Old 11-10-2011, 11:21 AM   #1
TrackDog
On-Ramp Renegade
Drives: 2005 Subaru Legacy GT
Subframe/Drivetrain Thoughts....
Being that a good number of these cars will be bought with daddy's money and handed over to teenagers who have no clue about how a front engined/RWD car handles, it stands to reason that a pretty good number of these cars will be totaled. That being said once they start showing up in salvage yards the drivetrain, and suspension assemblies seem like they would be prime candidates for building a superlight trackday car like the Atom/Caterham. Just think if you could find one that had been wrapped around a utility pole in the passenger side door for around $5-6k. Strip out the go fast bits, Part out what can be saved from the body, sell the shell to the recycler, shorten the wheelbase by about a foot, weld up a cage, reinstall said go-fast bits. Result is a car that would weigh about 1200lbs and goes like stink at 6lbs/Hp with a bulletproof stock drivetrain. For probably less than $8000. Your Thoughts???
-Joe
TrackDog is offline   Reply With Quote
Old 11-10-2011, 11:27 AM   #2
Shin
Shin's Avatar
Drives: Highlander, Corolla, Asphalt FR-S
Sounds dangerous in the case of a crash.
Shin is offline   Reply With Quote
Old 11-10-2011, 11:30 AM   #3
TrackDog
On-Ramp Renegade
Well it wouldn't be street legal at all but a properly build cage out of DOM tubing and a helmet would probably be alot safer than the original car...
-Joe
Old 11-10-2011, 11:49 AM   #4
Longhorn248
Hook 'em
Longhorn248's Avatar
When you start getting to work on it let me know and I'll take a trip over to Alabama and give you a hand!
I think it will take a bit of skill and precision to produce a well handling car if you're buidling the chassis from scratch, but the power to weight ratio is definitely something to drool over.
Longhorn248 is offline   Reply With Quote
Old 11-10-2011, 12:10 PM   #5
TrackDog
On-Ramp Renegade
Thanks for the offer. I really dont think it would be that hard. As seen In the chassis diagrams, the rear suspension/drivetrain is all one subassembly that bolts to the unibody. With regards to the front, once the suspension is removed I dont think it would be too hard to weld up a jig that fits in the original body's suspension mounts. Once you have that jig assembled it's just a matter of building the new cage to fit around that jig. Then remove the jig and mount the suspension pieces. It's all theoretical at this point because we don't even have a production car yet, but it's definately something to think about. I've been thinking about doing this to a NB miata for awhile now. As you can see from the pic below, Miata's whole drivetrain and suspension can come out in one unit, but the FT-86 looks like it might be a better candidate performance wise.
-Joe
-Joe
Old 11-10-2011, 12:24 PM   #6
keiri
Toyobaru Wonder Twins™
keiri's Avatar
Drives: 2020 Subaru BRZ Limited w/ PP
That is a bloody beautiful sight to be honest; I can only imagine the kind of trackrat you could have with a tubular shell/frame built into/around the NB's drivetrain.
keiri is offline   Reply With Quote
Old 11-10-2011, 12:48 PM   #7
oneday
Opinionated
oneday's Avatar
Drives: Something Red
People have been using Miatas, S2000, and various other platforms for this purpose since these donors were available. I've had the privilege of flogging a LoCost built on the NB drivetrain before and it is a hoot...and a friend of mine is starting a similar project in his garage this winter...there is even a forum for like-minded lunatics to get support from.
GRM Article about a Locost build they did in 48 hours
Googling "Miata Locost" will also net you a lot of info.
Most of the cars I drive have nets for windows.
oneday is offline   Reply With Quote
Old 11-10-2011, 12:49 PM   #8
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
As long as it's a single seater and open cockpit, I approve lol.
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 11-10-2011, 12:56 PM   #9
oneday
Opinionated
oneday's Avatar
Really? It's auto racing, of course it's dangerous.
Whatever you do, don't watch this:
[u2b]jDrNrPLhqow[/u2b]
despite the title, there is no way the car was doing more than 80 when the wreck occurs
Old 11-10-2011, 01:05 PM   #10
oneday
Opinionated
oneday's Avatar
Locosts generally aren't one seaters....Legrands are, me in my third event in one of those::
[u2b]fsBIoDT6lio[/u2b]
Old 11-10-2011, 03:17 PM   #11
Dimman
Kuruma Otaku
Dimman's Avatar
Factory5 is building a new kitcar around a Subaru drivetrain (MR, though I think...).
Because titanium.
Old 11-10-2011, 05:02 PM   #12
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
I'd rather take the drivetrain from a wrecked one and put it in my Impreza
The rear subframe on this car looks to be almost exactly the same as a 08+ Impreza, and the front is kind of a reverse Impreza subframe. So, I'd ditch the suspension bits if I were making a track car and go with something better.
Kostamojen is offline   Reply With Quote
Old 11-10-2011, 10:53 PM   #13
Sully
Drives: In the market for something fun
www.locostusa.com
Boxers are a wide, very rarely used engine for these types of cars. You couldn't follow the common plans/proportions. STrut front would also screw things up, virtually all of these types of cars have double wishbone front/rear. Though struts hubs aren't always hard to adapt to an upper wishbone.
Here's somebody who took the miata subframes and built an atom-esque car around them. http://www.locostusa.com/forums/viewtopic.php?t=8332
1200lbs might be a bit optimistic, most of these little tube frame cars end up 1300-1400. But it's good to have goals.
Sully is offline   Reply With Quote
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
Your thoughts of the Ford Mustang Abflug Other Vehicles & General Automotive Discussions 31 08-25-2011 10:15 AM
Thoughts and secrets of the FR-S/FT-86 Interior KevinDuMa Scion FR-S / Toyota 86 GT86 General Forum 56 07-21-2011 02:38 PM
Drivetrain experts! Name this car! :) aspera Engine, Exhaust, Transmission 200 08-15-2010 11:41 PM
