the rear of my subframe on...
Still gonna order a 14x1.5 helicoil set just in case something happens down the road...
Whiteline rear subframe bushing install... fl_speed001 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-11-2020 12:29 AM
Whiteline KDT922 (Subframe Bushing Inserts) Grease - Safe to use on Rubber? eckoflyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-14-2018 11:24 AM
whiteline rear subframe inserts charged86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 05-18-2013 09:20 PM
Subframe/Drivetrain Thoughts.... TrackDog Scion FR-S / Toyota 86 GT86 General Forum 12 11-10-2011 10:53 PM
