Old 03-20-2014, 09:56 AM   #1233
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by 355rockit View Post
I am assuming as long as only the exterior of the header is coated and the Catalytic converter is not coated... it shouldn't be an issue.
correct.
FT-86 SpeedFactory is offline
The Following 2 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
355rockit (03-20-2014), husker741 (03-20-2014)
Old 03-20-2014, 06:37 PM   #1234
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Originally Posted by FT-86 SpeedFactory View Post
correct.
Is FT-86 SpeedFactory explicitly recommending that folks coat their headers, for daily or track use? I have no former experience either modifying or purchasing aftermarket headers and I want to make sure I am doing it right.
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline
Old 03-20-2014, 07:53 PM   #1235
FT-86 SpeedFactory
We are not saying one should or should not coat it. If you want to go for it.
Both our shop cars are running our header uncoated and see extensive track use which is going to be way higher heat than daily driven cars. ( Silver Car is Catless Version, Red Car is Catted Version )
chas3wba0 (03-20-2014), Re~Mix (03-21-2014)
Old 03-20-2014, 07:54 PM   #1236
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Curious as to why you wouldn't want to coat the catalytic converter? I would think it would be the one generating a good amount of the heat.
BigFatFlip is offline
Old 03-20-2014, 08:24 PM   #1237
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
I'm assuming it needs to radiate off the heat so it doesn't melt the cat?
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline
The Following 2 Users Say Thank You to Turkish For This Useful Post:
BigFatFlip (03-20-2014), EpicNameBro (03-20-2014)
Old 03-20-2014, 09:26 PM   #1238
sato
sato's Avatar
Drives: Dodge Patitas
I'm talking out of my ass here, but maybe it is for the catalytic converter not to retain too much heat (better cat longevity?)
Sent from my C6906 using Tapatalk
sato is offline
The Following User Says Thank You to sato For This Useful Post:
Old 03-20-2014, 10:28 PM   #1239
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
The cat does it's job by generating a large amount of heat in the catalytic core to burn off the undesirable byproducts of burning the fuel. Coating the cats will reduce the amount of heat that can be dispersed from the core and eventually cause premature failure of the core. The ceramic core could break down and in some cases, could clog the secondary cat and or muffler causing other undesirable issues.
355rockit is offline
Old 03-21-2014, 12:48 AM   #1240
msile
msile's Avatar
Drives: ISF
Depends on what eventually is defined as. 2 years? 4 years? I have coated the cat on all my track cars with no issues so far. I just did the UEL as well with my second track day this weekend. Over 500 miles so far. It will be fine.
1993 MR2 Turbo - Red
1996 Supra Turbo - White
2011 ISF - Mercury Metallic / Black Suede
2013 Scion FR-S - Firestorm Red
2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery)
msile is offline
Old 03-21-2014, 12:10 PM   #1241
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Any a&b, before&after, dynos yet from the new customers??
fooddude is offline
Old 03-21-2014, 12:56 PM   #1242
Sypher
Sypher's Avatar
Drives: '13 Ultramarine FR-S M/T
Check post 1073. In this thread. It doesnt show a base line but it does show the nice flat torque curve.
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's
Sypher is offline
The Following User Says Thank You to Sypher For This Useful Post:
kodyo (03-21-2014)
Old 03-21-2014, 07:38 PM   #1243
jonbonazza
Just an update on the exhaust leak. It was nothing to do with the header (as I guessed), but one of the gaskets that came with Motiv OP was bad. I replaced it with the OEM subaru gasket that came with the header and she's leak free and sounds AMAZING! WOOO!
jonbonazza is offline
The Following User Says Thank You to jonbonazza For This Useful Post:
FT-86 SpeedFactory (03-21-2014)
Old 03-21-2014, 08:53 PM   #1244
sato
sato's Avatar
Video or bust!
sato is offline
Old 03-21-2014, 09:02 PM   #1245
Slowbaru
Slowbaru's Avatar
Drives: 2013 WRB BRZ Limited
Originally Posted by sato View Post
Video or bust!
I agree. Unless everyone that has got theirs already owns a jitterbug. At least a phone vid please.
Slowbaru is offline
Old 03-21-2014, 09:17 PM   #1246
jonbonazza
Video or bust!
Taking some logs tonight. I'll get one then.
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
