Old 03-18-2014, 09:35 PM   #1219
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Originally Posted by jonbonazza View Post
Doin' work!
Attachment 70911
Yikes! Never jack up nor use the oil pan to support the engine, the whole front end of the car nor any other heavy weights (even just laying the engine on the floor). Some designs have the oil pickup "straw" super close to the oil pan's floor on the inside; and when dented, could block oil flow, starve the engine and straight up blow the mutha.
It's happened to several people in the past (including myself, with a rod straight through the block). A very common problem with imported engine swaps (since those engines are slid around and banged around a lot on the floor during shipments, resulting in messed up oilpans).
fooddude is offline
Old 03-18-2014, 09:45 PM   #1220
jonbonazza
Wow okay, thanks for the heads up! This is the case even when using a rubber block? Where should it be supported? Not many options down there.
jonbonazza is offline
Old 03-19-2014, 01:09 AM   #1221
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
If you properly loosened the engine mounts and use something rubber or wood on the oil pan it is fine.
Do not use the jack straight on the pan.
GR86 MT premium
StormTrooper is offline
Old 03-19-2014, 09:40 AM   #1222
SCharged
Drives: asphalt fr-s
Guys, another heads up, make sure you torque back the engine mount bolts to spec, do not listen to youtube ''experts''. I stripped the thread on one of my engine mount studs by trying to torque it as indicated in a (professional looking) youtube video when installing my OP. I believe OEM spec is 28 lbs, but you should double check...
The video said somehing like 68 lbs.. and I gave it a little more just to be sure.. errgh.. lessons learned I guess, but now likely need to get a new mount on the driver side..
SCharged is offline
Old 03-19-2014, 01:23 PM   #1223
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Is it necessary to jack the engine up to install this header? My friend installed his Revworks with no need to jack up the engine.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline
Old 03-19-2014, 01:27 PM   #1224
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
No. The only time you need to jack up the motor is for an overpipe install.
FT-86 SpeedFactory is offline
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
CamryDS (03-23-2014)
Old 03-19-2014, 02:03 PM   #1225
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Ordered mine. But probably won't get to enjoy it til next summer lol.
tahdizzle is offline
Old 03-19-2014, 03:35 PM   #1226
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
I received my header today and then dropped it off at Olympic Coatings for ceramic coating. I am going with their black thermal-x that is good to 2000*F. It'll be a long 2 weeks until I get the headers back. Can't wait to install. Thanks FT86SF!
355rockit is offline
The Following User Says Thank You to 355rockit For This Useful Post:
FT-86 SpeedFactory (03-19-2014)
Old 03-19-2014, 03:56 PM   #1227
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Just got my tracking info
I was number 4258.
husker741 is offline
The Following User Says Thank You to husker741 For This Useful Post:
JaguarXJ6 (03-19-2014)
Old 03-19-2014, 03:57 PM   #1228
FT-86 SpeedFactory
It won't be that long promise. Starting to roll them out now.
Old 03-19-2014, 09:31 PM   #1229
355rockit
If anyone is receiving their header in San Diego county, let me know if you'd like to meet to do the headers together. I have all tools, etc and a decent sized garage. I am looking at installing mine around 1st weekend in April given the headers will be back from coating.
The Following 2 Users Say Thank You to 355rockit For This Useful Post:
DAN_BRZ (03-20-2014), EpicNameBro (03-19-2014)
Old 03-19-2014, 10:03 PM   #1230
EpicNameBro
Drives: Slow...
Can't wait to see how the coating turns out on your's. Please post results as i may be going this route myself here shortly based on what i see...
EpicNameBro is offline
Old 03-19-2014, 10:52 PM   #1231
husker741
I still wanna know if we get the header coated if the warranty is still good. @FT-86 SpeedFactory?
nor cal frs (03-19-2014)
Old 03-19-2014, 11:56 PM   #1232
355rockit
I am assuming as long as only the exterior of the header is coated and the Catalytic converter is not coated... it shouldn't be an issue.
husker741 (03-20-2014)
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
